Question about GE Profile WPRE6100G Top Load Washer
GE Evolution = How to remove the Clutch Assembly for new belt
My belt was worn out and it had left a lot of black residue from being worn on the bottom of the washer
I bought a new belt but I can't figure out how to get the new belt on. I suspect I need to remove the clutch assembly but there is clip that I can not see how to remove. If this is not what I need to do can someone please tell me one way or another.?
Thanks in advance
  • 4 more comments
  • robert427 Feb 26, 2009
    This is an image of what I am working on.
    Here is another view . I think this is the one you want.
    This probably would ave worked .
    1) I lifted the engine upwards with a hammer thereby lifting the whole drum a little
    2) I did not loosen the screws.
    3) On the larger pulley there are holes nderneath tat can be used to grip and twist the pulley around so that you can get the belt on.
    It is a question of getting a good grip and slowly turning the belt once it is almost on and then it snaps into place.
    I did nto have to play with the screws this way. I suppose it is a littel more brutish and it was helpful to have my wife holding the hammer so that the egine was held up. I can see this as possibly risky in that if shhe would have lost the pry on the engine I could have gotten hurt. I tink it would have been better to use the screws but I can not vounch for my intelligence this time of night.
  • brandon8534 May 11, 2010
    As I looks in the photo you should be able to put the belt on the pulleys. By first putting the belt on the furthest pulley and with the closer pulley try to wrap it around it by turning the pulleys so it can slip on.
    I have a way but I need another angle of that pin from the other side to see of how its placed on. Its a type of locking pin.
    Can you post a picture of what your dealing with? I probably can help you with this.
  • 70 Answers
Actually, you just need to place the belt around the motor pulley and get it started around the larger pulley and move the belt clockwise while keeping it on the larger pulley. it will self thread onto the large pulley as you spin it.
Good Luck!
Posted on Feb 26, 2009
  • WRMtech
    WRMtech Feb 26, 2009
    there are 4(four) 3/8 nuts under the motor plate. Losen them up and slide the motor towards the middle of the machine. This will allow you to spin the belt right on.As you look at the motor, draw a line at the base of it so you know where to pull it back as you tighten up the nuts. ALWAYS tighten the easy front ones first, this will hold the motor in place.
    Goos Luck!
Brushbar not working
probablt belt wore out or broken r&r
Feb 14, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
Clutch will not release
Not much information to work with like make and model but I can make some general suggestions. A badly worn belt will sometimes leave rubber residue on the pullies causing them to be grabby so they won't release. If the belt is old I would replace it and clean any residue from the pullies and make sure they are smooth. If it is a new belt I wold look for a place in the linkage to adjust it each way to see if it helps. This may require removing covers or other things in the way. The clutch arm will usually have something on the backside of the belt that puts a pinch on the belt to hold it when the tension is released. This can be a formed part of the clutch arm that may be bent out of position or a bolted on piece that can be adjusted. Some clutch arms have a brake pad that presses on the transmission pully to stop it from turning and that could be missing.
Oct 19, 2014 | Garden
2005 Piaggio X9 Evolution 250 no top end speed
Hi, Dan and the usual suspects are:
1. Inlet system air leak.
2. Enrichener valve not seated or leaking.
3. Damaged or restricted fuel tank vent system.
4. Restricted fuel supply tract.
5. Dirty or damaged air cleaner element.
6. Plugged bowl vent or overflow.
7. Worn or damaged needle or needle jet.
8. Vacuum piston assembly malfunction.
9. Loose or plugged main jets or passages.
10. Improper float level.
11. Accelerator pumps inoperative.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Troubleshooting
Leo vince fitted loss alot of power
PIAGGIO MSS X9 EVOLUTION 250 Workshop Manual
Piaggio X9 EVOLUTION 250 2004 Parts
PIAGGIO X9 Evolution 125 Owner Manual
Aug 05, 2017 | 2005 Piaggio X9 Evolution 250
Residue left on dishes
Make sure you use a drying agent as well a good brand name dishwasher soap.
Aug 30, 2009 | Bosch Evolution 500 SHE45M05UC Stainless...
Beater bar will not engage. belt ok, cannot find a clutch, what else?
One possible problem could be a worn clutch. I just had the same problem. Before buying a new clutch assembly, I took the out the clutch just to make sure I could do it (the link previously mentioned is great: http://www.dysonmedic.com/DC07%20Folder/DC07%20Clutch%20replacement.html). In the process, I also opened the clutch at the wide end (two screws and a little retaining clip on the side - can watch a video as to how to disassemble the clutch here: http://www.ezvacuum.com/dyson-dc04-dc07-and-dc14-belt-pack-for-clutch-system-90251401-2-pack-p-2196.html?currency=USD). In the "lid" you will see a little black plate (looks like the same material that a car breakpad is made out of). If the clutch is the problem this plate will look a little worn down. It can be removed and flipped over. You'll get a few more years out of it. Of course, when the second side wears out, you'll have to get a new clutch (but by then maybe the the entire vac will need replacing anyway). Saved myself $40. Enjoy.
May 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
GE Prodigy Washing machine making clunking noise
One common problem area is the clutch assembly. The clutch is built on top of the motor, the motor drives the clutch and the clutch assembly drives the rest of the washer. The clutch gets very noisy when parts inside are worn out. The shoes lining that drives the inner drum of the clutch wear off and you will get a metal on metal sound. Clutches often can be rebuilt, but sometimes they are too worn and replacing the whole clutch is the best repair. Please use this link here for clutch replace and repair info. The belt and pump may be the next items to check for noises. How to access the washer. Clutch repair help.
May 03, 2009 | GE Washing Machines
How to replace belt by motor
To replace a washer belt, remove power, remove back panel. On the left side is the motor, clutch, pump and belt. The pump is driven by a coupler clamped to the pump and clutch assembly. Loosen one of these clamps enough to move the coupler away so the old belt can be slipped past the coupler and also to facilitate the new belt to be installed. The belt runs in a pulley built into the top of the clutch assembly and can be "run" onto the transmission pulley very easily. To adjust the belt tension, pull out the washer, tilt it back against the wall......there are 3 nuts and bolts holding the motor assembly to the bottom frame, loosen these nuts off, the holes on the motor bracket are oval shaped so the motor assembly can be moved back and forth. You can move motor to tighten or loosen the belt, just make the belt fairly snug and don't over tighten it.
May 03, 2009 | Washing Machines
GE evolution dryer has intermitent squeeling!
Is the belt slipping? Check and see if it is worn. Open door, remove 2-4 screws at 12:00 position, lift up cover. The belt is the little band wrapped around the big thing.
Jan 25, 2009 | GE DBL333EA Electric Dryer
Belt of pulley part of pulley in pan of machine
it sounds like a belt and or clutch problem. there is a retaining clip that holds the clutch onto the motor, this may have come off releasing the clutch bell and belt. if you only see a half of a pulley in the bottom then you need a whole new clutch assembly with a new belt.
Jun 29, 2008 | GE Washing Machines
Final spin cycle problem
Sounds like maybe the clutch is worn?? Ge has several versions of this washer out some use a clutch and some dont Does yours have a clutch attached to motor or is it a solid pulley? Also GE uses the slow speed to start the spin and then kicks into high one or 2 mins into final spin. Is this noticable or does it sound like it starts slow and then never shifts???
Jan 20, 2008 | GE WBSE3120B Top Load Washer
GE Profile WPRE6100G Top Load Washer Logo
483 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
