Question about Compaq Evo N800c Notebook
Mr. I need to replace the screen on my Evo n800c. I have the new screen it comes with the entire housing to where it screws into the bottom portion of the laptop where the keyboard is. I am having a problem getting the bottom case apart to switch out the screens. I have taken out all of the screws that I can find and it still wont separate.
  • aredxwrestle Feb 27, 2009
    I figured it out after I posted this, but thank you anyways.
  • Compaq Master
  • 32,281 Answers
There is no need to remove the bottom case.
There are screws on the back edge that fixes the LCD hinges to the base of the laptop.
Remove the plastic panel on the laptop between the LCD and the Fn keys/LED lights/push buttons. You most likely need to fold the LCD flat to remove this panel. This panel is cliped in place, take care to unclip it, start at one end and work along to release it.
There may be further screws that fix the hinge to the base. Also there are cables that connect the LCD to th motherboard, be careful to remove the cables before you remove the LCD.
Posted on Feb 26, 2009
When plugged in power lights come on but there is no power to the laptop does anyone know why??
Your power supply/ charger is damaged, and needs a new adapter replacement. You can find replacement parts on ebay.
Jan 30, 2011 | Compaq Evo N800c Notebook
Wireless problem. message 'limited or no connectivity' appears regardless of adapter. evo n800c.
Unplug wireless router from power source for 10 seconds and plug back in and it will fix the problem
Or go to bottom right screen, find internet icon, right-click on it and then choose, repair connection
Dec 14, 2009 | Compaq Evo N800c Notebook
Blank LCD screen on Compaq n800c laptop
First instinct would tell me that your LCD has gone bad. A refurbished replacement LCD should run around $300-$325 give or take.
Keep us posted, good luck
God Bless
-Carlos:
Jul 09, 2009 | Compaq Evo N800c Notebook
On my Evo N800c labtop the words on the menue bar and desk top are hard to read, such as File, Edit, View, ect..
hi u need either to change the screen resolution or go to desktop -> right click -> properties ->Appearance -> change the properties to which u see it's good
Jun 06, 2009 | HP Compaq Evo Notebook N800c PC Notebook
Network problem with Compaq Evo N800c Laptop
you need to configure your Internet Protocol (IP) that synchronous the network. if you using WIFI you may need encryption code from your network provider.. beware on installing driver, it comes crashing in your machine.
Apr 09, 2009 | Compaq Evo N800c Notebook
Need the right wireless adaptor for the Compaq Evo n800c
It depends, do you have wireless capabilities on you modem or router, if you do yoy have a choice of wireless adapters. Either usb or pcmcia. You'll want one that is easy to hook up.
Mark
Mar 30, 2009 | HP Compaq Evo n800c Notebook
Compaq evo n800c not recognizing hard drive
Test new HDD in another laptop or else. Make sure it's not DOA.
Jan 01, 2009 | HP Compaq Evo n800c Notebook
I have a half white screen and the other half is usable..!
You mom will not kill you, the fault was probably not caused by you (you can tell her I told you)..
The fault most likely a faulty video chip on the laptop or a faulty connector between the laptop motherboard and the LCD screen. You can connect the laptop to an external monitor and the power the laptop up, if the image on the monitor is OK then the video chip is OK.
If the laptop is new then it should be under warranty, get it fixed or replaced.
Nov 15, 2008 | Compaq Evo N800c Notebook
Compaq Evo N800C
Try setting your resolution to 1400x1050, or the max that is available.
Also, use only 60Hz.
Use the native resolution of the screen, otherwise the laptop will interpolate pixels and make text look fuzzy.
Sep 08, 2008 | HP Compaq Evo n800c Notebook
Compaq Evo N800c Notebook Logo
80 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
