Coffee and Espresso Makers
Problem for Coffee and Espresso Makers
Generic problem for all Coffee and Espresso Makers
Adjusting tamping pressure on a la mar...
By roadhousejoe on Feb 25, 2009
I'm wondering if I need to adjust the tamp pressure, or the quantity of coffee portioned. Right now I have to adjust the grinder too course to achieve a good pour time. However it is so course the extraction is weak.
Clarification Request
Posted by EsWorld on Feb 26, 2009
Before I get into your grinder I have a question, when brewing a shot what does the bottom gauge on the espresso machine read. If it is not getting to 9 bars? It sounds to me that the pump on your machine might be the problem, but without more input I cannot be of more help.
1. What is the pump pressure?
2. How much coffee is in the portafilter, ie is it tamp to the fill ring on the filter basket.
3. I am assuming that you have a Marzocco or an astoria espresso machine because you're using a swift grinder.
Solution #1
posted on May 16, 2009
Not Rated)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 331 votes
It is possible that the burrs on the grinder need to be replaced. However if that was already done and you are still having the problem, the adjustment for the coffee amount is behind the tall rectangular box on the grinder. Remove box (4)screws and on the left side there is a microswitch this affects the level of coffee.
Was this helpful?
Yes
No
Popular Solutions for Coffee and Espresso Makers
Questions and Unsolved Problems for Coffee and Espresso Makers
Answer
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop... (More)
Answer
Problem with Bezzera Ellise. Internal pressure drops and water comes out of the steam wands
Answer
I need to replace the clear acrylic cap that fits inside the lid of the Russell Hobbs electric... (More)
Answer
Shuts down without heating water. When cycle is initiated times out after about 3 minutes and shuts... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coffee and Espresso Makers:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 2511
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
