Question about Lexmark C760 Laser Printer
BLACK VERTICAL STREAKS
TONER CARTRIDGE HAS BEEN REPLACED -- FUSER? OR
I.T.U
Thanks
  • Makoman Feb 26, 2009
    there is no ink in this printer IT IS A LASER.......................
  • 203 Answers
Toner recently replaced?
have you cleaned nozels?
try running a cleaning cycle.
also clean the paper rollers to make sure you got no ink on them.
Posted on Feb 25, 2009
  • sean sutton
    sean sutton Feb 26, 2009
    if it is a laser why would it have a fuser?
  • sean sutton
    what do you think the toner is?
    it does not print with a laser, the toner is ink powder. the laser sets it to the paper.
    it will still get blocked and it will still need cleaning
How do I get rid of vertical streaks?
You may have a bad drum cartridge. Is it refilled? Try replacing it with brand new original.
If there are debris of "black film-like material" you may need to replace your fuser film.
Apr 29, 2014 | Dell 3010cn Laser Printer
Hp lasject 4050a toner cartridge have black line in the paper
The vertical lines can be caused by a damaged fuser assembly. The fuser heats the toner and melts it onto the paper. The roller is covered with teflon and when it gets worn down it leaves streaks or "ghost" images on the paper. Here is an article dealing with the lines on a Laserjet 2100 printer but the cause is the same for the 400 and 4050 series printers. Check your fuser as per the information in the above article and if need be order a replacement fuser from somewhere like Amazon.
Mar 16, 2013 | HP LaserJet 4050n Printer
We have a HP LaserJet 1320 printer that is leaving black marks or streaks on the paper-maybe ghosting(?). We have switched cartridges and it is still appearing. Any help would be appreciated!
Vertical lines, ghosting, streaks, and dots usually indicate a problem with the fuser when it doesn't regulate temperature correctly. When this happens the toner sticks to the drums and then copies the impression on successive pages, or gets scratched by the sand papery build up making lines as each sheet goes through.
Horizontal lines, page dusting, and vacant areas on the page are usually the toner or the drum, which on most printers are one unit.
If you have replaced the cartridge and the problem didn't go away, you probably have to replace the fuser.
Apr 27, 2010 | HP LaserJet 1320 Printer
I'm getting black streaks down the left side of the paper. There is plenty of toner left in the cartridge. We've vacuumed out the printer, cleaned the drum - nothing helps.
black streaks the toner cartridge is leaking from the left side which is easy to check pull the tone and look at the gears on the left side to see if toner is present. if these gears have toner on them the cartridge is leaking replace it. check the fuser for wear marks on the hot roller which is the top roller when these get worn through the outer coating they will create black streaks
Dec 05, 2009 | Lexmark E238 Laser Printer
Black streaks on paper on samsung ml 2150 laser printer
Could you describe these marks for us please.
Are they small specks or blotches? Bad Toner Cartridge
Are they lines:
Horizontal - Transfer Roller or Charge Roller
Vertical - Bad Toner OR Bad Fuser.
Note: A bad toner cartridge can render all of the parts listed here useless. Check for build up or lines on the cartridge reflective drum. Avoid light, as with film.
If they are a mix of both, the device needs to be cleaned with a can of compressed air. You must remove the cartridge, paper tray(s, and fuser to create clear path.
Apr 28, 2009 | Samsung ML-2510 Laser Printer
Hp 4550 vertical line down center of page
From the service manual:
Vertical lines or streaks
 Check for a leak where light might be entering the printer.
 Check for circumferential scars on the photosensitive drum. If scars are present, replace the
drum cartridge if the line goes through all colors.
 Check for circumferential scars on the upper fusing roller. If scars are present, replace the upper
fusing roller if the line goes through all colors.
 Remove the imaging drum and inspect main charger or imaging drum for a contaminant, such as
a fiber, if the line goes through all colors.
CAUTION Do not expose the imaging drum to light for more than 15 seconds. The drum is light sensitive, and
exposure to light can cause permanent damage.
Vertical black lines
 The toner cartridge is defective.
 The toner cartridge is not seated properly.
 The fuser entrance is dirty.
 The fuser has scratches on it.
 This might be a repetitive defect. If so, the lines will repeat at a consistent interval down the page.
 The printer needs to be cleaned.
 There is a problem in the heating element.
Vertical white lines
 If white lines or streaks appear only in the black areas of the printed media, print several
configuration pages to clear the anomaly. If this does not clear the problem, check the sleeve
surface to confirm the defect, then replace the black toner cartridge.
 If white lines appear only in a particular color, try printing several configuration pages to clear the
error. If the error does not clear, check the sleeve surface to confirm the defect, then replace the
defective toner cartridge.
 There is a lack of toner or the toner cartridge is faulty.
 There is dirt in the laser path.
 The fuser is defective.
 A mirror in the laser scanner is dirty.
Apr 07, 2009 | HP Color LaserJet 4550 Printer
HP Laserjet IIIP starting printing thin vertical black line
Was this happening before you swapped toner?
Is there toner streaks on the drum? Yes? Defective.
What if you stop the printer (open cover) as it passes through the fuser to determine if image is from drum or fuser?
But really....isn't it time to move on anyway???
Mar 20, 2009 | HP LaserJet IIIp Printer
SF-560R. When receiving and sending Faxes
needs a new toner cartridge probably but the fuser rollers may be damaged as well usually if the lines are indented into the paper that means its the fuser roller if they just appear strait down the page then its the toner cartridge
Nov 18, 2008 | Samsung SF-560 Plain Paper Laser Fax
Two dots on right side of page
if you replaced the cartridge and the streaks are still there then it's the fuser. you can try to clean the "fuser" roller with a little alcohol and your finger nail (after it's cooled down) to scratch off the toner, if it's an actual scratch on the roller you need to replace the fuser as it will pickup toner again and leave marks.
hope this helps
thanks for rating
Jan 09, 2008 | Lexmark Optra SC 1275 Laser Printer
Lexmark C760 Laser Printer Logo
226 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
