FixYa.com
Tags:
Brother HL-5250DN Laser Printer
Brother HL 5250DN Problem
By Duke - usenet poster
xp Home, 768 M memory, 2.6 Pentium 4. Bought above printer but had no
USB 2.0 so bought 2.0 card + cable. Loaded drivers for both new USB
card(xp compatible) and printer following instruction order exactly.
Got found new device BUT also not recognize USB device when trying to
print. So, attached USB 1.0 cable to test printer. Worked fine but
with "you can go faster" message. Plugged another device into unused
port on new USB card, worked fine. Wa the hay! Both ends of cable
connection(printer and computer ports) seem to be working but no USB
2.0 printing. Took new USB cable + printer to computer with built-in
USB 2.0, worked perfect. Cable is OK. Help please.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 02, 2007
FixYa! (100)
Joey2
Joey2 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
This sounds like a problem with the USB card, since I think I understand
that the printer is ok when connected to a USB port built into the
computer. If it were a USB hub you were using, I might suspect that it
needs an AC adapter, since some devices need it, but if it's an internal
PCI card, this wouldn't be an issue. Check the website of the card
manufacturer for tips and see if they also offer tech support.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Printers problems?
Print Size Problem
My HL-5250DN seems... Answer This...
printer ink faint or not at all
The brother printer has no... Answer This...
Re:Will not print
Red status light and toner... Answer This...
I dont see anything
The paper is bright yellow...I... Answer This...
HL 2070 Printer Toner light...
My brothers laser printer is... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
