I have the ge 1105p dvd player. It will only play about 1 out 25 0r 20 files. I do not know if i am using the wrong converter or the wrong burner. would some of you who dot have this problem tell me what software you use to convert and burn. thank you for any help!!!! Bette
SOURCE: Won't play dvd's that I have burned even if decrypted or converted before burning.
Most players of this type have 2 laser eyes, 1 for CD and another for DVD. Based on your description, I would venture a guess that the DVD laser eye is at fault. If the unit was playing DVD before and the problem just occurred recently, then perhaps, cleaning with the use of a CD cleaner (similar to the ones used for computer CD ROMs) would correct the fault.
Should this not be the case, you may need to seek the services of a qualified audio technician who can either perform a manual cleaning (involves opening the unit) or diagnosis and repair if required. I am hesitant to suggest that you venture a do-it-yourself as this require working with a live/powered unit when performing tests and diagnosis.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
SOURCE: Trouble programming Universal Remote to a DTV Converter Box...
Not a complete solution, but, around the last page (pg. 14) of your converter box manual there are codes listed for universal remotes. I happen to have a Philips remote that is listed. My code to control my dtv box is 0354. It appears that they have all codes listed for all Radioshack model universal remotes. I would suggest getting a Radioshack remote for Your "Digital Stream" (Radioshack) dtv box...
SOURCE: Hi: I purchased a GE
you can send your info to
you can inquire and purchase parts at "appliancepartspros.com" and they will have the "conversion" kit from L.P. to natural gas,all you need to do is follow the enclosed instructions from them in the "conversion- kit"included and change the supplied 'gas orfices' at the burner tube and along the way in this conversion from L.P. to Natural Gas, these people can assist you 'online' at the same web address on how to safely convert this system,if uncertain on this change-over,contact your gas supplier & he can be contacted as to how to accomplish this SAFELY too!!!
'appliancepartspros
