Question about Dell E151FP 15" Flat Panel LCD Monitor
Some letters (pixels?) fading out
Model #151FPb purchased used. Words have faded out letters (pixels?) Connected to Emachine computer. Old huge monitor worked perfectly. Also, brightness control doesn't work. Any fix? Or is this a sign I shoulda' bought new? thanks.
  • chickysue50 Feb 26, 2009
    Okay I figured it out myself. I had to reset the resolution in the control panel from 960x600 to 1024x768. That took care of the fading problem. (Though words were too small for me, so I had to adjust the fonts up to 120.) However, the brightness of the monitor still cannot be adjusted. Any ideas? Thanks.
gripfitter
  • 557 Answers
SOURCE: monitor works for a few minutes, then flashes gray
Replace the bad capacitors in the power supply. They are usually visually detectable (tops bulged). The ones that usually good bad in that model are 1000mfd. 16v.
Posted on Dec 08, 2009
SOURCE: 151FPb
One of my customers had the same problem. So last night, I took it apart and found a cold solder connection on a coil that had white goop on it. Goop is usually put on coils to stop oscillations. This is probably an inherrant problem. If you tap the back of the monitor with the back of a screwdrive, it should start working for awhile. Take it apart and take the shield off and do the same till you find the loose component. Don't hit it too hard. When you find the loose component. If you move the component back and and forth, it should work and not work. Take the board off and re-solder the component. Put the board back on and tap it lightly and see if you got the right component. If not repeat the proceedure until it works or pitch it...
Posted on Dec 17, 2006
  • 4 Answers
SOURCE: screen keeps fading
I don't know for sure if this will help but it's worth a try. Go to Start, control pannel, system, advanced, performance, settings, and click adjust for best performance. This is a Windows XP fix but the same thing may apply to older OS's (95, 98, 2000, ME, NT (although you may have to set it a diferent way). Many other things could be your problem but this is an easy thing to try.
Posted on Feb 04, 2007
WhIzAtIt
  • 136 Answers
SOURCE: faded color photos
HAve you tried uninstalling Canon's software and reinstalling?
Posted on Sep 15, 2007
zjut
  • 106 Answers
SOURCE: Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Posted on Jan 01, 2008
How can I fix my this ? Pixel colour fades on screan , though battery is fully charge , how can I fix this please?
some computers will fade the screen automatically when on battery power. on windows systems, you can change those settings (normally) by going to Control Panel -> Hardware and Sound -> Power Options -> Edit Plan Settings (beside the option in use) -> change advanced power settings -> Display (see screen shot)
Sep 14, 2015 | Samsung GT-N8013EAYXAR - 10 1 Galaxy NOTE...
Please help me with coming up with 4 letter words using the letters abcdefg and using the letters more than once
From a Scrabble anagram solver:
66: CABBAGED - B!
66: EFFACED - B!
64: CABBAGE - B!
64: DEBAGGED - B!
64: DEFACED - B!
64: FEEDBAG - B!
63: ACCEDED - B!
15: BAFFED
14: DAFFED
14: EFFACE
14: GAFFED
13: CABBED
12: BACCAE
12: BAFF
12: CAFF
12: DABBED
12: DEFACE
12: FACADE
12: FADGED
12: FAGGED
12: GABBED
12: GAFFE
11: ACCEDE
11: BACCA
11: BADGED
11: BAGGED
11: BEGGED
11: CADGED
11: DAFF
11: DECAF
11: FACED
11: GAFF
10: BEADED
10: DECADE
10: EBBED
10: FADED
10: FADGE
9: ABACA
9: AFF
9: AGGADA
9: BADGE
9: BEEF
9: CADGE
9: CAECA
9: CAFE
9: CAGED
9: CEDED
9: DEBAG
9: DEGAGE
9: EFF
9: FACE
9: FEEB
8: ABBA
8: ABBE
8: BAAED
8: BABA
[name of film pig]
8: CACA
8: CECA
8: DAGGA
8: DEAF
8: EDGED
8: EGGED
8: FAB
8: FADE
Mar 21, 2015 | Toys
Aoc led showing a line of faded pixels after regular intervals
i encounter this and found out that the signal from pc is the source of the problem and not the monitor itself mine is failing video graphics card
Jan 26, 2014 | Computers & Internet
Acer aspire 5738 screen fade
From your description, you may either have a bad cable to the LCD on your laptop or the LCD screen itself is going bad. I would guess a repair shop may charge $100-200 for the parts and labor, but you'll have to check your local area for price estimates.
Since your computer is nearly 3 years old, you may want to consider purchasing a new computer, especially since they start at $300-500 brand new.
May 19, 2017 | Computers & Internet
How to fix dead pixels
Cheaper to throw away instead of trying to fix, if green is fading the rest will soon follow, I gather it must be near 4 or 5 years old as this seems to be the life span, sorry I have no solution as even dead pixel fixers will not restore lifeless colour, this is usually worn out caps and backlight.
Dec 01, 2011 | HP Computers & Internet
We have recently printed and applied hundreds of asset sticker labels on our Dymo LabelWriter 450 and they have all faded! Is there a solution to this? or is the Dymo LabelWriter only useful for temporary...
LabelWriter labels are sensitive to sunlight. The coating is what allows to burn text onto them because LabelWriters do not use ink.
They are not supposed to fade easily so it may have been an old roll. Please contact our help desk for a resolution (see dymo.com for contacts).
^CM
Feb 10, 2011 | Dymo ® LabelWriter® 450 Series PC...
I purchased a gigaware keyboard from Radio Shack a few months ago. The lettering on the keys are fading away with every use. Many of the keys are totally blank by now. Radio Shack will not except it for...
Well if they would not replace your keyboard then I may suggest you buy a stencil lettering that you scratch. You can purchase this on school supply outlets. It has many sizes and fonts. After choosing the type of stencil, scratch it to your keyboard and top it with a clear nail polish gloss so that it would not fade whenever you're typing.
Sep 01, 2009 | Computers & Internet
Letters are fading hard to read
Buy a new keyboard. they are real cheap on line, try Newegg.com
You should find one for around $10 USD. Or, you can try cleaning the keys on the keyboard with rubbing alcohol.
Dec 22, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Won't print but few lines til black fades out
It pretty much sounds to me like you have "outdated" or old cartridges. Are you using the photo setting to print photos? Before you purchase more expensive cartridges do a head cleaning! Good luck.
Dec 16, 2008 | Dell 924 All-in-One InkJet Printer
Some letters on monitor are fading out
Some letters on monitor are fading out if there is no problem with card then it is due to monitor high voltage section failure. 1 there should be proper output from power supply. 2 focus control on flyback to be set. 3 crt base loose 4 or focus wire going to crt base not properly connected due to some foreign material deposited on it. 5 at last if monitor is old there is a possibility of crt getting weak.
Sep 24, 2007 | Gateway FPD2275W LCD Monitor
Dell E151FP 15" Flat Panel LCD Monitor Logo
549 people viewed this question
Alun Cox
