Question about LG 32LG30 32 in. LCD HDTV
TV PICTURE SETTINGS REVERT BACK TO DEFAULT LG 32PG6000
Hello, I have just purchased an LG 32PG6000 and whenever I try adjusting the picture settings to my preferred taste, after 10 minutes or so the new settings revert back to default. I just can't seem to retain my new adjustments. Am I doing something wrong ? LG 32LG3000 once enters standby next power-on changes to the picture items are lost e.g. turning down sharpening on the standard setting. Also forgets which picture setting was last selected and defaults to vivid on power on.
  • Jim Bay May 11, 2010
    You make the adjustments then watch some programming and after 10 minutes it reverts back to default?
    Or does it revert to default after turning the TV off? If this is the case what is the TV plugged into?
  • Anonymous Mar 25, 2014
    My LG 42LC7D picture has only blue and green. I tried adjusting the colors in the menu, but it didn't work. I also tried resetting it to the factory defaults, but it is still green and blue.
  • 4 Answers
Hi it sounds like when tunned in tv it was tunned in shop mode.
do a factory reset and choose home when installing
Posted on Mar 01, 2009
I HAVE 52" RCA TELEVISION.MY GRANDSONS WERE WATCHING IT USING REMOTE CONTROL.THEY DID SOMETHING;WHICH HAS CAUSED THE SCREEN TO SHRINK.PICTURE NOW HAS APPROX. 4" TO 6" ON ALL...
Can you please give us the exact model of this TV set so we can help you better..by the way did you try resetting the settings of your TV using the remote I believe there's an option there to reset the settings of the TV set....
Oct 21, 2008 | RCA Televison & Video
I have just bought a Samsung LE -26R82B tv. After adjusting the Picture Standard for Contrast, Brightness, Sharpness and Colour the picture seems to revert to factory settings after about 30 mins. This...
Your TV is in shop mode which can be turned on and off by holding the front panel menu button down for 3 secs.
( Shop Mode is used to reset to default settings after 30 mins. and to not retain settings after power off.)
Please Let me know if you have any further Questions
Thank you for using Fixya and have a Great Day!
Apr 19, 2008 | Televison & Video
How do I factory rest my Lg led smart tv?
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 10, 2014 | Televison & Video
When I change picture settings from my remote why does it revert back to old settings
Main system control memory IC fault. Contact any service technician to replace it. Before replacing this IC; do a reset to this set and check.
Sep 10, 2014 | LG Televison & Video
I recently purchased used LG 37 (37LC2D) PICTURE WOULD QUIT READ ALOT OF PEOPLE HAVE SAME ISSUE. THEY RECOMMENED new main board i purchased one off internet $112 slapped it in and ba bam it worked an
Try to restore factory settings (default settings) to come back to original settings..In this procedure you can determine if the problem is on settings or on the faulty parts..
Thank you and hope it helps...
Jan 01, 2012 | LG Televison & Video
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
I purchased 42" LG Plasma TV and i need to know
There is quite a lot you can do. Go to menu, picture settings and select user 1. From here you can adjust everything from colour to contrast to warmth to sharpness. The best thing to do is to switch to XD manual adjustment and make sure the mpeg noise reduction is set to max. This removes artifacts and gives a better picture. Oddly, connecting via SCART rather than HDMI will give a more watchable picture if the HD broadcast is't at a very high bit-rate.
Dec 29, 2010 | LG 42LC2D 42 in. LCD HDTV
Hi!
I have a user manual in norwegian, and I have just solved this problem. Go to page 107 in the user manual, and it will guide you. :)
Feb 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop mode or demo mode. How to get out of "Shop Mode"
1. Press [Source] to get to the Air or Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself (not the remote)
Next step must be completed while the volume bar is still on screen
3. Press and hold [Menu] on the TV itself (not the remote) for about 7 seconds
If the screen flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the alternative way below
Alternative Method
Press [Source] on TV remote to get to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight SETUP and press [Enter]
Press [Enter] again on PLUG AND PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or choose an alternative language
Press [Right Arrow] to highlight HOME and press [Enter]
Press [Menu] repeatedly until you see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by pressing [Info] on the TV remote
Nov 09, 2008 | Samsung HL-T5687S Television
LG 32LG30 32 in. LCD HDTV Logo
1,480 people viewed this question
Computer Repairing
Computer Repairing
