Question about Electronics - Others
No electric start
I have replaced the battery,checked the inline fuse. all is fine.and still no power to the lights,horn,or turn signal. can someone please help me figure this out
    President:
  • 1,714 Answers
Can you tell me what kind of machine this is??
Posted on Jul 23, 2009
I have full battery power but no power to my dash ignition lights when i turn key put have head lights and horn. on my 2008 chevy cobalt
Some cars have inline fuses in the battery cables and have multiple connections for components making one get power and others not. If all your fuses are good, the next thing to look at is the electrical part of the key switch. Usually there is the mechanical part with the tumbler, and the electrical part.
Dec 07, 2013 | 2008 Chevrolet Malibu
I have a 78 mgb the head lights, turn signals, gas gage, and rpm gage, don't work. We have checked wiring and fuses but can't find anything. Would appreciate any suggestions. Thanks.
Ignition switch? Battery?: Voltage correct? Battery size and type correct? (Other owners\' restore screw-ups? Kids?) Fuses correct amperage?: Power surge? Items themselves ruined/burned out? Stripped or exposed wiring--intermittent? Water vs. electrical. Dirt/contamination? Fuse box and connectors? Horn work? Starts, of course? Alternator? Alternator cables? Belt? (Hummm: Alternator--often a fine bet for small car trouble--big car, truck, or powerful car alternators, V8 or V6/6 cyl. always prove better. Small car/cheap car alternator? Old MG alternator--time to replace/re-coil? Dirty alternator? Your alternator proves worthy of crucifixion?!) Keep pluggin\'--it\'s gotta be something!: An interesting exercise in logic for Mr. Spock?!
Aug 20, 2013 | Cars & Trucks
2004 Dodge Caravan Electrical Failure
The body control module seems to be the culprit here. Have it tested or replaced.
Mar 28, 2017 | 2004 Dodge Caravan
Turn Signal/ High Beam Lights/ Driver Window/ Horn suddenly not working! Help!
These are just ideas, but In my simple attempt....start with checking, or have someone check every fuse in the fuse box. Another thought is that the turn signal indicator arm that controls blinkers, high beams has finally gave out. And when it did, it might have shorted out the horn. Being a 1993, it has probably seen some usage. Does the cigarette lighter work?? Also check the fuse in the fuse box that controls the horn, because in some of my experiences, the cigarette lighter and the horn are sometimes on the same fuse.
Jan 10, 2013 | 1993 Cadillac DeVille
No electrical power when key is turned on
It sounds like it may be the ignition switch. you can use a multimeter to test the incoming wires to the switch and if they are show power, turn the switch to start and the test the out going wires.
Feb 21, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Lights, turn signals, horn don't work
Look for a bad ground connection inside the headlight shell (or possibly elsewhere). The other thing that all of the items you mention that are working intermittently have in common is the ignition switch. With the switch 'on', check for battery voltage at the fuses for the headlight, turn signals, horn, etc. No voltage at the fuses likely means a bad ignition switch.
Nov 05, 2009 | 2000 Harley Davidson FLSTC Heritage...
It starts and runs perfect but no headlight horn
first... check to make sure you don't have blown fuse.. using an electrical tester also, pierce the wire going into the units(if testing blinkers.. horn.. etc.. make sure you actually turn the blinker or horn on etc) this will tell you if you're getting power to them.. if no power trace wire back to connectors with the tester, checking connections etc... (you can get the electrical tester for about $5, clips onto battery and has small light that turns on when it's getting current to where you pierce the wires)
Sep 02, 2009 | kawasaki Full Suspension Mountain Bike Men
92 FXR bike will not start or even turn over
the starter solinoid is not working if it has an electric start, try kick starting it, if it won't start check the points or the ingiter coil.
Aug 08, 2009 | 1993 Harley Davidson FXR Super Glide
Electrical problem after battery replacement.
Below is a listing of which fuse corresponds with which circuit:
1 - 10 Amp - Transmission Controller, Gauges, Autostick
2 - 10 Amp - Right High Beam Headlight
3 - 10 Amp - Left High Beam Headlight
4 - 10 Amp - Radio, CD Player
5 - 10 Amp - Washer Motor
6 - 15 Amp - Power Outlet
7 - 20 Amp - Tail, License, Parking, Illumination Lights, Instrument Cluster
8 - 10 Amp - Airbag
9 - 10 Amp - Turn Signal Lights, Turn Signal/Hazard Indicator
10 - 15 Amp - Right Low Beam
11 - 20 Amp - High Beam Relay, High Beam Indicator, High Beam Switch
12 - 15 Amp - Left Low Beam Headlight
13 - 10 Amp - Fuel Pump Relay, Power Train Control Module
14 - 10 Amp - Cluster, Day/Night Mirror,Sunroof, Overhead Console, Garage Door Opener, Body Control Module
15 - 10 Amp - Daytime Running Light Module (Canada)
16 - 20 Amp - Fog Light Indicator
17 - 10 Amp - ABS Control, Back Up Lights, Daytime Running Lights, A/C Heater Control Cavity Fuse Circuits
18 - 20 Amp - Power Amplifier, Horn
19 - 15 Amp - Overhead Console, Garage Door Opener, Trunk, Overhead, Rear Reading, and Visor Vanity Lights, Trunk Release Solenoid, Power Mirrors, Power Door Locks, Body Control Module, Aspirator Motor
20 - 20 Amp - Brake Lights
21 - 10 Amp - Leak Detection Pump, Low Rad Relay, High Rad Relay, A/C Clutch Relay
22 - 10 Amp - Airbag
23 - 30 Amp - Blower Motor, ATC Power Module
24 - 20 Amp - Power Window Motors
25 - 20 Amp - Power Door Lock Motors, Power Seats
Apr 04, 2009 | 2002 Dodge Intrepid
Electronics - Others Logo
63 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
