Question about Canon CanoScan 8400F Flatbed Scanner
Yellow streak through color image scan
When I scan color, it doesn't matter where I position the item to scan, I get a yellow streak through the scan. The streak is so bad that I can even adjust or tone it out of my photo. The scanner is an Epson Perfection 3490 Photo scanner, only 2 years old. It used to work great. Can you tell me what is wrong and how to approach fixing it? Thanks so much.
Crysti Esper I've been using the CanoScan 8400F for a few years with no problems.  Suddenly I started getting a yellow streak down the right side of the page on all color scans.  It seems to be getting larger.  I've emailed Cannon, but so far to no avail
Http://www.carlmcmillan.com/CanonScanner/Canon.htm
Posted on Aug 05, 2009
How do i stop my savin 2020 from printing a yellow streak on my color copies?
Sounds to me like either a faulty yellow toner cartridge (try replacing it) if the drum is integral with the toner this should clear it. Otherwise you may need to replace the yellow image drum.
Jun 09, 2014 | Canon for IMAGERUNNER C2020 C2050 C2058...
Light yellow streak down the center
there is a prism in between 3 lcd panels that the light shines through for the image. each lcd panel has a color filter between it and the prism. after a while the filter will fry, creating the discolor on the image. unfortunately, you cannot but just the filter. you'll have to get the entire lcd/prism assembly. it's pretty tough to get it out, so you might want to bring it someplace that can do it.
Feb 25, 2014 | Epson EX71 Projector
HP Color Laserjet 9500hdn printing yellow streaks at bottom of page
I'm not familiar with this model but have you ran the cleaning mode if it has one?
Aug 23, 2012 | HP Color LaserJet 9500HDN Printer
Red and yellow streaks appear in scans, always in the same location. The scanner was cleaned but the repair person could not find any problem with the equipment. Yet the streaks persist. How do I resolve...
execute a calibration to correct the wrong color:
  1. place your photo on the scanner, with a distance of 0.25 inch from the edge of the glass
  2. open Epson scan and select Professionnal Mode
  3. select the document source
  4. select the image type
  5. uncheck thumbnail then click Prevew
  6. crop the area of the image
  7. Click zoom to fine tune the area you see the streaks
  8. select the resolution of 72 dpi
  9. scan your photo
if the problem still not solved, you need to change the scanner unit , there are many dead pixels.
Dec 09, 2010 | Epson Expression 1640XL Pro Flatbed...
Yellow not printing - but only in streaks
Your yellow problem sounds like a bad yellow developer housing. Take the drum out and look at the developer housing, You will need a flash light to do so. See if the roller is solid yellow. Even if it is there may not be any developer left in the housing.
The Cyan sounds like the drum since it gets worse as it prints.
That can also be caused by the transfer belt cleaner. But that normally is the opposite. It has a rainbow sort of streak and it gets better as the machine runs.
Feb 02, 2009 | Xerox WorkCentre M-24 Color Copier
I think your flatbed lamp is damage
if u replace or color it pure white ink
Jun 10, 2008 | Office Equipment & Supplies
Yellow Streak on Images
I took the scanner apart. Then using a dampened eyeglass cleaning cloth, I gently cleaned the 3 internal mirrors.
No more yellow streak! :)
May 27, 2008 | Microtek ScanMaker 3800 Flatbed Scanner
Canon CanoScan 8400F Flatbed Scanner Logo
910 people viewed this question
old marine
old marine
