When i turn on my computer everything comes on but my hard drive and cd rom i have tried changing cables and when then computer is on if i unplug the flat grey cables they will turn on but when i reconnect them they dont work
  • Anonymous Feb 26, 2009
    the hard drive is fine when i turn on the computer the cpu fan that is attacked to the mother board comes on and so do all the lights but nothing happens while the computer is still on i can unplug the flat grey cables from both the hard drive and the cd rom drive and then they start to spin but when i hook up the grey cables again the drives stop if i take the tower out side and let it get really cold then bring it inside and try to turn it on it come on fine but i turn it off and try turning it on again it does what it did before i think there is a problem witht he mother board but not sure because the other fans attached to it work
  • Tim Crosslin May 11, 2010
    What do you mean everything comes on but the hard drive and the cd rom? Does the computer boot to Windows or the operating system? Did you unplug the cables while it was on? How do they turn on when you unplug them? And not if they are plugged in? Sorry so many questions.
    President:
  • 2,692 Answers
Sounds like the hard dribver may be bad. Their are site to download software that wil check a hard driver without windows,just for a disk.  Try:  seagate.com  for seatools, for example to check the hard drive. The other possibility is that the gray flat cable is upside down or damaged or that the cable socket is. Another thought . You do have the hard driver turned on in the BIOS setup screen,corrct. In other words, this is somethng that just hapened to a working computer w/o any changes made by you.
Posted on Feb 26, 2009
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
My dri8ve will not open and close with the push of the button.
Hi. if you are using a cd rom that dosnt open and close. try the following. unplug your HDD cable to the hard drive. just use cd rom. if cd rom open. you must use a separate cable. if problem continues then you must take cd rom to the nearest Computer electrical expert to fix.
good luck
Nov 11, 2010 | Computers & Internet
My computer recently stopped recognizing my Western Digital external hard drive. I tried everything and nothing seemed to work so I figured it was the ciruit board. I removed the hard drive and opened up...
Unplugging the CDROM didn't cause this issue but installing the western digital on that cable did cause your drive numbers to change in BIOS. You need to disconnect the external hard drive from the SATA cable but leave the power connected,then boot windows. Once booted reconnect the SATA cable. Check and see if it shows up in your disk management utility.
To do this, right click on computer, then left click manage. When the management console opens, click Disk Management on the left side and scroll down through your drives. Let me know if it shows up and what it says about the partition on the right, I'll keep my eyes open for your reply.
Chris
Oct 05, 2010 | Western Digital Computers & Internet
My TS-H653N CD Rom device does not work. What do
Buy a new one and replace it. Follow this tutorial on how to do it:
1. shut off your computer.
2. Unplug the power cord from your computer and the rest of the wires from the back of the computer.
3. find a sturdy flat surface on which to work on
4. unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
5. open your computer up by taking the side panel off, or sliding the cover off.
6. unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
7. unscrew the 4 holding screws on both sides of the cd-rom drive.
8. now, you just have to remove the cd-rom drive, carefully by sliding it either forward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
9. Do everything in reverse to install a new one.
Jul 19, 2010 | Compaq Presario 5000 PC Desktop
Failed to boot, i cant even get to the bios! only the fan running, led(green) and (red) indicator doesn't even light.
Dear Client, unpluged all the data cables, power cables or wires, bios cell and RAMs. Everything should be unpluged from the motherboard for two hours and then reassmbled. It will work properly but when you reassembled it just plug with the follwing devices.
* Power Cables
* Data Cables
* Bios cell
* Processor + Fan
* RAMs
Do not attach CD-Rom or Hard Disk, just turn on the computer without Hard Disk and CD-Rom and try to enter in bios setup. I assure your problem will be solve. Now you can attach the CD-Rom and then try to boot up from the CD-Rom and in the last you should try to attach Hard-Disk. I hope you will do it step by step and get success.
Good Luck
Feb 14, 2010 | Asrock 775i65G Motherboard
Replace the disc drive on hp pavilion notebook
1. First of all, you need to shut off your computer . To do this press the power button on the front of the computer after you have shut it down from Start> Shutdown on your start menu.
2. Unplug the power cord from your computer. This is the big black/white/grey plug that plugs into the power supply on the back of your PC.
3. Unplug the rest of the wires from the back of the computer.
4. Find a sturdy flat surface on which to work on.
5. Unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
6. Open your computer up by taking the side panel off, or sliding the cover off. It might be difficult but it will come off if you have taken all the screws out.
5. Now before touching anything inside, it is a good idea to hook up to an anti-static wrist strap. If you dont have an anti-static wrist strap, just touch the side of the computer where it is metal to deshock yourself. Then when you touch the inner components you wont risk damaging any of them.
7. Find the CD-Rom drive, it should be about 1.5 inch thick 5 inches wide, and 6 inches long. Unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
8. Once you find the CD-Rom drive, find the screws holding it onto the chassis. unscrew those screws on both sides of the Cd-rom drive. Be careful not to unscrew any screws holding the cd-rom drive together.
9. Now, you just have to remove the cd-rom drive, carefully by sliding it either forward or backward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
10. Now that you've removed the cd-rom drive the next step is to install your new CD-rom drive. To do this, simply slide the cd-rom drive in from the front of the computer, controls facing forward. Plug all the plugs back into the cd-rom and screw everything back into place.
Jan 17, 2010 | HP Pavilion TX2000Z Notebook
My CD-rom will not work after inserting CD's or DVD will not rev-up what wrong and what should I Do I Have Inspiron 531????
1.The laser optical eye of the CD-ROM drive may be dirty, and needs cleaning.
If the optical eye is dirty, it won't read the information on the disk you install.
A) Computer on, Windows loaded, open the tray of the DVD-ROM drive. (Or DVD burner drive. Whichever drive you are referring to. DVD-R/RW)
Shut the computer down normally. (Start>Turn Off Computer>Shut Down)
Unplug the computer from power.
Use a can of compressed air fror computers, and spray air into the DVD-ROM drive.
The optical eye, is located on the bottom of the DVD-ROM drive. (Or burner drive)
The opening in the bottom of the tray, that comes out for your disk, is where you spray the air.
You won't be able to see the optical eye, so how will you know you are spraying the air at the correct place?
If you start at the front of the bottom of the DVD-ROM drive, and work your way towards the back, you will clean the optical eye. Spray across from side to side, and in rows, as you proceed towards the rear.
(Air will make it's way through, and reach the optical eye. The optical eye is not visible, as it can be harmful to the human eye when operating.
Laser.
When the tray is closed the optical eye is exposed. It is not exposed to where it can harm the computer user.
More information that may be helpful, in understanding where the optical eye is located,
http://en.wikipedia.org/wiki/CD-ROM_drive
Scroll down to the heading - CD-ROM drives. Also view the photos down on the right, and the animated GIF.
http://electronics.howstuffworks.com/cd4.htm
How a CD Player Works. Same principle for your DVD-ROM and DVD burner drives )
2.Make Windows reinstall the drivers.
This solution requires physically removing the flat ribbon cable from the back of the DVD-ROM/DVD burner drive, then reattaching it.
Software advice of Updating the drivers, Rollback the drivers, or downloading, and installing the drivers, doesn't always work, or doesn't work.
If the physical solutions I am providing here does not work, we will proceed to the software solutions if you wish. (Comment)
1.Computer off, and unplugged from power. Open the computer case,
Dell Support - Dell Inspiron 531 Desktop PC - Manuals - Documentation - Removing and Installing Parts,
http://support.dell.com/support/edocs/systems/inspd531/en/OM/parts.htm#wp1595069
(Removing the computer cover)
CAUTION!
BEFORE you reach inside you need to relieve your body of Static electricity!
Not trying to freak you out, just needed to catch your attention.
Static electricity, can fry out the delicate computer hardware components, inside your computer.
Touch the metal frame of the computer case.
Computer unplugged from power you are safe.
Touch the metal frame of the computer case, (AFTER you unplug the computer), the computer is safe.
In the above Manual documentation - Removing and Replacing Parts, click on - Drives
Scroll down to the heading - CD or DVD Drive
(Towards the bottom of the page)
Unplug the DATA cable from the CD-ROM drive.
(No.2 in the illustration)
[The two optical drives you have are SATA drives. Dell indicates you have a DVD-ROM drive, (Plays CD's and DVD's), and a DVD burner drive.
(Plays CD's and DVD's, and records)
DVD-R/RW is a 'Burner drive'.
If the information above is correct, you have a SATA power cable, and a SATA Data cable.
(The Data cable transfers information from the optical drive, to the computer, and vice-versa)
The SATA power cable connector, is longer than the Data cable connector.
The power cable connector has 15 pins.
The Data cable connector has 7 pins.
Information,
http://en.wikipedia.org/wiki/SATA
Scroll down to the heading,
Data
Look to the right at the photo. This is a SATA Data cable, and it's connector.
Yours may not be a bent 90 degree elbow, but it will have the L shape in the connector, and 7 pins.
Scroll down to the heading Power Supply. Look down to the right at the photo of the 15 pin SATA power cable connector.
This is Not the cable/connector you want to unplug.
Unplug the SATA Data cable from the optical drive you're referencing to.
Press the Power On button in, and hold it in for a count of Five seconds.
Let go of the Power On button.
Do this two more times.
Plug the SATA Data cable back in.
Close the computer case.
Plug the computer back into power.
WAIT 1 minute.
Turn the computer on. Try the drive.
Dec 17, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Need a system recovery? Tried the F8 method--doesn't work! Help!
Just unplug the hard drive cable and plug it again. otherwise if problematic replace the cable.
Apr 24, 2009 | Gateway GT5404 PC Desktop
Hi all was ok in till i removed my hard drie affter i shut down the system and turn it off i removedthe hard drive now system will not boot back up it will power on but wont boot up ive unpluged everything...
hi im josh in cebu phils.may i help you? friend try to do this things. first i suggest to change new ide or sata cable.if still persist.try the following:
Boot order: Traditionally, a computer is set to boot first from the floppy drive, and then from the main hard drive (Drive C). This means that the computer will check the floppy drive first for boot files. If there is no disk in the floppy drive, the computer will then go to the hard drive to look for boot files. That is why if you leave a non-bootable floppy disk in the drive and try to boot up, you'll get an error message such as "NTLDR is missing. Press any key to restart." or "Non-system disk or disk error." This can be changed to pretty much any order, including CD and DVD drives. It is useful when installing Windows on a new or just-formatted computer to set the computer to boot first from a CD-ROM drive, and then insert the Windows installation CD-ROM into that drive. This saves you from having to use boot floppies that might or might not come with the Windows CD-ROM. Good luck.
Mar 05, 2009 | EliteGroup MB ECS A770M-A 770 SB600 AM2+...
Hard drive and dvd rom stopped working after changing to cd-rw, the ide cables have to unplugged to get any response from hard drive or dvd rom
Have you done the proper connection ? Please check out the Power & Data cable inserted firmly in Hard Disk, and DVD rom, after then check out the jumper is inserted correctly.
Unplug the Ram for 5 minutes and then try to start PC. Hope this works. Let me know the status after then.
Oct 09, 2008 | Apple Computers & Internet
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
