Question about Sony VAIO PCG-K23 Notebook
Replace DVD Drive in a Sony Vaio PCG-K23
Bought a new DVD drive for my notebook. Thought I could replace it by removing two screws on the bottom of the notebook. What else do I need to do?
  • halborowiak Feb 28, 2009
    ...the old DVD drive wont pull out. I cannot see anything holding it in place. The screws are out. Do I really need to take this whole laptop apart to replace something as simple as this?
  • 447 Answers
Here is the service manual for your unit with an exploded view of the notebook. Post back here if the guide still help you solve your problem.
Posted on Feb 25, 2009
  • 1 more comment
  • John Elliott
    John Elliott Feb 25, 2009
    NOTE: This previous post on FixYa says pretty much what you say - two screws and out.
  • John Elliott
    John Elliott Feb 28, 2009
    If you open the dvd drive and use the tray as leverage to pull the unit out you may not have to open everything up but if you do have to open the case here is a really good graphical instruction on how to gain access to the DVD drive for removal (you should be able to accomplish the task by step 7).
  • John Elliott
    Just an addition to my previous...
    Forced removal of the drive if it isn't budging is probably best done from the inside of the unit just so you can get a look at what's impeding it. The guide I linked to previously is probably the best demo I've seen for your model. Read through some of the comments below the article also so you can see what others experienced with the procedures described.
    Cleaning up the fan(s) while you're under there isn't a bad plan either.
    Let me know how it turns out.
How to remove a hard drive from a sony vaio pcg-6n1l
Turn laptop over and remove screws from HDD compartment door.. Remove screws holding HDD in place and remove.
Nov 22, 2013 | Sony VAIO PCG-6N1L, PCG-6N2L, PCG-6N3L...
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Could you, please explain how to replace HD drive on my Sony PCG-9rfl?
You will see a cover on the bottom of the laptop. The cover needs to be removed to get access to the hard drive.
Mar 31, 2010 | Sony VAIO PCG-K23 Notebook
My sony vaio freezes at the sony screen during boot
Most likely a hard drive problem but could be a number of things. Try pressing tab or escape when it freezes and see if the screen switches and gives more information. If you are able, remove the hard drive and try booting again. (the cd/dvd drive could also cause this so try removing that if possible)
Jun 17, 2009 | Sony VAIO PCG-K23 Notebook
Need to recover the computer, back to factoru settings
Call sony, the disk is 12 bucks. I had this problem after my hard drive crashed. Be careful though, because I replaced the hard drive and it would not recognize the disk after that. Sony wanted me to pay 100 dollars to fix it.
May 07, 2009 | Sony VAIO PCG-K23 Notebook
Cannot find bios for sony vaio PCG-K23
If you can't find it, how do you know it exists? I don't see it on the Sony Website
If you were instructed by Tech Support to upgrade the BIOS, then they should have provided information on how to obtain it.
Apr 01, 2009 | Sony VAIO PCG-K23 Notebook
Sony PCG-951A DVD Drive
Yes, the drive is removable, and there is only one little screw on the bottom side of the computer that holds it in. Remove the screw, and you will be able to pull the drive out of the bay. There is no lock.
Mar 16, 2009 | Sony VAIO Notebook
Sony pcg-tr1f laptop
The hard drive is hidden inside, and you have to take the palm rest off to get to it. Take the srews at the bottom out, take the keyboard off and replace the screws underneath. then pry off the palm rest. There are Laptop Repair Guides that show how to open a Laptop. Watch out for the ribbon cables, those tear easily. Replacement parts are usually available on Ebay. There are third party services that can do it for you, like Sony Repair NYC.
Feb 26, 2009 | Sony VAIO PCG-K23 Notebook
There should be a small screw or screws on the bottom near the drive. You should be able to slide the drive assembly out once these are removed. Replace with a compatible drive and reinsert the screws. Boot up and install any needed drivers for the new drive. Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Sony VAIO PCG-K23 Notebook
Sony VAIO PCG-K23 Notebook Logo
219 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
