Question about Denon AVR-600 Receiver
AVR-600 We have a Denon AVR-600 and -protect- is showing on the unit. We follwed the instructions in user manual and checked all speaker connections for shorts, cleaned vents and unplugged it for 24 hours. Nothing has resolved the problem it still says -protect-.
  • Chuck May 11, 2010
    i meant to say that if it doesnt say protect after you unplugged everything that you should only plug one thing in at a time and find out the culprit.
    unplug everything! yes everything. Just plug in the power cord and see if it still says protect. if it doesnt then plug on thing in at a time and see what is causing the protect. Could be a damaged speaker crossed rca connectioins. let me know. i will get back to you
  • 119 Answers
The problem is past that point once the protect continues to activate the amp is in need of service
Posted on Feb 26, 2009
Denon AVR1603 RESET
Starzy, to reset on a Denon AVR-1603
  • power off the unit using the front panel Pwr switch
  • press and hold SPEAKER A and B buttons;
  • keep pressing on the speaker buttons, switch on the AVR
  • when the display is blinking release buttons Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Denon AVR 1603 Operating Instructions Manual Last Function Memory...
Jul 24, 2016 | Denon Audio Players & Recorders
AVR X1000 going in protect mode?
If you used it for only 3-4 hours before the problem occurred then you should have a replacement warranty on the product.
I think you have already done the factory reset procedure shown on page 175 of the user manual.
Is it possible to take it to the place you purchased it from. Alternatively check the Denon website and find out who the closest agent is in your locality. Send it back with proof of purchase using a courier service that you can track for receipt. Hope it turns out well.
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
Denon avr 592 no sound
First of all check all the speakers. Maybe all the speakers gone out because of the loud blast. Also check in the tuner mode. Is there is any sound. If there is some problem in the avr then it will show the fault and will go into protection mode.
You can check the speakers with a battery from any one of the remote. Take the leads of each speakers and connect the lead to the battery terminals. If the speaker is ok then it will make a small cracking sound each time when you connect its wire to the battery.
Sep 27, 2012 | Denon AVR-2802
I need too know how to hook my speakers up to my DENON AVR-1601
Check the User Manual, at the site on FixYa:
Very easy instructions, I hope this helps.
Feb 06, 2012 | Denon AVR-1601 Receiver
AVR-1508 7.1 Channels Receiver: My Denon AVR-1508 won't stay on. Once I try to tak...
Not familiar with this model but seems like the protection circuit is kicking in, this could be caused by an imbalance of Ohms between channels or a short. remove & check all speakers and cables for continuity or shorts, does the unit power on without speakers or in a different mode (surround off).
always add speakers in pairs (L&R) before testing to prevent possible protection circuit, test main speaker pair first then add surrounds (all according to the allowable Ohms range for the amp of course)
Nov 18, 2017 | Denon AVR-1508 Receiver
AVR-589 Denon Receiver Keeps Shutting Off
even if the wires are not touching they can still arch. make sure there is no bare wire showing ie. cannot see any unshielde speaker wires. id unplug then replug back in
May 18, 2009 | Denon AVR-3805 Receiver
Protection circuit momentary activation. Not heat/speaker problem
Is it possible for you to lower the source level? if yes go ahead...
There is an automatic Dialogue normalisation function in Denon which is activated to reduce overly bright input signals. ( most movies have wide variation in sound levels and therefore this function is avaialble). (see page45 of your user manual).
When your system worked fine with the AVR 2808CI, then why is it giving problem with AVR 3808CI....???? You must ask Denon.
Protection circuits are activated when:
1). There is rise of internal temperature.
2).Core wires of the speakers are touching each other or a core wire is sticking out of the terminal and touching the set's rear panel or the speaker itself has a problem.
3). Speakers with an impedance other than specified are being used.
4). the set is damamged or has bad solder / dry solder connection .
If your AVR is new, please do not accept, the set could be faulty. The protection circuits should not be activated unless any of the above happen.
You must know, at times the protection circuits are not fast enough and it could burn some of the transistors on the power output circuit. With time, the solders on the circuit board could give way and give you problems later on.
You must sort out with Denon if the AVR is under warranty.
Best of Luck.
Mar 11, 2009 | Denon AVR 3808Ci Receiver
Denon AVR-810 going into PROTECTION mode
It sounds like there is a problem with the differential circuit. The bias I am not sure about, as every unit is different. You should get the service manual to be sure or call Denon and see if they can give you an idea. Good Luck
Jun 05, 2007 | Denon AVR-2106 Receiver
635 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
