Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need true chain/bar size for my husqvarna Model 254 chainsaw
This saw runs sluggishly when in hard timber. Not sure the size bar/chain are original. What is recommended?
  • lfoster01 May 11, 2010
    Can you supply the model number, have you tried a full chisel type chain for hardwood?
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Posted on Mar 16, 2009
What can be done to stop leaking oil?
Gary, not sure what oil you are talking about for sure, if it is chain/bar oil it is suppose to leak/lube chain while it is running.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://familywoodworking.org/forums/showthread.php?9424-Are-chainsaws-supposed-to-leak-oil
Husqvarna chain oil leak repair 346
Husqvarna 254 Chainsaw Bar Oil Leak Repair How To Remove Clutch
May 25, 2016 | Garden
Tip
Sharpening Chainsaw
Whether you learn to do it by hand or buy a saw sharpening attachment keeping a sharp chain is #1 in my book for keeping your saw running properly. The more pressure you have to exert to cut makes the saw run hotter, the bar wears out faster, the chain wears out faster and the sprocket wears out fast plus it's just plain harder on you to run the saw. In my timber cutting days I would file my chain every time I filled the saw with gas. Here is a helpful video for sharpening a saw. http://www.youtube.com/watch?v=lkSYov5jcO0
on Dec 05, 2009 | Garden
When I use my chainsaw the chain alway's comes flying off - please advise
not know what kind of chainsaw a fix maybe hard to do but here goes
1. be sure chain is right size for bar as in bar groove for chain right size, sprocket gear right size and chain right length for bar.
2. be sure bar is adjusted for length of chain and tighten bolts to hold bar in place
3. always have sharp chain teeth
be careful if still happening -- may be better to buy new saw
Mar 04, 2015 | Garden
Troubleshooting chainsaw
Sadly, the 3816 is not designed for larger timber. 38cc is only for smaller limbs, As a general rule also the largest timber to cut should only be 2/3 of the length of the bar
Jul 27, 2014 | Poulan/Pro 3314 3416 3816 3818 40184218...
Husqvarna 51 file size
Several bar and chain combinations fit the 51 model saw. If your saw runs an H46 / H80 or H81 style chain you will need a 7/32" (5.5 mm)
If you are running a H21 style chain you will need 3/16" (4.8mm)
May 02, 2014 | Husqvarna Chain Saw Models 51, 55
Help desk number
3/16
Click on the image by CHAIN TYPE to enlarge. All file sizes are shown.
Jun 28, 2013 | Husqvarna Garden
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
254 husqvarna chain saw mixture and plug gap
Plug gap 0.5mm, fuel oil mix 50-1 with Husqvarna two stroke oil, or 25.1 with other makes of two stroke oil as the quaility is not known
Jun 14, 2012 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cannot keep chain tight
Chain stretch is usually caused by inadiquate oil/ or incorrect oil to the chain, aim the tip of the bar at a clean peice of timber, you should see a good line of oil spray from the tip of the bar onto the timber.
Very dirty or dusty timber will also dry the oil out on the chain, and cause chain stretch.
Feb 24, 2011 | Husqvarna Chain Saw 20" Bar
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
854 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
