Question about Husqvarna Designer I
Screen is frozen
Put on my hoop and was ready to begin embroidery...suddenly the screen just froze and wouldn't allow me to do anything. I tried turning it off and on, but the only thing I get is the welcome screen.
  • nurseplj Feb 28, 2009
    I am having the exact same problem. Even tried unplugging and leaving overnight hoping it would reset.
  • Kent Sechrest
    Kent Sechrest May 11, 2010
    Do any of the buttons above the needle work?. Needle up down foot up/down etc?
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Remove the embroidery unit and see will come on then. If not, it is probably the PC board. If it does come back on, it may be the embroidery unit or the connection. Take to authorized Husqvarna Viking dealer for service or have them send it to Husqvarna Viking (SVP) Technical Service Department for repair. A list of authorized Husqvarna Viking dealers can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Posted on Sep 26, 2009
Ready to stitch embroidery letters but nothing happens. The start/stop button and the number 10 design on the machine blinks. What is wrong?
Make sure the machine is on a solid, level surface. Also, it may not work if you don't have the correct foot on the machine.
Mar 12, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Brother PE770 Hoop size programming stuck on small hoop option
Your machine would be able to perform 5 X 8 embroideries. The hoop size on this machine is recognized by the machine itself, depending of the embroidery file size. So it the embroidery is small, it will indicate that the small hoop is needed.
But U can use the large hoop, position the embroidery where U want then perform another embroidery on the sams hoop.
TRICK : the embroidery size exceeds the hoop? reduce it in X and or Y using this function on the machine
Jun 10, 2012 | Brother PE770 Computerized Sewing Machine
Jumbo hoop
I assume you mean the clips that attach the hoop to the embroidery unit. You just hold the hoop by means of the two clips, with a thumb and other finger on the outside of each clip - pressing them together allows the hoop to be put onto the two clips on the Y arm of the embroidery unit. When you release the spring pressure, the hoop should be retained in place on the Y arm.
Nov 25, 2011 | Bernina Sewing Machines
In the middle of stitching a design - and when I came to a color change, the new color began stitching 1 to 2 inches below where it should. The screen showed the correct place, but the needle was way too...
If the design isn't too big, try rotating it in the hoop and stitch it sideways. If it works in that position, you probably should have the embroidery unit cleaned. I recommend the embroidery unit be serviced every 5 years. It may need it more often depending on your environment.
Dec 11, 2010 | Husqvarna Designer I
I bought a new embroidery unit for my designer 1 when I but it on it makes e terible noise and says to slide of hoop and clear position for i . embroidery position'But it won't go into embroidery...
Don't know for sure what is happening, but you should not put on a hoop until you are actually ready to embroider. The unit goes on while the machine is turned off; turn on the machine; it will make a noise; you should get a pop-up on your screen to Calibrate the unit. Touch this button, and the arm moves into position ready. Load your design and choose the correct hoop then put the hoop and project on the machine. Also be sure that your design will fit in the hoop selected.
Sep 01, 2010 | Husqvarna Designer I
I have the quilters 150x150 hoop and I need an update to use it, the button on my embroidery machine is grey I think it needs to be dark blue
Dark grey, actually, but you don't need the upgrade. Set the hoop size at the machine for the 150 x 240 hoop and the 150 x 150 hoop will work. Just be sure that the design starts in the centre i.e. don't move it up or down at the machine Embroidery screen. Before you begin sewing, check that the design will fit in the hoop without bumping the sides of the hoop. Use the Check Size button which is on the second screen of the Embroidery Screen (touch More on bottom right of first screen). The Check Size button is the one on the bottom right - the first button to the left of "More". Touch it once, hoop moves to top left of design; touch again hoop moves to bottom left of design; again hoop moves to bottom right; again hoop moves to top right.
Make yourself a note so that when you next take your D1 in for its regular service, get the hoop upgrade done at the same time. You need to have at least version 2.1 of the machine software installed - your tech. can do this for you too. It is a really minor adjustment so should not add much to the service cost. Be sure to take the embroidery unit in too when you go for the service.
Nov 16, 2009 | Husqvarna Designer I
Do I need the embroidery hoop? does it connect to the thing in the back of the machine and moves areouns?
  1. What do I need to get started at free machine embroidery?
    • A zigzag sewing machine with a drop-feed control. (In other words, you have to be able to lower the feed dogs so they don't try to feed the fabric.) It's nice if you can vary the width of your zigzag stitches too.
    • An embroidery foot or needle with embroidery spring. An embroidery foot helps by holding the fabric down against the throat plate while nevertheless being minimal - it lets you see what you're doing because it has very little surface area. You can alternatively get a needle that has a kind of spring built into it, and the spring holds the fabric in place. These can be nice in that they're even more minimal than an embroidery foot, but they're also relatively expensive and if it breaks you have to replace the whole thing instead of using an ordinary cheap needle with the special embroidery foot. If you use the needle with spring, you don't use a presser foot while you embroider.
    • An embroidery hoop. There are two primary kinds of embroidery hoops on the market. The old-fashioned kind, usually made of wood, has an outer ring and an innter ring. You loosen the outer ring, separate the rings, place the fabric over the inner ring, place the outer ring over the fabric, tighten the outer ring, and pull the fabric tight in the hoop. With the modern type hoop, you squeeze a pair of handles on the inner ring to remove it, place the fabric over the outer ring, place the inner ring (still squeezed) into place and release the handles. The more modern hoop is faster and easier. The old-fashioned hoop provides better tension on the fabric.
    • Stabilizer. This helps prevent puckering and slipping while you're embroidering. There are a variety of types out there. Some are papery and are torn away from the embroidery when you're done. Only use that on the back side of the embroidery, as it's almost impossible to get it all off. Others are also papery and also tear away but are dissolvable in cold water, leaving only a few easy-to-remove fibers in the embroidery. Your authors like this type of stabilizer. There is also a transparent plastic-like stabilizer which dissolves completely in water. Your authors have this but haven't tried it yet, but hear it's very nice. It's expensive though.
    • Fabric... of course. Make sure that your embroidery hoop fits on the piece you're going to embroider on. If the piece is to be small, you may want to embroider before cutting the piece from the fabric.
    • Thread. Contrary to popular belief, you can use ordinary polyester all-purpose thread to embroider, but it can weaken the fabric you're embroidering on. (If you do use polyester, you may want to fuse some interfacing to the back of your embroidery when you're done.) There is plenty of gorgeous 100% rayon embroidery thread available.
    • Thread for the bobbin. This won't be seen on the surface, so you can use anything you want. Trying to find a way to get rid of that day-glo orange thread you can't remember why you bought? Stick it in the bobbin when you embroider. Some embroiderers feel that it's best to use a softer thread (like 100% cotton) in the bobbin so as to reduce the possibility that the bobbin thread will break the embroidery thread, but your authors haven't had a problem with this to date.
  2. How do I prepare the machine and fabric for free machine embroidery? Drop the feed dogs and set the stitch length at zero. (If you can't set the stitch length at zero, don't panic, it's not that important.) Install the fabric in the embroidery hoop (with any stabilizer[s] you intend to use) so that the surface of the fabric is at the *bottom* of the hoop. (Note that if you're used to embroidering or cross stich by hand, this means you're putting the fabric in the hoop backwards.) When you place the hoop on the table such that the fabric surface rests on the table, the right side of the fabric should face up. Install the embroidery foot or special embroidery needle with spring on the sewing machine. If you're using the special needle, remove the presser foot. Place the embroidery hoop in the sewing area. (Some machines can't lift the presser foot enough to admit some hoops - you may have to remove the presser foot temporarily, position the hoop, and then re-install the presser foot if you're using one.) Set the sewing machine for a straight stitch. Reduce the upper tension until stitches interlock below the fabric instead of above or inside it.
  3. How do I lock the thread at the beginning and end of my embroidery so it doesn't begin to unravel? Make several stitches in place to lock the thread.
Nov 13, 2009 | Janome Memory Craft 9000 Computerized...
Designer 1 touch screen freezes
Static Electricity and Designer 1:
The designer 1 is susceptible to static electricity. They sell static removers for electronics. Try that 1st. Don’t spray your machine, just the rag and wipe the machine. Endust for electronics makes a pump spray and you can even use it on the screen (DONT spray the screen). Then try to recalibrate the screen in the set menu. If you can’t get into the set menu keep trying until you can otherwise, there is a way to get into the service mode to set it.
Feb 25, 2009 | Husqvarna Designer I
Embroidery unit
Do you have a hoop already on when you first re-calibrate the embroidery arm? You need the embroidery arm ONLY when you first turn on. Don't put the hoop on until you are ready to start embroidering. If this is not the problem, try re-loading the machine operating system. If you did not save your floppy or USB file, go to Husqvarna website and download the latest one, and re-load it. (Be sure to select the correct file for your particular machine i.e. floppy or USB.)
Pamsquilt
Aug 10, 2008 | Husqvarna Designer I
Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Regards
dupina
Dec 11, 2007 | Husqvarna Designer I
Sewing Machines Logo
227 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
