Question about Canon LaserClass 2060P Plain Paper Fax
CHECK PRINT ##324
MACHINE NOT PRINTING. EVERYTIME WE TRY, IT DISPLAYS AN ERROR. THE DISPLAYED MESSAGE READS-"CHECK PRINT ##324". WHAT DOES THIS MEAN AND HOW CAN I FIX IT????
  • 59 Answers
This error is a laser motor error. You can try to lube the laser bearings by taking apart the laser assembly, most likely you will need to get a replacement
Posted on Mar 20, 2009
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Brother Intellifax 2920 Error "Unable to Print"
Check the flux capacitor, those usually go out on brother faxes.
I just replaced mine last week, same problem.
Jan 05, 2010 | Brother IntelliFax-2920 Fax
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    DISPLAY READS: 80 SERVICE (01E4)
    If you keep getting 80 service, first recycle the power to the printer (try a few times if the error doesn't go). If that doesn't work replace the MIO card (the bit the network cable goes in)
    Jun 16, 2008 | HP LaserJet 4 plus Printer
    Canon imageclass MF8170c print problem
    i have Image class MF 8170 c Just printing blank pages.no erro code
    apear on display.
    Jan 11, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
    Unable to print. Error message Machine Error4F
    here read this:
    http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000001887&Sympt=How+do+I+clear+the+message+Machine+Error+4F+from+the+display%3f&Model=89&ProductGroup=5&ProductID=MFC210C
    Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
    Check ink cartridge error reading won't go away and can't use it.
    Switch off the machine. depress all three buttons with the button depressed switch on the machine and hold the button in for a few seconds. Did the problem go away? No? try www.fixyourownprinter.com
    Jul 01, 2007 | HP PSC 2175 All-In-One InkJet Printer
    Canon LaserClass 2060P Plain Paper Fax Logo
    233 people viewed this question
    old marine
    old marine
