Question about Hobart D300 Stand Mixer
New bowl & hook hobart d300
I need a new bowl and dough hook for a hobart d300
anyone suggest where I can get one?
My location - san diego ca - can pick up or order it shipped
  • Anonymous Mar 30, 2014
    Leaking fomm the center into the bowl
    Problem Solver:
  • 17 Answers
There is a website called, It carries parts for the hobart 30 quart mixer. I specifically saw the bowl and hook attachments as well as others like beaters and a cheese and vegetable grater. Hope this helps. And if you sign up I think you can even request a full catalog for your machine.
Posted on Mar 08, 2009
My dough keeps on rising up to the top of the hook
change the hook to spiral. J hooks tend to have dough crawl up
Feb 23, 2011 | Hobart D300 Stand Mixer
Mixer shuts down midway through mixing dough on low speed.Is ther a thermal overload next to contactor that may be overheating
A thermal overload is an option on the D300 and is self resetting. Assuming your machine is being operated at it's full rated voltage, you might have to cut down on the amount of dough you are mixing. If I recall correctly, the relay and overload is located in the base or behind the speed selector plate.
Feb 24, 2010 | Hobart D300 Stand Mixer
Hobart D300 Mixer, Will not shift from 2nd to 1st gear without coming to full stop, Ideas as to source of problem? It also seems to be making increased noise.
Hobart mixers are NOT designed to change gears while operating. The Hobart planetary gears are like the transmission in your car but, without the clutch. Everytime you change gears while unit is running you are tearing up the brass spacers, gears & seals. Time to call a QUALIFIED service tech to come out & sell you another planetary or rebuild your old one, about $2K, Buy a Varimixer if you want to change gears while unit is running, they use belts. Another planetary premature failur cause, over loading the bowl. Batters & icings- 75% bowl capacity, Dough 65% bowl capacity.
Jul 23, 2009 | Hobart D300 Stand Mixer
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
Beater mechanizim runs very slow and will not change speed
It sounds like you sheared a key in the transmission.Does any gears work?were you using 1st gear for dough?
Jan 15, 2009 | Hobart D300 Stand Mixer
The ball turns in opposite direction.
You have a 3 phase unit, it can run opposite direction if the main feed wires are not correct for the motor wiring. If you simply swap any two of the main electrical feed wires it will run in the opposite direction. This should correct your problem now. Enjoy.
Dec 29, 2008 | Hobart D300-6036 Mixer
Need to Raise the stop height of the bowl on the H600
I should have know this was a scam to sell something.
Thanks, but no thanks.....
Dec 09, 2008 | Hobart HL600 Legacy Stand Mixer
Broken Mixer
in what speed?any noise?what were you mixing?it may be a sheared key or broken gear.let me know.
Jun 28, 2008 | Hobart D300-6036 Mixer
Dough mixer not working at all
it sounds like the mixer was overloaded and therefore broke a shaft,gears or sheared keys.
Oct 27, 2007 | Hobart D300 Stand Mixer
Hobart D300 Stand Mixer Logo
146 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
