Question about Estate TGDS840JQ Gas Dryer
The belt popped on my estate dryer and i got a new belt, how do i put the new one on. a diagram or tips would be helpful
  • 5,911 Answers
If the model number you have this listed under is correct, these are the steps necessary to replace the belt on your dryer:
1. UNPLUG the dryer.
2. Locate the two screws under the lint screen door on the dryer top panel. Carefully remove screws. NOTE: Do not drop them down the lint chute. Place a free hand over the opening, or cover with tape to prevent this from happening.
3. With two screws removed, the top panel will slide towards you, then lift up.
4. While resting the top panel against your shoulder (or propped up), remove the front panel by removing the door latch connectors and ground wires, first. Then locate the two screws that hold the front panel to the side casing. There is one on each side. Place you body against the panel with the door shut to support the panel while you loosen the screws. With the screws removed, the panel should lift up a bit then come off. NOTE: Tape the door shut while removing, so it does not fly open.
5. You can leave the drum in place, or remove it completely. The new belt needs to wrap around the drum and be routed through the idler pulley and drive motor pulley. NOTE: Since the routing of the drive belt differs on some dryers, refer to replairclinic.com for dryer belt diagrams. Just click on the "Repair Help" link at the top of the page, followed by the "Dryer Belt Diagrams" heading under the Special Features section on the next page. Refer to diagram H for your dryer.
6. Reinstall components in the reverse order of the steps provided.
ADDITIONAL HINTS:
1. If you remove the drum, make sure it is seated properly on the back drum roller supports or the back of the drum will not seal properly against the back bulkhead.
2. When installing the front panel, look for the small black cleats along the front edge of the side panels. There will be a small square shaped hole on the bottom edge on the back of the front panel that the cleats must insert into. This can take some coordination if performing the repairs alone. A second person can come in handy. Once the front panel is mounted on the cleats properly, place your body against it to hold in place until you get the screws back in place.
3. Make sure the front of the drum fits around the door opening seam of the front panel when installing. This ensures a proper seal along the front of the drum.
Read through all the steps thoroughly before attempting the repair. This may seem a bit intimidating, but the process is actually very simple. If you get stuck along the way, have questions, or require additional assistance, please let me know before rating the solution. I hope this helps you.
Posted on Feb 26, 2009
  • Jeff Rockwell
    Jeff Rockwell Feb 26, 2009
    If the model number is NOT correct, please post back with the correct information, so that I may be able to give you accurate advice.
My estate dryer stoped working.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 08, 2010 | Estate Dryers
Tip
Kelvinator Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
!970- 1995 models use this diagram
Style: Flat with ribs
Installation Tips: Ribs face toward drum
1995 – present models use this diagram
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 06, 2010 | Dryers
Tip
Gibson Dryer Belt Diagrams and Replacement
Style: Flat belt
My dryer is an estate model #eed440sq0 and when you hit the start button nothing happens.I tried putting it in a different cycle but still nothing could it be a faulty lid switch?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair ? The dryer will not start
heatman101
Aug 27, 2010 | Estate EGD4400SQ Gas Dryer
The belt has come off the dryer drum. I dont know how the tensioner goes back on
stick the belt pulley in the holes closest to the motor. if you have a belt pulley like this. get the belt and hold it together so you have a loop at the end and run under the pulley so the pulley lifts up and put the belt on the motor shaft. the belt always goes under the pulley so you are lifting upwards
Jun 21, 2009 | Dryers
Tip
Estate Dryer Belt Diagrams and Replacement
For models with non-removable back panels use this diagram:
Installation Tips: Ribs against drum
For models with removable back panels use this diagram:
How to get to the belt to put a new one on
To better assist you I need to know
what brand is your dryer n model n serial#
Thank you
May 20, 2009 | Estate Dryers
My whirlpool estate dryer tub will not rotate
To replace the belt unplug the dryer, remove the lint filter, remove the 2 philip head screws,with a stiff putty knife pry up in the top of the cabnet on the right and left to litf the top, disconect the door swithch remove the screw from each side and lift the front off romove the old belt the reinstall put new belt around the drum groove side toward the drum. put the idler pully in the slot closest to the motor be sure the tab is under the base and the 2 catches stit in the slot. now pull the belt through the idler pully and around the motor shaft. the reinsatll the front secure with the screws reconect the door switch,close the top, put the 2 screws back in where the lint filter goes then put in lint filter, plug in dryer and test.
Jan 19, 2009 | Estate EED4300SQ Dryer
Replacing dryer belt
  • Just like this but imagine the roller as being a semicircle.
put pressure on the tensioner with the belt and loop the belt under the tensioner to the motor.
  • this is a diagram for a whirlpool/kenmore/roper/estate dryer, i don't know the brand of dryer you have.
look here is more diagrams of different brands. http://www.repairclinic.com/0079.asp
let me know if you need more help Mike
Jul 04, 2008 | Dryers
Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Mar 25, 2008 | Estate TEDS740JQ Electric Dryer
Estate TGDS840JQ Gas Dryer Logo
144 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
