Question about GE 25952 Cordless Phone
I have 3 phones. All phones are charged. When an incoming call comes in, only the base set rings and allows you to answer the call - the other two phones do not ring nor can you use them to call out. Any suggestions?
    Sergeant:
    Champion:
  • 240 Answers
Go through the menu and check that the ringer volume is on. There is HS(handset) volume and BS(baseset volume). You may only have base set volume on.
Posted on Jun 12, 2009
Hit it onv the table and take the melecular valve out wet it then put it back in it should work after that
Posted on Jun 11, 2009
  • 385 Answers
Switch phone off at the mains 5 mins, reset them.
Or, Re-register the phones to the base unit.
should be good.
Hope this helps
Regards
Posted on Apr 19, 2009
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
Answering Machine Problem
You have not configured the phone. If you do not set the number of rings before switching to the answering machine, the phone rings ten times then goes to the answering machine.
Aug 20, 2014 | Panasonic KX-TG6441 DECT 6.0 Digital...
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
Jun 01, 2014 | Siemens Lands Phones
Phone does not ring
Time to get new phones. You incoming wires are not operating on the base of the phone. It is called the 'ring-side' or 'red' wire. Unless you know where the break is, you cannot fix it. because it happens on all the phones....it has to be broken in the base that serves them all. This isolation is furthered by the fact that a corded phone works fine on incoming calls, so it is not in the line to the building, broken on the ring side that is. Happy phone hunting!
blkqueentech
Apr 05, 2014 | Panasonic KX TG6511 Cordless Phone
I can not locate how to limit the number of rings; and the answering machine does not come on even after 20 rings; I can hear my message recording- when I play it back; but it does not come on for incoming...
Ring count You can change the number of times the phone rings before the unit answers calls. The default setting is "4 rings". "Toll saver": The unit answers on the 2nd ring when new messages have been recorded, and on the 4th ring when there are no new messages. If you call your phone from outside to listen to new messages, you will know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call.
1 {MENU} 2 {V}/{^}: "Answering device" i {OK} 3 {V}/{^}: "Settings" i {OK} 4 {V}/{^}: "Ring count" i {OK} 5 {V}/{^}: Select the desired setting. 6 {OK} i {OFF}
MANUAL http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf
HOPE IT HELPS GILES102
Jun 27, 2011 | Panasonic KX-TG1033S Cordless Phone
. Base unit Answer on
Lighted button you see may not be for ANSWER SYSTEM. Lights on Base units may indicate INCOMING MESSAGE already stored or all sorts of system ready lights.
Please do these three steps:
1. From the handset, Go to menu and set ANSWER system to ON once more
2. In the menu, set the number of incoming rings before ANSWER system turns on, to just 2.
3. In the menu, record a new message using your own voice.
then, Dial your own phone number from a cell phone to test.
Watch/listen as the incoming message is played. repeat any of the above if the system doesn't work.
Post a new question and include the model number and manufacturer of your system.
I work for a manufacturer of these machines and I can help.
S
Feb 22, 2011 | Cell Phones
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Answering macihne won't answer, disconnects after a few minutes
unplug your unit and allow it a few minutes to reset it's self. than call it using a cell phone and see if it does the same thing. If so check you menu option and make sure that the anserwing machine is not set up to only record for a certain period of time before disconnecting the call.
Aug 03, 2008 | Uniden TRU9485 Cordless Phone
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
Model 28112ee2-4 dect 6.0
For the handset, you can use the menu button to check the HS Setup settings. For the answering machine, you may have pressed the side button that turns it off. It would say "off" on the lcd if you did that. According to the manual (I just bought one of these).
Dec 21, 2007 | Uniden Cordless Phone
GE 25952 Cordless Phone Logo
151 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
