Question about Gateway MX6438 Notebook
I have a gateway MX6438 with a persistent DC jack problem. I had the notebook repaired and it started smoking on me not once but 4 times now. I've been told to replace the motherboard, but I'm hoping that there is a less expensive way to fix this computer, I like the features and don't want to give it up. Any suggestions? I can be reached at Charles B.
    President:
  • 2,653 Answers
There's nothing cheaper than fixing the dc jack again, but if it's smoking it sounds like a sinking ship.
Motherboard swap is gonna be the only way out of this mess unfortunately.
Posted on Feb 26, 2009
How to replace charging port
Gateway Nv57h73u notebook jack issue check:
1) more common issue is changer ( ac adapter) DC core broken inside, please change a adapter to fix. also you can repair adapter DC core wire. if still no charging that could be DC jack issue inside notebook.
2) disassembly keyboard and top cover of your laptop looking for a wire it connect to the DC jack, check is the wire broken close to the jack soldering pot. you can soldering it to fix, or other issue is jack damaged, you can order and change the DC jack with wire easily, the parts see picture
Oct 20, 2014 | Gateway Nv57h73u With Autodesk Maya...
Tip
Gateway Support For MX6438
You can get drives and support for your MX6438 laptop from Gateway HERE
on Jun 04, 2008 | Gateway MX6438 Notebook
My DC jack broke what should i do.
I am assuming you mean the DC jack on the motherboard in your laptop?
You can repair it yourself, or take it to a repair shop and pay to have someone do it.
To repair it yourself, you'll need:
1) A new DC jack (though sometimes you can fix the broken one)
2) The disassembly guide to your specific model of laptop. Google the phrase "laptop make/model disassembly" and one should come up pretty quickly. Guides are generally step-by-step with pictures included, and putting it back together is just the reverse of disassembly.
3) A soldering iron and solder. 15-30 watts for delicated boards like a motherboard. Once you've pulled your motherboard out, You can de-solder the broken DC jack from the motherboard (if necessary) and solder the new one on. DC jacks are generally 2-4 solder points and fairly simple to press back on.
May 26, 2011 | Computers & Internet
Gateway MX8738 Laptop won't power on. The power adapter is putting out the correct voltage, but the computer is dead - no sign of life. This happened once before - repaired under warranty. This time I'm on...
Sounds like your power jack may be faulty or bad connection to motherboard unfortunately. The only way to truly find out is by disassembling the laptop. You'll have to do this at your own risk of course, and test the terminals at the power jack to see if you are getting power through them, if you are, then the trouble is deeper in the motherboard. If you are not, then here is a good article on how to fix the power jack:
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Good luck.
Jul 21, 2010 | Gateway MX8738 Notebook
No connection with the DC Jack on Gateway 3550GZ
It's time to take the computer to a qualified technician, for proper trouble-shooting & repair, because there are very-few "user-repairable" parts inside a laptop/notebook computer.
Jan 20, 2010 | Gateway 3550GZ Notebook
Gateway MX6438
Here is the gateway link. Find you serial number  download the sound driver and reinstall it. YOu wil then know for sure.
Slow . Remove unused software Clean and defrag the harddrive. Number one reason for slow computers are the hard drive read time.
Feb 08, 2009 | Gateway MX6438 Notebook
Power Cord Slot Repair for a Gateway ML6230
First Of All.... STOP WIGGLING IT!!!!!!!!
WHat Your Doing is Shorting Out The DC JAck And Causing Further Damage Every Time You Wiggle It For A Connection....
Which Could End Up Ruining Your Motherboard....
Your Problem Is The DC Jack You Need To Have Yours Replaced... THis Involves Complete Disassembly Of the Laptop Down To The Motherboard, Then The Old-Bad DC Jack Needs To Be Desoldered and removed and a new one Soldered Into Place....
http://www.ifixlaptops.com
Nov 18, 2008 | Gateway ML6230 Notebook
Gateway laptop MX6436
Try this link. It's got disassembly diagrams for most models.
Jun 20, 2008 | Gateway MX6438 Notebook
How do I fix a faulty DC In port connector in my Gateway laptop?
To fix it yourself you would have to take the laptop apart and remove the motherboard.
Repair costs could run you $50 and up depending where you take it.
Example Site
Gateway MX6438 Notebook Logo
123 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
