Question about Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television
Bad color scheme - cannot adjust enough
We got a used 45 inch projection samsung tv model hcp4741w the color is bad skin is reddish cant adjust with remote how much could repairs be?
  • 121 Answers
If you haven't already done so, it may be that all you need to do is adjust the convergence after moving the set. You should find convergence and its adjustments in the setup menu
Posted on Feb 25, 2009
My Samsung's picture is starting to fade and all the colors are turning a reddish color. Does this mean I need to change the lamp? I just did that about 6mos ago. What now?
with TV on bring up the menu. If the menu screen is NOT affected, the DMD board should be fine. It menu is affected, DMD board is likely the reason.
Also check the color wheel, sometimes when they are going bad they will translate the wrong colors or even make a loud pop and shut TV down. If the bearing is going bad on color wheel, it can make a grinding/squealing kind of noises and sometimes even make the TV vibrate.
Im not a TV specialist. Just trying to help with what I have experienced with this set.
Feb 27, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
HDLP50W151 50 in. Rear Projection HDTV Television: have a 48 inch rca projection tv and the picture i...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
I have a 57 inch rear projection t.v. the color looks 3d and the screen looks warped. the t.v is about 10 years old but i would like to fix it myself if i can. please help.
  • Screen looks 3D
May 15, 2010 | Hitachi 53UDX10B 53" Rear Projection...
I have a 65' Samsung model #HCN-653W rear projection tv... just recently the picture became distorted as if watchingsomething that is 3D... Is it a tube or something that I can replace with out getting to...
  • Screen looks 3D
Feb 23, 2010 | Samsung PCL541R 54" Rear Projection...
The colour on my TV is a reddish colour. Have tried the colour adjustment. Skin colours in particular.
simple. easy. you have 3 screen adjustments. red green blue. turn color all the way down. you should then get just a black and white picture, but in your case, it will still be reddish. behind the speaker grill is an access panel for screen adjustment. remove speaker grill. remove access panel. you will see a block assembly roughly 6 inches square with 6 knobs on it. 3 are for screen, 3 are for focus. adjust until you have a black and white picture. then go into menu and turn your color back up. enjoy!
Nov 14, 2009 | Televison & Video
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Color is distorted. Green, red, and blue ghosts
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Jul 15, 2009 | RCA P52950 52" Rear Projection Television
Picture is distorted w/ aline on top and bottom
  • Screen looks 3D
Jan 30, 2009 | RCA HD65W140 65" Rear Projection...
Samsung 6768W DLP 2 yrs old Replaced lamp and now color is off Faces look like paint by number
possible solution:
http://www.avsforum.com/avs-vb/showthread.php?t=1050735
  1. You may need to adjust the index delay after the replacement. You will be able to tell because you may see strange color banding in any scenes that have colors close, but not quite the same, in tone. This is usually most obvious in face skin tones (i.e. “clay faces”). If you need to adjust index delay, turn off the set, wait for the lamp to cool down, then hit mute-1-8-2-power in succession. The set should turn on with the service menu popping up eventually on the left. I don’t remember which submenu “index delay” is under, but find it and usually it will need to be lowered. I believe mine started out in the mid-50’s and had to be lowered to 47. These numbers are different for each Samsung model, so just adjust until the picture is pleasing to your eye. By the way, the supposed “correct” way to do this is to make the reddish part of the test color bar appear the “most saturated”, if you have a color calibration device.
Oct 15, 2008 | Samsung HLR6768W 67" Rear Projection HDTV
Samsung HC-P4741W 47" Rear Projection HDTV-Ready Television Logo
382 people viewed this question
Jerry Greenberg
Jerry Greenberg
