Question about HP Pavilion a1610n PC Desktop
Hard deive / non-system errod when running recovery CD's
I ran the recovery CD 1.1 and it created the recovery partition and the computer locked up...
i shut down and re ran the CD the system tries to create the recovery partition again and spits out the message--- hard disk error--
what do i need to do
    Novelist:
  • 121 Answers
My name is Armymason, have you thought about running a hardware diagnostic test? Do a search on the internet for a free one and check to see if the hard drive is bad.
Thanks,
ArmyMason
Posted on Feb 26, 2009
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.
There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :
(from http://support.gateway.com/s/Manuals/Desktops/8510406.pdf)
To restore system software from the Recovery discs:
1 Insert the Recovery disc #1 into the CD or DVD drive.
2 Restart the computer, then press and hold
R when prompted to display the restore process options. The
Options menu appears.
3 Select a restore process option:
- Press R to boot from the hard drive recovery partition
or CD. If no recovery partition is found, go to Step 4.
- Press F to format the hard drive and perform a full system
recovery, then go to Step 5.
4 Click a system restore option. For more information, see
"Restoration options" on page 5.
- Non-Destructive System Restore (Recommended)
- Full System Restore (Destructive)
- Full System Restore (with Backup) (Advanced Option)
5 Follow the on-screen instructions to complete the system
software restoration process.
Oct 29, 2013 | eMachines ET183105 PC Desktop
Tip
Creating a bootable flash drive
<p><b>Resolution:</b><br /> <p>The USB Flash Drive must be configured with an active primary MS-DOS partition. It must also contain the boot files. Follow the steps below to create a bootable USB Flash Drive. <br /> <p><b>Requirements:</b><br /> <ul> <li> Motherboard with BIOS that supports USB boot. <li> USB Flash Drive that may be erased. <li> Bootable floppy disk or CD with Fdisk and Format commands. </li></ul> <p><b>Directions:</b><br /> <ol> <li> Plug in the USB Flash Drive. <li> Make the USB drive the only bootable hard drive. <b>Method 1:</b><br />If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. <b> Method 2:</b><br /> Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. <b> Method 3:</b><br /> Unplug all hard drive cables inside the case. If the cables are unplugged the computer cannot detect and boot to the hard drive. <li> Insert the bootable floppy disk or CD into the appropriate drive. <li> Restart the computer to the bootable floppy disk or CD. <li> At the command prompt, type: FDisk. <li> Delete and create a new active primary DOS partition. <li> Use FDisk to delete all partitions from the USB Flash Drive. <ul> <li> In FDisk, press the 3 key to Delete partition or Logical DOS Drive. <li> If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition. <li> After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER. <li> A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER. <li> You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER. <li> The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu. </li></ul> <li> Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2. <ul> <li> In FDisk, press 1 to Create DOS partition or Logical DOS drive. <li> Press 1 to Create a Primary DOS Partition. <li> The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER. <li> The next screen prompts that the computer will now reboot. Press ENTER to continue. </li></ul> <li> Exit FDisk and restart the computer. <li> Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected. <li> At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER. <li> At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER. <li> Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\&gt; command prompt. <li> Change the settings made in step 2 back so that the computer operates normally again. </li></ol>
on Mar 14, 2011 | Computers & Internet
Tip
How Do I Correct the Error and Recover an Acer Computer hard drive?
In order to correct the hard drive partitions so the recovery program will work, you can use a variety of tools listed below.
1) Active@ KillDisk - Use their free killdisk program to wipe the hard drive clean off all partitions.
2) Ubuntu or another Linux alternative bootdisk. Create a boot disk for the Ubuntu Live CD and boot the computer from it. During the boot process it will ask to "Try Ubuntu without any change to your computer". This is the option you want. Once Ubuntu loads, find the partition editor program under the System, Administration menu..
To delete a partition, right click on the partition that you wish to delete and select "Delete" from the menu. Once you are sure that you've selected the correct partition, and are positive that you have backed up all the files or data that you wish to save from that partition, click the "Apply" button at the top of the Window, and the partition will be deleted.
3) Use the Acer Hard Drive Format Utility, on some versions of Acer computers when you have the option to create Recovery disks, the system creates a hard drive format utility CD as well. Boot from this CD and format the hard drive.
The utility will recreate 1 partition (C: drive), after the partition has been created, you'll be able to reload the HDD with the backup media. The file is an ISO image for CD media only (not compatible with floppy diskettes). Create a CD disc from the ISO image file using a CD writer program on another computer.
Once the hard drive partitions have been deleted by any of the utilities above, you can proceed with rebooting the computer using the Acer System CD and proceeding with the complete recovery of the system.
on Jun 25, 2010 | Computers & Internet
How to delete all my files and restore my acer 5336 aspire
Restoring from the Acer Aspire System Recovery partition is easy Most Aspires will have a second partition that can be used to restore if you do not have CD It is recommended that you make those CD when you first buy the laptop If you don t you run the risk of not being able to install Windows again if that second partition fails Restoring From The Acer Aspire System Recovery Partition Keep in mind that running the recovery will restore the computer to the way it was when you first brought it home Anything you added will be lost so make sure you have program disks passwords favorite websites photos, documents and anything else you need backed up before proceeding with the recovery of your Acer Aspire.Hard Disk Recovery should be enabled by default If it is not you may need to go into your system s BIOS by hitting F2 at boot and enable it under the Advanced tab Once Hard Disk Recovery is enabled, restart the system and hit ALT F10 This will begin restoring from the Aspire system recovery partition. You will be prompted to type six zeros as a security step Type 000000 to proceed You will then see a screen to select your Operating System. Do this and hit enter and the recovery process will begin You Cannot Use The Acer Aspire System Recovery Partition The process for restoring from the Acer Aspire System Recovery partition is similar with all major brand names The most important thing to remember is to always have backups of your data and take a few minutes to burn recovery DVDs using Acer s built in utility. Creating these backup DVD is vital If the hard drive fails you will not be able to perform a recovery from the Acer Aspire system recovery partition Create the media and store it in a safe place along with the rest of your software and computer documentation
Nov 04, 2011 | Acer Aspire AS5336-2524 Laptop
Format
How to partition and format the hard disk using the Windows XP Setup program loadTOCNode(2, 'moreinformation'); You can use the Windows XP Setup program to partition and format the hard disk. To do this, use the following steps: Step 1: Partition the hard disk loadTOCNode(3, 'moreinformation');
  1. Insert the Windows XP CD into your CD or DVD drive, or insert the first Windows XP Setup disk into the floppy disk drive, and then restart the computer to start the Windows XP Setup program.
    Note If you are using the Windows XP Setup disks, insert each additional disk when you are prompted, and then press ENTER to continue after you insert each disk.
  2. If you are prompted, select any options that are required to start the computer from the CD or DVD drive.
  3. If your hard disk controller requires a third-party original equipment manufacturer (OEM) driver, press F6 to specify the driver. For more information about how to use F6 to supply a third-party OEM device driver while the Windows Setup program is running, click the following article number to view the article in the Microsoft Knowledge Base: 314859 (http://support.microsoft.com/kb/314859/ ) Limited OEM driver support is available with F6 during Windows XP Setup
  4. At the Welcome to Setup page, press ENTER.
    Note If you are using the Setup disks (six bootable disks), the setup prompts you to insert the Windows XP CD.
  5. Press F8 to accept the Windows XP Licensing Agreement.
  6. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
  7. All existing partitions and non-partitioned spaces are listed for each physical hard disk. Use the ARROW keys to select an existing partition, or create a new partition by selecting the non-partitioned space where you want to create a new partition. You can also press C to create a new partition using non-partitioned space.
    Note If you want to create a partition where one or more partitions already exist, you must first delete the existing partition or partitions, and then create the new partition. You can press D to delete an existing partition, and then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this step for each existing partition that you want to include in the new partition. When all the partitions are deleted, select the remaining non-partitioned space, and then press C to create the new partition.
  8. To create the partition with the maximum size, press ENTER. To specify the partition size, type the size in megabytes (MB) for the new partition, and then press ENTER.
  9. If you want to create additional partitions, repeat steps g. and h.
  10. To format the partition and install Windows XP, go to step 2.
    If you do not want to install Windows XP, press F3 two times to exit the Windows Setup program, and then do not follow the remaining steps in this article.
    To format the partition without installing Windows XP, use a different utility.
Step 2: Format the hard disk and install Windows XP loadTOCNode(3, 'moreinformation');
  1. Use the ARROW keys to select the partition where you want to install Windows XP, and then press ENTER.
  2. Select the format option that you want to use to format the partition. You can select from the following options:
    • Format the partition by using the NTFS file system (Quick)
    • Format the partition by using the FAT file system (Quick)
    • Leave the current file system intact (no changes)
    Notes
    • If the selected partition is a new partition, the option to leave the current file system intact is not available.
    • If the selected partition is larger than 32 gigabytes (GB), the FAT file system option is not available.
    • If the selected partition is larger than 2 GB, the Windows Setup program uses the FAT32 file system (you must press ENTER to confirm).
    • If the partition is smaller than 2 GB, the Windows Setup program uses the FAT16 file system.
    • If you deleted and created a new System partition, but you are installing Windows XP on a different partition, you are prompted to select a file system for both the System and Startup partitions.
  3. Press ENTER.
  4. After the Windows Setup program formats the partition, follow the instructions that appear on the screen to install Windows XP. After the Windows Setup program is finished and you have restarted the computer, you can use the Disk Management tools in Windows XP to create or format more partitions. For additional information about how to use the Windows XP Disk Management tools to partition and format your hard disk, click the following article number to view the article in the Microsoft Knowledge Base: 309000 (http://support.microsoft.com/kb/309000/ ) How to use Disk Management to configure basic disks in Windows XP
Tanks. Cheer!
Mar 23, 2010 | Computers & Internet
Tip
Creating Bootable USB Flash Drive.
Requirements:
  • Motherboard with BIOS that supports USB boot.
  • USB Flash Drive that may be erased.
  • Bootable floppy disk or CD with Fdisk and Format commands.
Directions:
  1. Plug in the USB Flash Drive.
  2. Make the USB drive the only bootable hard drive. Method 1:
    If available, change the BIOS settings for the hard drive sequence, making sure the USB device is at the top of the list above all other hard drives. Not all BIOS Setup Utilities have this option. Method 2:
    Disable all hard drives in the BIOS. In some BIOS Setup Utilities you can disable the individual hard drives, while in others you will need to disable the controller. Method 3:
  3. Insert the bootable floppy disk or CD into the appropriate drive.
  4. Restart the computer to the bootable floppy disk or CD.
  5. At the command prompt, type: FDisk.
  6. Delete and create a new active primary DOS partition.
  7. Use FDisk to delete all partitions from the USB Flash Drive.
    • In FDisk, press the 3 key to Delete partition or Logical DOS Drive.
    • If there is just one partition on the drive, choose 1 to delete the primary DOS partition. If there are several partitions, the extended and logical partitions must be deleted before the primary partition.
    • After choosing option 1, the screen appears with partition information and a prompt for the partition to delete. Choose which primary DOS partition to delete, and then press ENTER.
    • A prompt appears to enter the volume label of the hard drive. Enter the label exactly as it appears on the top of the screen in the partition information. If the volume label contains gibberish or lowercase letters, the partition will have to be deleted as a non-DOS partition. Try using the option to delete a non-DOS partition in FDISK. After entering the volume label, press ENTER.
    • You are prompted if it should delete the partition. Press Y for Yes, and then press ENTER.
    • The screen changes to show only the total disk space and a line near the bottom that prompts that the primary DOS partition has been deleted. Press the ESC key to return to the main menu.
  8. Use FDisk to create a primary partition on the USB Flash Drive. The drive letter will be C:, since all other hard drives were disabled in step 2.
    • In FDisk, press 1 to Create DOS partition or Logical DOS drive.
    • Press 1 to Create a Primary DOS Partition.
    • The next screen prompts if the maximum hard disk size should be made into one partition. Press the Y key, and then press ENTER.
    • The next screen prompts that the computer will now reboot. Press ENTER to continue.
  9. Exit FDisk and restart the computer.
  10. Start the computer from the bootable floppy disk or CD with the USB Flash Drive still connected.
  11. At the command prompt, run Format by typing the following command: Format c: /s. Press ENTER.
  12. At the command prompt, run FDisk by typing following command: Fdisk /mbr. Press ENTER.
  13. Restart the computer without the bootable floppy disk or CD, and attempt to boot to the USB Flash Drive. If it works, it should go to a C:\> command prompt.
  14. Change the settings made in step 2 back so that the computer operates normally again.
on Mar 31, 2010 | Computers & Internet
Gateway laptop reset
Gateway Direct systems went "media-less" back in September 2004. In the event of a system crash users could either 1) restore their systems from the Recovery Partition OR 2) from the backup media that they were prompted to create on first power-up -- which would provide them with up to 5 blank CD-R discs depending on their system's configuration.
On the factory load of the hard drive, the recovery partition will not contain operating system files. It only contains application and driver files.
The first time the recovery partition is used, it prompts the user to insert their System Recovery CD/DVD to copy files from the CD to the recovery partition.
The Drivers and Applications CD is not bootable and does not contain Operating System files.
The System Recovery CD/DVD is bootable but does not contain any application or driver files.
If the end-user erases the hard drive and restores the computer using the System Recovery CD/DVD and an Applications and Drivers CD, the recovery partition is not recreated.
This means that you will need the operating system restore disc FIRST then the recovery partition will work for you
Mar 14, 2010 | Computers & Internet
Hard Drive Error during system recovery
You need to run a hard drive diagnostic disk in dos,(before windows starts) First check with HP, You can also use a program called HDD Regenerator 1.51. This will check the drive for bad sectors, and then you can try and repair them. This way you might
be able to see some of the data you want. If the sectors that where
repaired had the operating system on them, you should just get a new drive,(if not under warranty) then after you have a new OS installed on the new drive, you can plug in the old drive and see what you can recover.
Feb 25, 2009 | HP Pavilion a1610n PC Desktop
Application error when running recovery disk
hi
Did you create any partitions on the HDD?
Obviously the HDD or some partitions on the HDD are corrupt.
In my opinion, you should firstly try to format the whole HDD and delete also whole partitions.
Then insert the recovery CD and try to install the Toshiba image
villival
Dec 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Non installment of acer erecovery solution
eRecovery expects there to be both C: (system) and D: (DATA) partitions on the drive as well as the hidden recovery partition. If you use Disk Management to shrink the C: drive, and create the D: drive, things will install properly.
Oct 03, 2008 | Computers & Internet
HP Pavilion a1610n PC Desktop Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
