Question about Technics SL-1210 Turntable
No power to the decks
Turned the decks on as normal but theres no power changed fuse but still no power???
  • chant_k Feb 25, 2009
    the problem is neither of them work both decks ave no power going to them working mint yesterday???switched on as normal turned the on switches to on no lights no power?im baffled
  • 6,784 Answers
Hi, this is much more than the fuse. im sensing a board issue with a capacitor. there may be a cold solder also that has lost its hold as well. check the board for any lose or cracks. and discoloring.
Posted on Feb 25, 2009
  • Michael Masters
    Michael Masters Feb 25, 2009
    Check all contact point as well on the power board.
  • Michael Masters
    Yes, its defiantly a power board issue for sure.
No power when plugged in ? Is there a fuse ?
The best way to find out is remove the base of the deck. You should see the power supply then. If the deck is main's powered the transformer will be seen. Some have fuses built into them, so it needs checking. Some decks use a mechanical switch to turn on the motor. That can break or stop engaging. But this will only apply if the deck doesn't have a power light indication. A deck with an on off switch for the power can also suffer a broken switch.
Jan 22, 2016 | Teac P-A688 Turntable
Tried hooking subs and amp to my factory deck in my 2006 chrysler town &country limited.. Everything was working but wife's friend started while I was wiring smelled like burning electrical.. Now no s
Only fuse you need is the power wire leading to your aftermarket amplifier for te subwoofer. Which most likely you have too small of a gauge of wire and burned straight through it, and if you haven't, add a 40 amp fuse near the battery where your power cable is hooked up to. Also use a multimeter to test your power wire on amp, check the
Jul 19, 2013 | Car Audio & Video
2003 hyundai tiburon dual din JVC touch screen deck installation issues
Hello, Chose another powersource for your device. It is possible that you are tied into a circuit breaker that is constantly resettting. Maybe use an MP3 player for the trip and work on it when you get back.
Dec 09, 2011 | 2003 Hyundai Tiburon
Had factory radio, burned out or so I thought. Replaced with after market, not the first one in there. Bought wire harness so I did not need to cut any wires. Now I have no power to the new deck. Fuses are...
Check all your fuses first. The yellow wire behind the deck is for a constant 12 volts from the battery( to retain memory), the red wire is for switched power, for example when you turn the key it should be 12 volts, when you remove the key(or turn off) there should be no voltage on the red wire, and of course, make sure you have a good ground. Use a test light when performing these tests, it's a time saver.
Aug 19, 2011 | 1994 Jeep Cherokee Country
The power buttons doesnt turn off and is there a
there is a power button on your deck, but you must get to the screen where the clock is, touch the button and it will shut off, if not then we need to trouble shoot the situation, which is easy, if you take out your deck. and if you can find the blue wire w/ the white stripe that is located on your deck this is your remote wire, this cut the deck on and off, when hooked up properly, first your gonna need to extend this wire, so it can reach the fuse panel, then you need to locate the fuse that says cigarette lighter, pull the fuse out, and stick the extended remote wire there, then reinsert the fuse. now the deck should be off, now if you put the key in and turn it to on, the deck will come on, and when you turn the car off, it will swtay off, this will work i bet my rep on it.
Feb 19, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
No power in either turntable
maybe the power source that goes into the deck itself has dissconected, but it is strange that niether would work...so im guessing the decks are fine...it might be your extension cable...or u have had a power surge, if that has happened...then you need to seek profesinal help...and unfortunally, your decks may have died. But check your plugs/extension cables...etc....it should be a basic problem, and easily fixable
Aug 03, 2009 | Technics SL-1210 Turntable
Doesnt turn on
Three things to check.
Are all connections secure? Check and double check this.
Is there 12V coming to the 'remote lead?' Use a 12V meter from your local Walmart to test when the deck is turned on there is power going to this lead. No power and the amp will not turn on.
If there an inline fuse on the Power or Battery + that has blown? If so check and change this.
Jul 07, 2009 | Legacy Audio LA420 Car Audio Amplifier
No power to deck
If you have not check the radio fuse in the fuse block under the dash or right side kick panel, i would do this asap. if its not the fuse, you may have a dead radio.
Jun 06, 2009 | 2000 Chevrolet Cavalier
Amp neon lights wont turn off
There are two types of power that feed your amplifier. There is a constant power that connects directly to the battery and there's a remote power that usually connects to the remote power output of your deck. Some decks do not have the remote power output, but they have a power antenna output that works just as well.
The remote power is what enables the amplifier to turn off when the car's power turns off.
Either way, it sounds like you have the remote power input on the amp connected to your constant power source.
That would prevent the light from turning off with the car.
If you don't have a remote power or power antenna output on your deck, I would invest in a new one.
However, it is relatively easy to find a remote and a constant power source in your fuse box.
Purchase a fuse tap for a few cents and connect the remote power input on the amp to a power source in the fuse box that turns on and off with the ignition.
Some of the power sources you can find in your fuse box that go on and off with the ignition may be labeled something similar to the following:
ignition, power windows, radio, accessory, etc.
The constant power sources in your fuse box are the ones that don't power off with the car, such as the dome/interior light, power locks, battery, etc.
I hope that some of this helps out a little.
Dec 04, 2008 | Car Audio & Video
Deck does not play/turn on
Problem is not the fuses, but the power supply / power transformer has blown. This is why you should always wrap exposed wiring with electrical tape or heatshrink tubing.
The power supply can be purchased HERE, but this is not an easy replacement. And if you blew it by not properly replacing the Pop-up light, than I DON'T suggest you try to replace the power supply on your own either. You could really cause even more damage, and possible harm to yourself and your property.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
A DJ PRO AUDIO Co.
Nov 25, 2008 | Technics SL-1210 Turntable
Technics SL-1210 Turntable Logo
113 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
