Question about Dell Ethernet Card Network Adapter
Would like to know how to access the NIC information I currently have on my desktop.
  • Chuck May 11, 2010
    what do you mean. IP information or hardware information
    Scholar:
  • 85 Answers
If it is the hardware information do you know how to get to a command prompt via start button then run (in XP) or just type in at bottom at start button on Vista. type this in and hit enter. devmgmt.msc now open this up it is called device manager. now scroll down till you see network adapters expand this now you will see all network adapters installed just right click the one you want and hit properties. i hope this helps
if it is the ip address and that info let me know i was unsure of your question.
Posted on Feb 25, 2009
I HAVE NO MORE WARRANTY ON MY GIFT. THE OWNER WANTED TO GET RID OF THE PC SO I GOT IT AND HE SAYS HE DOES NOT HAVE THE VISTA SOFTWARE NOR THE PASSWORD. SO I INSTALLED A WINDOWS XP ON ONE OF THE PARTITIONS...
Hello nfor2
Sound drivers are free . You just need to identify the soundcard and go to the manufacturer's site and download the driver . Maybe you can access the recovery data on one of the partitions . You will find the driver there .
Apr 21, 2011 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
Having lan card problems what does it affect how much does it cost to replace and fix
C521 LAN card is integrated in MB.
You can Flash the BIOS to most current and load the latest driver (Support.dell.com) see if the card works, next I'd reset BIOS defaults, and try again. If NIC will still not work, it may be damaged. Turn it off in BIOS and replace with a PCI NIC
http://cgi.ebay.com/Xinruilian-Fan-92mm-Ball-Bearing-2pin-4pin-PSU-Power-/200552830688?pt=Computing_ComputerComponents_Fans_Heatsinks_SR&hash=item2eb1e156e0
Jan 14, 2011 | Dell Dimension C521 PC Desktop
One of my computer will not connect to the internet when hard-wired through this router. Others do work and the wireless works flawlessly. The computer in question runs XP and can communicate with the...
1. There may be 3 issues here to consider 1st :
a. the network card \
b. the Ethernet cable
c. the Ethernet port on the router defective.
2.Here is a instruction set to follow to see if your router is connected properly with the said pc :
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or firefox) on the computer that doesn't connect.
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop/desktop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. use a straight through Ethernet cord ( a know good one )\
8. verify that the network card is working by using a loop back ( that is ping the NIC card ( done by using dos command prompt>> loopback address is 127.0.0.1 this should yield 4 hops complete if the NIC card is working ( NIC = Network Interface Card)
I hope this helps. Have a great day!
This is for all routers to set up wirelessly.
Aug 23, 2010 | SMC WBR14-N Router
Fujitsu Siemens GA-8ISXT-FS, can I add a 2nd ethernet card / NIC
The P/N GA-BISXT-FS is a Gigabyte mother board which has 5 availble PCI slots.
If you don't see any open slots, chances are that all 5 of the slots are already in use.
Take a look and maybe you can pull out of the cards you don't need and install the 2nd NIC card.
Good Luck and let us know how it works.
May 26, 2010 | Fujitsu Siemens SCALEO 600 (FSP:83C005617)...
I have a Gateway E1600-SE with Windows 98 OEM
You will need a driver for your specific NIC (Network Interface Card) that will run on Windows 98 second edition (this is important. If you dont have 2nd edition, you will need to find it somewhere. I would suggest Craigs List or e-bay). Your Default adapter is unknown to me so I cannot send you to a manufacturer site. However, that information and driver should be available at www.gateway.com/support as well as the NIC manufacturer.
Don't know what the device is? Check your Device Manager in "My Computer" / properties - select device manager
Another avenue you can travel is go for a visit at www.pcpitstop.com and have a free test performed. Of course to do this, you have to have a NIC with the proper driver already! I mention this because after you get this NIC going, you can visit the site and they will tell you whether you have the most current driver for your system or not.
I hope I have helped you with your trouble this evening.
Thank you for considering FixYa.com
Please vote
thanks
a
Dec 04, 2009 | Gateway E-1600 (DE1600-1928523) PC Desktop
I can't see my nic card to access the internet I loaded windows XP professional
The only option is to download the driver from another system on a USB drive or CD etc, then load the NIC driver on the system.
Since you didn't list the brand and model, we can't give you suggested downloads.
May 06, 2009 | Computers & Internet
Need windows 2000 server nic driver
Hello sir,
Try this link for Windows 2000 server.
http://www.opendrivers.com/driver/212753/3com-etherlink-server-nic-3c985-3c985b-driver-
windows-2000-free-download.html
Best of Luck
Don't forget to rate the solution.
thanks
Mar 11, 2008 | HP Compaq d220M (829160054797) PC Desktop
Limited or no connectivity
I have just a few questions in order to assist you! I hope this ok?
What type of PC are you using? Desktop or Laptop?
What type of Router are you using? Linksys, D-link, Netgear, Internet Service Provider, verizon, at&t, comcast? What type of Modem? I just need more information in order to help! Let me know I will assist you!
Nov 28, 2007 | EnGenius EL-2611CB5+ (NL2611CB5)
Dell Ethernet Card Network Adapter Logo
69 people viewed this question
Alun Cox
