Question about Whirlpool Washing Machines
Prize of part
Hello  how much would it cost me to buy a new drain pump for a whirlpool front loader? thank you  sophie
    Scholar:
  • 86 Answers
Hi, You are looking for a p ump around the £30 depending where you get it from and if you buy a complete one! As you can buy just the base..
Let me know how you get on......................
Posted on Feb 27, 2009
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won¨t start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
Whilrpool front loader F21
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Nov 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a frontload whirlpool washer and the water will not drai n out. I have clean the filter but it wil still not drain
hello, Chances are there is something in the pump and usually it will break off the impeller. You might have to install a new pump. Try unhooking the pump hoses and put the unit in drain and see if the impeller is turning or damaged before buying a new pump. please dont forget to rate me..Thank You..
Jun 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Error code F02 on Whirlpool Duet front loader
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Jun 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Gray front loader washing machine
Check the drain pump filter for a foreign object and check your hoses for clogging or obstructions.
If there is nothing wrong with either of those, you will need to replace the drain pump.
Jul 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loader drain pump keeps running all drain positions in cycle
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello eastax
Welcome
My advice now a days is :
It's really not advisable to fix a dishwasher that old.
It's putting good money into bad!
Here is an article I just read that you may find interesting.
Repair or replace?
When to pull the plug on your dishwasher
Typically, you'll also find a troubleshooting section for more-serious problems in the owner's manual and on the Web sites of many manufacturers.
Should you pay for a repair or buy a new model? The answer depends mostly on the age of your dishwasher, how much you bought it for, and the cost of the repair. Follow these guidelines from our in-house experts:
When a repair makes sense. If your dishwasher is under warranty or less than four years old , paying for a repair makes sense. Note that dishwasher under warranty might require service from a factory-authorized technician; readers have found them on a par with independent repairers.
When a repair might be a wise choice. If your dishwasher is out of warranty and is four to seven years old, it might make sense to pay for a repair. Readers paid $100 to $200 for a repair. But you might want to buy a new model even at this stage, given that today's models are quieter and have added features. They pay for them selves in only a few years due to higher energy efficiency which is another plus: Energy Star-qualified models made after April 28, 2008, are 43 percent more efficient than conventional models built before 2001 and 56 percent more efficient than those built before 1993.
When it pays to replace. The repair costs more than half the price of a comparable new dishwasher. Our data also show that it doesn't pay to fix a less-expensive dishwasher six or more years old .
Thanks to better recycling programs, less than 10 percent of a dishwasher you replace is likely to end up in a landfill.
Thank you for using our services to advice you.
Please remember to leave a rating!
Oct 05, 2008 | Whirlpool Dishwashers
Washing Machines Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
