Question about Dean SR14E Deep Fryer
Dean gas deep fryer burner on high will not respond to temp set
Burner will not respond to thermostat setting.
Model# SR152GN
SN# 063mB0023
Series- AB WH 02
NG 120 K/HR
  • sandyman641 Feb 26, 2009
    I will try and locate a new thermostat tomorrow and change it out. I will let you know how it goes.
    sandyman
  • sandyman641 Mar 02, 2009
    Fixed the problem. Thanks
    beachygreen
  • 833 Answers
The thermostat is likely welded shut. You'll have to change it out.
Posted on Feb 25, 2009
Frymaster Dean Deep Fryers pilots light automatically go off
Will this heat up at all. Is it the same Model # as the one you .have some changes from the one you have for 2 years ago might have been made. check model # and make sure it is the same The light that go's out might be when the unit come up to the setting you put you Thermostat on meaning it heated up and will come back on when the temp drops and it starts to heat back up. it's that simple. if you just got this unit it should work if you turn the heating setting up . Let me know if the unit heats that is the starting point.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
Deep fryer pilot is blown out when burners go out after reaching temp
Hi there. Hi limit may be tripping off due to high oil temperature (power supplying the gas valve is connected in series with the hi limit). Verify if the thermostat is not shorted, also please check the thermostat calibration if it is good.
Regards.
Sep 16, 2013 | Frymaster Dean Kitchen Appliances - Others
Getting 400 ppm of co at vent
Too much CO is a result of a rich burn mixture...
Check to make sure that all the burner shutters are wide open...
If they are all open then the gas pressure needs to be turned down at the gas valve...
The screw to set the pressure is under a cap screw on the gas valve...
open the top and then turn the inside screw up or CCW to turn the flame down...
heatman101
Jan 15, 2011 | Frymaster Dean Frymaster/Dean FPEL3 Deep...
Pilot will lite,but burners will not lite when you turn the thermo. up
Make sure gas valve is in the ON position after lighting the pilot. Try jumping the thermostat terminals together to see if burner comes on. Three things could cause this problem 1. bad operator on gas valve 2.low millivolts 3. thermostat not functioning
Tom
Aug 03, 2010 | Frymaster Dean SR42G Deep Fryer
Pilot light
Assuming that your make up air and exhaust hood are properly balanced, no negetive pressure conditions exist, your gas manifold pressure is at 4" wc, your air/gas mix on the burner set correctly, the your problem would be the pilot adjustment. If the flame is not intense enough flame to survive the sudden air shock, it will go out.
The pilot height should be about 1 1/2". Your Pilot orfice could also need cleaning. Eliminate excessive draft in your kitchen.
Here is the manual for your unit, it covers these topics.
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5355.pdf
Jan 24, 2009 | Frymaster Dean H17-SC Deep Fryer
SR24
It could be a faulty high limit, you can also check the high limit probe to insure it is mounted securely against the through tube wall in the grease. Also check the burner, there are baffles that run through it and when they get old the flames don't move though the burner correctly and will cause the high limit to trip prematurely
Nov 09, 2008 | Frymaster Dean 2424G Deep Fryer
Dean SR152GN Fryer
Is the unit propane?If so the baffles may be sooted up and need to be cleaned.This usually causes blowback.
May 19, 2008 | Dean SR14E Deep Fryer
Garland deep fryer
gas valve not fully turned on
cattering hose not fully pushed into connector
thermostat tube inside oven broken (new valve)
Nov 13, 2007 | Garland AF-5025 Deep Fryer
Dean SR14E Deep Fryer Logo
505 people viewed this question
Top Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
starztruck4u
paulcarew
Are you a Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
