Question about Akai LCT3201TD 32 in. LCD Television
Unit powers on, but SOURCE button cannot change screen from VGA
LCT3201AD - Unit will turn on, screen says DVD :No Signal"; press SOURCE on the control or the TV and the screen says VGA "No signal". DVD player will not accept a disk
  • 35 Answers
Hi
You have main board problem and coast for you with shipping $130.00.But we do only exchange.Please look at our policy:
ATTENTION:
WE CHANGE YOUR BAD MAIN BOARD TO GOOD ONE.
OUR POLICY
1.YOU HAVE TO SHIP AN OLD MAIN BOARD TO US
WE WILL SHIP NEW ONE TO YOU BY USPS IN 2-3 BUSINESS DAYS.
2. PLEASE PAY TO PAY PAL BUY FOLLOWING EMIL ADDRESS:
alenooshki@yahoo.com 3. PLEASE SHIP YOUR OLD MAIN BOARD TO FOLLOWING ADDRESS:
GEORGES ELECTRONIC
769 GLADYS AVE
LOS ANGELES CA, 90021
PHONE: 213 627 4071
FAX: 213 627 3944
THANKS
GEORGE
Posted on Mar 17, 2009
I must have pressed the wrong button. my tv went to snow and there is a little tv going around the screen with run a channel scan written in it
see if the is an AV button and press that
it changes"the signal in" source n ( pay channel,free to air antenna, x-box, dvd, etc)
the snowy screen indicates no signal and the icon is suggestingn it is looking for a input source
Nov 06, 2016 | Televison & Video
No signal
Press the Function Button to open the short cut menu. Locate the Input graphic and press the button for it. Each time you press the button, it will cycle between DVI and VGA input jacks. Allow a few seconds for the display to switch inputs. Make sure that cable is connected securely to the associated jack in the back of the monitor and the computer (or other source). If either VGA or DVI input is selected ,but the VGA and DVI cables are not connected, a floating dialog box indicates:
"No Cable Connect" or "No Signal"
Your manual can be viewed here:
http://www.manualslib.com/manual/268264/Acer-S201hl.html#manual
Apr 07, 2014 | Acer S201HL BD Refurbished LCD Monitor
My power acoustik has a black screen and says no signal
If you have a DVD palying, Press the source button and see if the screen changes.
Aug 04, 2012 | Power Acoustik PT-852CM 8.5 in. Car...
DX-LTDVD20 Blank screen
Hi My first guess is your signal board.
You can get parts at www.interliquidparts.com
Dec 07, 2011 | Televison & Video
Acer d241H display plus mode shows no signal. I want to use the monitor stand alone. When i press the source key to change to display plus mode. the screen shows no signal. (the first time I powered on the...
I had the same issue as yours. After contacting the Acer support team, I got the response as follows. I tired and it worked.
"In order to resolve this issue, you may please perform a power reset. This will remove any static electricity stored in the hardware components that may cause the issue.
- Turn the monitor off and unplug the power cord and VGA cable from the monitor.
- Hold the power button on the unit down for 30 seconds.
- Release the power button and plug only the power cord back into the unit. "
Hope it helped.
Oct 30, 2011 | Acer D241H LCD Monitor
Akai 32" wide-screen lcd tv/dvd
Tramaine, I would suggest a new PSU. I have used ShopJimmy.com in the past with great success. Here is a link to the part you need on their site. Hope that helps! TeeVeeMan2
http://www.shopjimmy.com/megmeet-mlt168a-power-supply-unit.htm
Aug 18, 2011 | Akai LCT3201AD 32 in. LCD Television
Cannt get tv to change chanel
Check the mode the tv is on (Use "Source" button on remote to change modes). There are several modes to choose from.
Jul 16, 2008 | Akai LCT3201AD 32 in. LCD Television
Directed 9" Model OHD901 Power comes on, lights will come on, screen shows AV1 & AV2, but will not switch to DVD screen, and will not play dvd.
Preliminaries: (call Directed if these fail at 1-800-274-0200)
Make sure the disc format is supported - not HD, not Blu-Ray, and not an unfinalized burned disc
Make sure the lock switches are firmly in place
POWER—Power On/Off button, Source Select button. Hold for 3-seconds to turn power off.
Each press of this button cycles through sources DVD, AV1, or AV2.
or
SOURCE (MODE)
Press the (SOURCE) button on the remote or momentarily press the POWER button on the left
side of the LCD screen to select the input signal AV1, AV2 or DVD.
Manuf. reccomended troubleshooting:
DISC does NOT Play
Parental code is set lower than than allowed by the DVD mounted.
Ensure the disk is mounted in the player with the correct orientation (shiny side up).
The disk is warped.
The player cannot play certain formats (see the beginning of this manual).
The region code on the DVD does not match the player.
Moisture condensation has occurred within the player. Leave the unit on and the disc access cover
open and try again after about 30 minutes.
The disc has not been properly finalized (formatted) when recorded. Refer to your manual that came
with your disc authoring equipment.
May 23, 2008 | Televison & Video
Directed 9"Model OHD901: Power comes on, lights work, screen shows AV1 and AV2, dvd will not play at all
or
SOURCE (MODE)
DISC does NOT Play
The disk is warped.
Insignia is-lcdtv26 26", NO SIGNAL
This TV (Insignia) has been recalled (Model # : IS-LCDTV26) - Best Buy AS OF 04/02/2009 is STILL holding recalls for this TV due to fire hazards & power supply failure - the official report is here ->
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09183.html
Contact best buy's customer care hotline @ 800-233-0462 to get a gift card for upto $800 if you own this TV (Insignia - Model No. IS-LCDTV26)
Nov 09, 2007 | Insignia IS-LCDTV32 32 in. Television
Akai LCT3201TD 32 in. LCD Television Logo
91 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
