Question about Car Audio & Video
Battery light appears when i apply ther brake
When i apply the brake the batter light appears and none of the brake lights work i know the fuses are blown but as soon as i put new ones in they blow straight away can anyone help me???
  • josh1111 May 11, 2010
    are the fuses for an amp or in the fuse box of the car not enough info tohelp
    New Friend:
  • 15 Answers
You definitely have a short in your power line for your brakes. Shorts can be very difficult to find. They can be anything from water in the fixture to someone tapping into the brake line for their car stereo. (if you accidently used the brake power line as ground, it could be shorting through the chassis of the car/truck since an ohm meter would read it as ground without the pedal being pushed.) You might find the easiest way to solve the problem is to take it to a professional and it might even take them a few hours or just a few minutes to find.) It IS unquestionably a short in the brake wire, and it is unfortunately impossible for anyone to give you a firm answer without being with your car with a voltmeter in hand. Take it to a pro. Good Luck
Posted on Feb 28, 2009
How can I find out what fuses to check for brake lights on 2004 Trailblazer
ther is no fuse for that particular lights is ther a switch very close to the brake pedal that activate brake lights when you brake, and needs to be replaced, not to expencive
Sep 20, 2014 | 2004 Chevrolet TrailBlazer
Back light, dome light, front panel, radio, air not working
Try looking for a fuse box in the glove box. Even try opening both front doors and looking on the sides of the dash. O e other spit may be under the steering column. You will have to lay on the driver side floor looking up to find d it if its there
Jan 11, 2014 | 2002 Dodge Grand Caravan
My headlight or brake lights will not work i check the fuse in light bulb but still do not work at all...2005 trailblazer
there is an E Z WAY for you to find out what is roung with youer lights .go to youer head light there are three wires there find the bigs one an make a small hole in it now get a pice of wiure that isa long enuiff to go form the head light to the batter ,strap at lest 1hafe of an IN'to baer wire so that you will get a good conatch to the +poted of the batter an the ether end to head light big wire .now remanber that that wire mosted also be straped 1 hafe IN 'so when you put the wire form batter to the light threr will be power to the light if ther is light when you do this then the bad ,,that mines get a new light switch .now if ypou dont want to drive in the drark'i hope this helps you out
Aug 01, 2013 | 1994 Honda Accord
My brake lights were not working so we checked all of the fuses, now we tried to crank the car and it wont start but you can hear a click from around the fuse box under the hood. car was working fine...
When you checked the fuses did you pull them out and examined them and if so was the batter connected. You could have accidentally blow a fuse by pushing it back into the fuse socket. Re-check all the fuses again but this time disconnect the battery. Any broke fuse replace and once done re-connect the batter.
As for your brake lights check the brake pedal and make sure that upon depressing the brake pad you hear a clicking sound engaging a switch to operate the brake lights. Good Luck
Jan 07, 2011 | 1998 Ford Contour
Bbrake lights worked then didn't. replced fuse
You have a brake light switch under the brake pedal arm. When you apply brakes the arm presses a switch and turns them on. The switch may have went bad. Easy to replace. It's works like the push button in a refrig "open the door the lights come on" close it and the lights go off.
Jun 25, 2010 | 1990 Mazda Protege
Brake lights and cruise control stopped working at the same time?
Ther is a recall on the brake light switch it makes the cruise control not work too. but Chevy only recalled the Brake lamp Switch. Recall #09049.Hope this helps.
Jan 01, 2010 | 2006 Chevrolet Colorado
1991 corolla sx no dash or reverse lights and batter light won't go off.
if you have no ignition lights on your dash, no reverse lights and if when you start the car up the battery light stays on your ignition fuse has blown controlling these items. change the fuse. not sure if it is your ignition lights by your posting. if it is not please give a more detailed report,try to help if i can. hope this helps.
May 08, 2009 | Toyota Corolla Cars & Trucks
Brake lights wnt wrk when pushing dwn brake, but park lights do
As cadman mention to check the fuse, and if there ok check your brake light switch along the brake peddle arm. Before you doany of that, turn your hazard light on to make sure that all your light's are not burnt out. Good luck
Apr 08, 2009 | 2004 Kia Rio
2006 Mazda 3 Hatch brake lights not working
ur breask switch may be not working or wire is loose....also check ur globes,,,,some globes carry 2 functions.....normal light and brake light,,,,,so i assume you brake light globes need checking
Mar 07, 2009 | 2004 Mazda 3
Car Audio & Video Logo
46 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
