Question about Kenmore Washing Machines
Kenmore 82372110 70 series heavy duty plus won't spin
I have a kenmore 82372110 70 series heavy duty plus washing machine that drains but will not spin. Before it quit spinning, it kept getting out of balance and I would have to rearrange the clothes so it would spin. I'm not sure how old the washer is because I bought it used.
  • slw62 Feb 26, 2009
    Is this something I can do myself or do I need to call a serviceman?
  • Kenmore Master
  • 3,361 Answers
If it drains and won't spin you have to replace the direct drive coupling.
Posted on Feb 26, 2009
  • steve
    steve Feb 26, 2009
    It is one of the simpler repairs. You can do it.
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Spin cycle does not drain water. The washer just stops when it gets to the spin cycle. The washer is a 70 series heavy duty.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 30, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore 90 series heavy duty washing machine will agitate, but will not drain or spin.
check drain solenoid valve.follow drain hose into machine.valve should be lcated in this area.
Oct 16, 2009 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Kenmore washing machine will not drain
Replace the timer.
This is a neutral drain machine. If there is no natural pause in the timer at the end of the rinse cycle the timer is bad.
Mar 13, 2009 | Kenmore Washing Machines
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
1,570 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
