Question about Whirlpool LEQ8000JQ Electric Dryer
Kenmore gas dryer heats some of time MD
Kenmore gas dryer heats some of time MD 110.7496230
  • Anonymous Mar 23, 2014
    Model 970-339941
  • 833 Answers
Is the drum turning and are you getting a flow of air out of the exhaust pipe? These two items may assist you in finding the problem. Look next at the thermostat if these items are working right. Have you checked the area below the lint filter for buildup of lint?
Posted on Feb 25, 2009
Kenmore gas dryer no heat, have cleaned all components with shopvac and rags, still no heat, spins and all seems good, geta little warm once out of every 30 times i turn it on, any idea's?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 03, 2011 | Kenmore 73102 Gas Dryer
My kenmore 80 series gas dryer heats sometimes, but other times wont heat. I can see the flame when it does heat. I replaced the thermostat. It seems to heat when it has been sitting unused for a long...
heatman101
Jun 25, 2011 | Kenmore Dryers
My maytag MD-1 dryer will heat at times but latley has not heated, had tech check the heating element and it was okay, it was working okay when he left , but now want heat,what to check? the dryer is 4...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 28, 2010 | Maytag PYE2300AY Electric Dryer
Kenmore Elite model #110700932990 dryer has no heat
My experience has been that most of the time when a gas dryer does not heat, that the igniter has gone bad...
The other less common problem is that the coils of the gas valve go bad...
Other problems can be the thermostat, the high limit, or the thermal fuse going bad...
Here is a tip that I wrote about not heat in gas dryers...
gas no heat tip....
heatman101
Nov 23, 2010 | Kenmore 74642 Gas Dryer
Kenmore Gas dryer won't stay on
in the control board you should have a motor relay and a heat relay,they are the same part you can swap it out with the heat relay to see if that's your problem or you have an even heat board in there that's bad,next time send model number
Mar 12, 2010 | Kenmore 73952 Gas Dryer
May gas dryer is not heating
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
789hj
Jan 18, 2010 | Maytag Neptune MDE4000 Electric Dryer
Gas kenmore dryer
It could be a couple of things, but I would start with the flame sensor. Different models work differently.
Jan 03, 2010 | Kenmore 74962 Gas Dryer
Kenmore gas front load dryer.Very little heat, takes 3x to dry
Check your heating elements. check the outside exhaust door is it open.
Feb 20, 2009 | Kenmore 93142 Gas Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
KENMORE GAS DRYER - MYSTERIOUS HEAT PROBLEM
Most times I replace the coil assy. on gas control valve. OR could be the sensor.Or both.
Nov 27, 2007 | Kenmore 73952 Gas Dryer
Whirlpool LEQ8000JQ Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
