Question about HP LaserJet 2300L Printer
Unable to store job at printer, printer not configured to collate
I am not trying to collate, just print multiple copies of a sign created in Print Shop. I have printed multiple copies on this printer from Print Shop in the past. Now it says I need to configure a RAM disk or install a hard disk if supported. Please help me to print more than one copy of this sign at a time.
Problem -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
Error “Unable to store Job at Printer”
Reason “Printer not configured to collate”
Solution “Install an EIO hard disk”
Usually when trying to print a multi page document.
Solution 1. Start > Control Panel > Printers
2. Locate the printer > Right Click > Properties.
3. Device Settings > Mopier Mode > Set to Disabled.
4. Apply OK
Posted on Mar 21, 2009
  • 5 more comments
  • joelvill Mar 28, 2011
    Thanks a bunch. This fix worked! I've had this exact same problem with my HP 2300 for about 3 weeks now and haven't been able to resolve it. Again, thanks for your help.
  • bz985 Jun 30, 2011
    Thank you very much. This was a very quick fix! I had been putting up with this problem for over 2 years.
  • rswag Jul 02, 2011
    This fixed my problem also. I think the problem began when I upgraded to 7. Thanks a lot.
  • Rockinjim Jul 29, 2011
    Great! My problem also started when I upgraded to Windows 7, and this fix worked!
  • Harvey Catchings Nov 02, 2011
    I tried it and you are right, it worked.........!!! Thanks for the information.
  • Curtis
    Curtis Feb 11, 2014
    This solution worked for a LaserJet 4050 on a PC that had just transitioned from Windows XP to Windows 7.
  • Muhammad Usman Moosa
    Muhammad Usman Moosa Mar 26, 2017
    it worked thanks
I have HP LJ 4100 series and I am getting a error message: unable to store job at printer. Printer not configured to collate.
Hi
Thanks for your question at Fixya,
Please find the solution to your problem as follows :-
If you are using Microsoft Windows 2000 and XP etc.. Then you need to follow the below procedure,
  1. From control panel choose Printers and Faxes,
  2. The then right click on the printer icon and select properties,
  3. In the Device Settings tab you need to make sure that the 'mopier mode' is disabled.
  4. Multiple copies will print without moping in addition to this make sure that that 'Job Storage' is disabled.
  5. Then go ahead and close the printers window and then try to execute the print command again.
Hope this helps ...:) In case you have any queries , feel free to contact me.
Sep 14, 2011 | HP LaserJet 5500DN Printer
How can i print multiple copies of the same document with 3 pages and have the printer staple the copies in the correct groups?
In the print driver you should have the option to collate, you need to make sure that that option is on, and when you go to send the print job, you need to make sure that you adjust the finishing options in the driver to tell it to staple.
May 11, 2011 | HP LaserJet 4250 Printer
Why do multiple copies sometimes staple together as one set instead of multiple sets?
I don't know how/why, but if you set the Print settings (main print screen) to non-collate and the Printer Properties (clicking in to get to the staple option) to collate, it works correctly, stapling each set individually.
Oct 28, 2010 | Konica Minolta bizhub C450P Laser Printer
Printing page order
under print settings make you have "collate" option checked. There are different ways to find this depending on which operating system you are using.
May 26, 2009 | Brother HL 1440 Laser Printer
Print error job storage
The printer needs to have RAM drive off, mopier mode disabled. Also the device settings for the printer needs to have Printer Hard Disk set to not installed and job storage and mopier mode set to disabled.
Jan 15, 2009 | HP LaserJet 4200 Printer
Excel Print Queue Delay Problem
It has to do with your collate settings on your printers properties and the collate settings on your first print screen that shows up when you go to print. First when you are ready to print select print from the file menu in excel then go to the properties of the printer you are going to use and make sure the finishing properties are set the way you want them. Hit ok then you will be back at the first print screen. Here uncheck the collate box and then print. I am unsure but this may work. I had a similar problem a while ago and I know if I played with the collate check box it would print much faster other wise each time it was going to print a copy of the document it had to resend all the information again to the printer, which took forever.
Jan 08, 2009 | Microsoft Office Standard for PC
I am running Microsoft Word 2003 and have an HP 1320n printer. My problem is that when I print more than 1 copy the pages do not collate even if the collate box is ticked in the print dialogue book and so...
HP 1320 print driver is a universal print driver covering several printer models.  Collating only works on HP printers if you have a multiple exit tray system for commercial based laser printers similar to finishers on a copier.  They have to have room to keep the copier together before they can be collated.  On a standard configured 1320 there lacks any space for finishing tasks.
This support bulletin on hp.com can provide you the answer:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01366409/c01366409.pdf
Sep 10, 2008 | HP Computers & Internet
KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
Jul 23, 2008 | Office Equipment & Supplies
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
Using Job Accounting with Excel
Try unticking the collate box on the print window. this can cause 50 jobs to be sent rather than 50 copies of the same job.
Hope this helps
Mar 27, 2007 | Canon ImageRUNNER 3570 Copier/Printer
HP LaserJet 2300L Printer Logo
14,387 people viewed this question
Seeker5211
Seeker5211
