Question about HP OfficeJet G85 All-In-One InkJet Printer
Color ink cartridge HP Officejet G85
I have installed a new color cartridge and it continues to prompt that it is intalled incorrectly. I have replaced many cartridges before without this problem
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 90 Answers
Clean the copper contacts with soft cloth...
Posted on Feb 25, 2009
How do I install my ink cartridge for a hp officejet 4215 all in one
Turn on the HP printer. Lift the printer cartridge door, which is the right side of the printer, revealing the black and color ink cartridges. Push down on the front of the cartridge you need to replace and pull it out slowly. Unwrap the new ink cartridge and peel off the tape. Insert it at an angle into the cartridge slot. Apply gentle pressure until it clicks into place. Close the cartridge door and press "OK" when prompted.
References:
HP User Manuals: HP Officejet 4215
Hope this helps you :)
Mar 07, 2012 | HP OfficeJet 4215 All-In-One InkJet...
Cartridse error
If you see a message saying that you have an incorrect ink cartridge, a flashing cartridge light meaning a bad color cartridge or you are told to remove the color cartridge, you should follow these steps to correct the problem if you are sure you have installed the correct color ink cartridge.
Instructions
Reinstall the ink cartridge
1. Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
2. Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
3. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
Wipe down the cartridge contacts
2. Remove the cartridge an use a clean, lint-free, dry cloth to gently wipe the contacts.
3. Wipe from the top of the contact to the bottom. Do this for each contact.
4. Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
5. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
Reset the Officejet printer
1. Turn on the HP printer.
2. Unplug the power cord from the back of the printer and wait one minute.
3. Plug the power cord back into the printer. Press the on button and hold until printer turns on.
4. Print a test page to see if this has fixed the problem. If not, you will need to buy a new color ink unit.
Jun 04, 2011 | HP Officejet 5610 All-In-One InkJet...
HP G85xi remove and check color cartridge message
Hi you can remove your Printer cartage and look see
ink points (dots) you can erase ink point and reattach your cartage your printer its Ready to use.
Jul 06, 2017 | HP OfficeJet G85 All-In-One InkJet Printer
I have purchased several color cartridges this past week for my HP Officejet 85Xi and I keep getting the message to remove and check color cartridge. I do that and I've even cleaned it with a damp towel....
Did you remove the seal from the cartridges before you put them in? Double check each cartridge. Are these genuine HP cartridges? Many people believe you can substitute 3rd party cartridges or fill the original with brand X ink. My experience has been such that I will not waste my time with non-genuine cartridges.
Thanks for posting your question at FixYa.com
Dec 23, 2009 | HP OfficeJet G85 All-In-One InkJet Printer
Cartridge
Easy! Just open the front latch by lifting up, unlock the cartridge you are replacing, and snap in a new one. I caution you to use only HP new cartridges for best results. You can find a pretty decent price on them at www.amazon.com. Also, reset your ink counter in the HP Image Zone to reflect the new cartridge install. Then run the align cartridges option and you're all set. Hope that helps. If so, please rate this solution. Thanks!
Sep 13, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
HP G85 All says remove and check color cartridge and prints only green/blue color
This is a known issue on this machine. What I do is open the printer as if replacing the cartridge and allow the cartridge holder to move to the exchange position. Then I unplug the power cable from the back and close the printer again. Keeping your finger on the power button, plug in the power cable again. Keep the button pressed for about 10 seconds, allowing the error flag to reset. Switch on again and wait for the initialise to finsh. It sometimes takes another 5 minutes for the message to disappear but it should go eventually.
Mar 06, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85
If its not recognizing the cartridge you probably need to go inside and clean the contacts. Best thing to use is ordinary rubbing alcohol but you should also get a can of dry air from best buy or similar place to blow out any areas you can reach. If you need instructions on how to take the machine apart email me at sanglemyer36@yahoo.com
Feb 19, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP OfficeJet G85 All-In-One InkJet Printer Logo
319 people viewed this question
Ben Johnson
