Question about Dell Computers & Internet
Monitor is vertical display instead of horizontal display
My 2 year old managed to change the monitor from horizontal to vertical. So to view the monitor you either sit with your head on the side or turn the monitor on its side. Do you know how to get it back to a horizontal view.
We have a viewsonic VA902
Kazz COMPUTOR ABIT SG-95 motherb. Intel Core Pent. D celeron
with a Dell monitor ( 4 year old, from prev. comp.) which allowed vertical ( screen on it's side ) with the old comp. Used for Music staff & the screen is too wide & too low / short. No setting can be found to change "polarity " )
ASUS graphics card ( a pocket size book with 20 languages & only 2 pages per L. Has 2 discs V513 &558 in the box .
email if req.
  • gortin Feb 26, 2009
    Apoloies. MANY THANKS FOR TRYING. Neither suggestion helped. This monitor worked ok on the Dell. I had did the conversion that time, but I cannot find the options on this one
  • gortin Mar 16, 2009
    Very many thanks for your suggestions,but the arrow keys etc. didn't help. I suspect it's a software problem. There would probably be a progr. to sort it.
    APOLOGIES ON THE LATE reply, I forgot about it ( that I had written ) even though it bothers me nearly every day
  • 162 Answers
The keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Posted on Feb 25, 2009
  • Dell Master
  • 19,396 Answers
You change display orientation by holding down at the same time the key combination ctrl alt and arrow keys at the same time.
  • Ginko
    Ginko Feb 26, 2009
    This is not a monitor problem.
    All you need to do is holding down the key combination ctrl alt and arrow keys at the same time.
    Do the following.
    Hold down contrrol and alt key at same time, and also at same time, whilst holding down control and alt on left side, press one by one the arrow keys, that change screen orientation on windows .
    Let me know how it goes.
  • Ginko
    Ginko Mar 16, 2009
    There is no software bug that can do this, if control alt and arrows (try all arrows) does not work , it can only be a virus.
    note: you must hold DOWN ALL THREE BUTTONS AT SAME TIME.
    Hope this can fix the problem.
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Monitor viewing position
what model of monitor do you have..?
May 18, 2008 | Philips Brilliance 107B 17" CRT Monitor
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
Monior displays vertical instead of horizontal
Nothing wrong with your mon. It is your windows display setting.
Go to display properties and change it back to normal.
Nov 13, 2011 | LG Flatron L1751S-SN 17" Flat Panel LCD...
Fix the monetor view to horizontal view
Orientation can be changed to landscape mode by accessing the video card properties in the windows "Control Panel".
Oct 25, 2008 | ViewSonic P775 Monitor
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
Monitor display is vertical instead of horizontal
What Video card are you using?
Right click Desktop>>>Graphics Options or
Right Click Desktop>>>Properties>>Settings>>>Advance
and change the rotation to NORMAL
For Intel Video card go to GRAPHICS Properties
For ATI Video card go to CATALYST
For NVIDIA Video card go to PHYSx
Oct 09, 2008 | Dell Computers & Internet
Horizontal lines on my monitor
I have a similar problem with a 2 year old Samsung monitor. I have tried to make a screen dump of it, but the horizontal lines do not show up then. This I have read indicates that the problem is in the monitor and not the video card.
Sep 17, 2007 | Computers & Internet
Hansol 730E CRT monitor
Oct 18, 2006 | Hansol 730E 17" CRT Monitor
Computers & Internet Logo
354 people viewed this question
Alun Cox
