Question about Car Audio & Video
No mounting sleeve for my car stereo
I want to have my car stereo installed, but I am missing the mounting sleeve, cage, or whatever you call it. What alternatives do I have by the way of finding a replacement?
  • james kappers
    james kappers May 11, 2010
    what type of car is it in?
  • 80 Answers
Autozone or ebay will have it!
thanks
erik
Posted on Feb 27, 2009
JVC KD-S595 car stereo. Trouble removing
It depends what kind of car it's installed into and the mounting technique used. Removal keys apply only to a radio that has been DIN mounted (ie: metal sleeve utilized). Many vehicles or radio kits use the ISO mounting method which involves screwing into the sides of the radio to secure it. Keys will not help in this situation. The dash or radio trim must be removed to access the screws on the sides.
With the front trim of the JVC removed, you should be able to see the metal sleeve around the radio if it was used. If not, the radio was ISO mounted.
Dec 26, 2013 | Car Audio & Video
I just bought a 91 Honda accord, and the factory stereo was missing so I went out and bought the stereo installation kit also a new stereo but don't know how to mount without mounting brackets looked...
If you purchased an installation kit it should include universal mounting brackets. Perhaps you do not have an installation kit for installing your new stereo in your Accord. The kits are designed for installation of certain stereos in an Accord; not every model
Feb 24, 2013 | Cars & Trucks
How to remove a deh 21001b from a vt commodore
He may have to get underneath the dashboard and see if their is a security strap or wire harness holding the radio into the mounting sleeve. It's common for installers to strap down the stereo to prevent thefts and other installer from easily taking the radio out. Have him keep trying.
Nov 26, 2012 | Pioneer DEH-2100 CD Player
I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
Oct 14, 2010 | Sony XPLOD CDX-GT200 CD Player
My lead got caught in the jack input of the pedal i pulled it out and now it wont work the led light will not turn on even.
This is a simple problem. The input jack is a "stereo" type which we call TRS for tip-ring-sleeve meaning there are three connections. It will involve soldering.
The way it is used with your guitar cable is that the third contact on that jack (the "ring") is used to turn the thing on because your MONAURAL guitaar cable shorts that ring contact to the sleeve completing the circuit for the battery or power cube if you are using that.
These jacks are EASILY destroyed by bending the plugged in cable a bit.
Solution: Go to Radio Shack and get a panel mounted "Stereo" jack (they may come two to a package, make sure it is the Stereo type).
Open your unit and install the jack. If the one in your pedal is a plastic one mounted on the board (those are even more fragile) see if you can't use the Radio Shack type anyway with short jumper wires to the circuit board.
If you would rather use a board mounted one, they are available from Mouser.com or DigiKey.com. You can pick out the part from teh online catalog... note that there are MANY ocnfigurations.
Aug 18, 2010 | Boss Mt 2 Metal Zone Effects Pedal
ALTERNATOR REPLACEMENT
Assuming this is a XG 350, the process is lengthly.
1. Remove the RH radiator cooling fan (two 10mm bolts at the top & wiring harness connector to it).
2. Lift vehicle to remove the Right Front wheel (then remove 4 10mm bolts securing the plastic splash shield & remove it)
3. Loosen the 14mm nut on the alternator belt tensioner pully
4. Loosen the tension on the belt by rotating (counter-clockwise) the 14mm bolt at the bottom of the idler pully and remove the belt.
5. remove the pully & the idler pully (three 12 mm bolts)
6. Loosen the 14mm nuts at the top and bottom mounting points of the alternator.
7. Using a floor jack (or vehicle lift), support the engine using a jack-stand & 2x4 piece of wood under the oil pan.
8. This is tricky - lift the engine 'SLIGHTLY' to take pressure off the front engine mount - loosen the 17 mm nut on top of the mount itself and observe engine movement. If the engine moves upward 'slightly' remove the 17mm nut - if not, raise the engine slight more until you see the mounting bracket rise off the mount.
9. Remove the remaining 17mm nut (deep well socket), and two 17mm bolts and remove the engine mount bracket.
10. Here's another tricky step. Some 350's bottom Alternator bolt bores are 'SLOTTED'... some are NOT. You'll need to determine wether you'll need to REMOVE the lower bolt, or just loosen the mounting sleeve at the bottom bolt. If it's 'sleeved', I use an air hammer to loosen the sleeve. If it's not slotted, I remove the lower bolt (it's the only way to remove the alternator and pry it off).
11. At the top is an "L" bracket which uses two 12mm bolts to attach it to the engine (head). One of the two 12mm bolts is difficult to get to -- do your best to remove it because the battery cable to the alternator is in the way.
12. Disconnect the alternator wiring (battery cable & regulator harness connector)
13. Lift the engine as high as it will go & pry the alternator off its lower mounting.
14. manuver the alternator upward taking care not to damage the radiator.
15. Installation is in reverse order.
NOTE: If your XG's lower mounting point was slotted, your task is easy. If it isn't, your task now becomes more difficult as you must align the new alternator to facillitate re-insertion of the lower bolt.
PS If not slotted, I use a telliscoping magnet to help re-insert the lower bolt.
Aug 09, 2010 | 2004 Hyundai XG350
Trying to install a CDE-9881 into a 93 Honda Accord, is the mounting sleeve the only hardware used, or is there a mounting bracket also. Stereo will go in dash, but is unstable, and cuts out.
Take your radio unit out of the mounting sleeve and see if you can bend tabs to hold the sleeve more securely to the dash panel... Not the greatest mounts... look on top, bottom and sides...
Nov 27, 2009 | Alpine CDE-9881 CD Player
A friend bought me a cannondale airspeed maximum pump i am trying to mount to my bike it has a snap type mount? with screw holes matching the bottle mounts how does this work? pump will not be centered on...
The pump mount is installed under the bottle cage, if you have one, using the same bolts. Sometimes longer bolts are required.
The pump snaps into its mount besides the bottle cage, on the left or right side.
Nov 04, 2009 | Cycling
I need to install a kenwood cd player into my 2001 ford explorer step by step
goto the auto parts store and purchase a pair of stereo keys, fascia adaptor and wiring harness (you may need to get fascia and harness from a car audio store or circuit city.)
Then use the stereo keys to remove the factory stereo. Push them into the small holes on the front of the stereo push them slightly outwards and pull to release the stereo. Unplug all the connectors from back keeping track of where they fall.
Insert wiring harness into the stock wiring
attach fascia in regards to its packaged instructions.
Place cage from new stereo into the hole in the dash using the tabs on cage to secure it,
Attach stereo to other end of new harness along with aerial (may need adaptor for this also depending on the new head unit.)
Insert stereo into new cage and voila nice new stereo.
Nov 27, 2008 | Kenwood Car Audio & Video
Car Audio & Video Logo
2,423 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
