Question about Dell 5310n Laser Printer
Dell 5310n knocking noise when printing envelopes
Whenever we print envelopes to the Dell 5310n, it makes a loud knocking noise as the envelope feeds into the printer. We were told that this same printer is doing the same thing in our other office. What could this be and how can we fix this?
  • lara609 Feb 27, 2009
    Thanks for the info. So why doesn't this happen to other printers? It's quite loud and annoying especially when you're on the phone.
  • 49 Answers
This is a good thing. The 'knocking' noise is actually called a "Thumper". It's purpose is to get the air out of the envelope before it hits the fuser. Air in the envelope typically leads to creases on the envelope itself.
Posted on Feb 27, 2009
Will not print envelopes. also is looking for more than one envelope
hi, each and every envelope has a code to identify it. So you printer knows what the size and format of the envelope is. you must select the code in envelope section from your application which you are printing your address for the envelope from eg; MS-Word. You should do this because not only dimentions of the envelope is telling the printer where to print but the weight of the envelope so it can allow for the thicker paper coz at some corners of the envelope it is 3x the thickness. feed it from the rear of the printer (manual feed) so it has its straightest path and does not have to curl around the rollers. make sure you feed it into the correct path there should be a line as a guide to where to feed it in so it can configure itself to where to print on the envelope.. i hope that helps you.. cheers!
Jun 19, 2014 | Canon Pixma MX452
Dell 5310N printing without jams, but pages are wrinkled in an accordion fashion, horizontally across the page.\r\n User also wants to know if they can use manual feed to do multiple envelopes at a time. ...
To fix mine I had to go in and trace the paper route with the duplex option installed...loosened on of the bolts just a little ... now works fine it was being dragged by the overtightened roller.
Sep 20, 2011 | Dell 5310n Laser Printer
I use a Dell 3110 cn printer. There were black splotches whenever I printed envelopes.I had a serviceman look at it to no avail so I changed the black toner cartridge. I am now getting blue splotches. ...
when you print envelopes you have to choose the envelopes in the printer settings then only machine knows that envelope is printing. when you don't select envelope in printer settings when you sent a print, the printer knows the a normal paper is coming through. the difference is that the envelope is a bit thick the normal paper. when envelope is selected in printer properties then the printer adjusts its settings to print on envelopes.
Jan 06, 2011 | Dell 3110cn Laser Printer
My printer has started making a knocking sound
Haha, shouldn't be your wife this time :P It sounds like one of two things.
1. One of the rollers that pulls through the paper has come a little bit loose and therefore is starting to hit other things, causing said noise. This is why you only hear it when it when the printer is active
2. One of the rollers or gears has become stiff, and isn't spinning as should be. This could stop all printing all together, so it's unlikely to be this, but without looking at it myself, I couldn't say, sorry.
I'd advise looking at the rollers within the printer, to make sure they're not jammed, loose or stuck full of toner. Make sure you have the printer off for a while too, you don't wanna burn your hands off :)
Lemme know how it goes
BB
Oct 22, 2009 | Dell 5110cn Laser Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
IBM 1532 makes a loud bang loading an envelope
That sound is actually the printer sucking the air out of the envelope to flatten it out. It is normal and there is no way to turn it off.
Aug 07, 2009 | IBM Infoprint 1532 Laser Printer
Clanking noise when printing from tray 1
if your getting this noise on every print job the fuser is usually the cause if they have been running on a bit hot they will get flat spots on the pressure roller and it will create a loud kind of clunking sound real common on lexmark lasers. it can also be an envelope setting on some lexmark lasers they have a solonoid for envelope feeding if the envelope inhancment is ingaged in the menu thiscan also cause such a noise
Feb 23, 2009 | Lexmark E450dn Laser Printer
Envelope printing
You need to insert the envelope in the manual feed area and open the exit door at the back this allows the envelope to go straight through the printer hopefully limiting creasing. Check the envelope settings in windows make sure that you are using the correct size and feed selection.
Thanks J
Feb 03, 2008 | Brother HL-2040 Laser Printer
Printing envelopes
Print on the Envelopes
  1. Click File , then click Print .
  2. Click Properties , then click the Features tab.
  3. Change the orientation to Landscape and the paper size to envelope #10 .
  4. Click OK .
  5. Click OK again to print.
Nov 18, 2007 | HP PSC 2410 All-In-One InkJet Printer
Dell A920 won't print envelopes
I have(had) the same problem using the Dell A920 printer on a Dell compunter running XP. After spending a hour trying to find a solution on the internet, I finally found a solution on my own. When ready to print a envelope. Go to File/Print Click Properties button In lower right hand corner, check "Print Color Image in Black and White" box Click OK button Click OK in print pop up When finished, repeat to uncheck "Print Color Image in Black and White" box to allow for color printing.
Dec 02, 2006 | Dell A920 InkJet Printer
Dell 5310n Laser Printer Logo
735 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
