Question about Arrow 8000 Power Shot Pro Staple & Nail Gun
There is a Stanley bostitch model B2000 stapler in my classroom. I need to fix the spring that advances the staples and holds them in place! wehre do connect the spring?
The person that asked this is probably long gone, but in case anyone else comes across this... I had the exact same problem when I dropped this same stapler today and the spring came out. After examining it for a bit, I realized where the spring had to go and fixed it.
Open the stapler the same way you would as if you were replacing the staples and look at the top piece, towards the back. There will be an elongated black hook here to attach one end of the spring. The trick is where you route the spring after that... look towards the front end of the same top piece, and you'll see 2 holes in the metal. You need to push the spring up through the first hole, then pull it back down through the second hole (you may want to use a straightened paper clip to snag the spring so you can pull it through that second one), and only then do you attach the other end of the spring to the hook in the sliding metal piece that advances the staples in the staple holder.
And that's it!
Posted on Dec 10, 2011
Why doesn't it work?
The spring that advances the staples may be disconnected, damaged, weak, or broken.
Mar 22, 2016 | Stanley Bostitch P3-chrome Stapling Plier
Open and load staples b660
Hold on to the chrome part near where the staples come out and lift up on the top plastic part. There is a video link on the Bostitch site to the right midway down the page
Stanley Bostitch No Jam Premium Stapler B660 Black
Feb 08, 2015 | Stanley Bostitch B660-BK: NoJam Full Strip...
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
There is a spring to push the staples into place. Bostitch was purchased by Dewalt and moved their parts lists to the web address below. Enter your model number and order the parts needed. Good luck with your future projects.
Sep 02, 2010 | Stanley Bostitch STB-MIIIFS Flooring...
How to remove staples from bostitch T5 model only to change type of staples
Lift the hinged guard on the front of the stapler and while open use a pencil or similar object to depress the striker (above the staples). This will release the spring catch and the staples will move forward. Use caution and catch the staples as they come out under spring pressure.
Jul 28, 2010 | Stanley Bostitch HP118K 23 Gauge Headless...
I have a model B310HDS heavy duty stapler and the spring mechanism broke on the end. Where can I find the replacement part? Thanks
what you are looking for what they call a pusher assembly.
Bostitch company uses Amex(SP?) for their replacement parts.
The phone number is 800-343-9329
Jul 21, 2010 | Stanley Bostitch 00540: 00540 AntiJam ?...
B310HDS Stanley Bostitch stapler rod to lock stapes has plastic t
I have the same problem and have found no answers from Stanley Bostitch customer service. They redirect to a telephone number that does not answer.
Solution: Don't buy Stanley Bostitch.
Jun 03, 2009 | Stanley Bostitch 00540: 00540 AntiJam ?...
How do the staples stay in place in my stanley 1/4" stapler? They slide back and forth and therefore aren't in place for the stapler to work?
There should be a pusher that is attached to a spring. If the spring broke, or the pusher is missing the staples will not stay in place.
If you can locate a model number on the tool, you go to to find the parts you may need
Apr 18, 2009 | Stanley Tools Staple/Brad Nail Gun
Arrow 8000 Power Shot Pro Staple & Nail Gun Logo
1,833 people viewed this question
Top Arrow Tools & Hardware - Others Experts
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
