Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
My dishwasher seems to run for 7 hours each time. What to I do? It seems to go through all the cycles and gets stuck at 1 minute for hours
  • 1 more comment
  • MR123 Mar 11, 2009
    I got the same problem. Mine is only 3 years old and the program was messed up. In a 2.5 hr programme, it only allows the last 30 min for rinsing and no drying at all, sometimes stuck at the last 1 min. The dishes are wet and slimy. I have tried to change the setting to intensive drying but no use. I wonder if I can get a new chip or something for the programme - not sure how much it would cost and how easy to fit. Can anyone help please?
  • denton777 Mar 28, 2009
    I have the exact same problem. Is the heating element gone out? If so, where do I get another one?
  • amccarthyb May 10, 2009
    Ours runs very long and also sticks at 1 minute for hours. The manual states that it is probably due to cold incoming water. It states to run the hot water in the sink then turn off and start the dishwasher. I'm leary b/c we have the recirculating hot water and it should be hot no matter what. I will try this though.
There is well known problem for this model and I had it as well:
On the control board the relay contact's soldering heated up and didn't provide contact, so the machine couldn't heat. Therefore the cycle became loooong!
Right now I am experiencing a faulty relay: it switches 3 times out of 5.
So I think to change it. Unfortunately the relay is rated for max. 10Amps, which is the working current for the heater. No wonder, that after 12 years it starts to "cough".
Posted on Feb 16, 2012
  • Bosch Master
  • 3,361 Answers
You must correct the water temperature problem. The water is not hot enough.
Posted on Feb 26, 2009
Dishwasher runs too long
Good Morning Tessa,
I understand that your Frigidaire dishwasher, model# FDB700BFC, is running too long. I also see that it seems to be getting stuck on one particular cycle and runs continuously for hours even though the water is hot. It sounds like there is possibly a miscommunication between the different boards inside your appliance. I please ask that you try resetting your dishwasher, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
Maytag jetclean eq plus mdb9150awd Stalls at 68 min
Could be defective timer. The diagram might be on the back of the machine - out of sight, out of mind
Jul 24, 2013 | Dishwashers
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
Dishwasher will not run through its cycle
Hi
If the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
2H displayed and pump runs nothing else happens
I would check the buttons on the control they may stuck. check the delay button..
Dec 21, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Whirlpool gold dishwasher gets stuck at 53 minutes left for an hour
Try "resetting" the control board by running the diagnostic cycle. The cycle completes in 15 minutes.
The details are in the service manual. The manual can be found hidden behind the tow plate (at the very bottom front of the washer).
The diagnostic cycle may tell you the problem. It also helps clear up some of the software gltiches.
It is easy to run the diagnostic cycle.
Just the buttons in the following sequence. The sequence should be complete within 6 sec.
heated dry -> Normal -> heated dry -> Normal
This will trigger diagnostic cycle of 19 intervals. Pay special attention to the intervals 18, 17, 9, 6, 4.
Interval 18 - displays your controller module number (should be letter 'd' followed by number 0 or 1 or 2 or something. Note that down for future reference.
Interval 17 displays 'software generation number' Note that down for future reference.
Then wait until you reach interval 9.  --- clean LED turns on - then an open or shorted thermister is detected.
-- Sanitized LED turns on - then the washer detected greater than 100 deg F temperature
Interval 7
-- Soaking/sensing LED should NOT come on (unless food soil is present).
Interval 4 -- Soaking/sensing LED should come on
Let the cycle complete and then try running the normal wash. Hopefully the possible glitches are cleared by now and you should have no problem.
If this doesn't work, time to call the expert tech.
Nov 08, 2008 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch dishwasher
I had similar problem. Would run for many hours and then not quite dry. I replaced the control module and all is well now.
Apr 19, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Stuck on last minute
I have seen a lot of these dishwashers burn out the control board, and usually the symptom is the timer not working or inability to complete a cycle. Most of the ones I have seen, you can remove the control board assembly and its pretty obvious where its burnt. If you can do the repair yourself, the board is about $150. Hope this helps!
Oct 26, 2006 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
380 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
