Question about Astro Pneumatic 7846 Harmonic Balancer Puller Set
Removing harmonic balancer can't get centerbolt
I have a 98 hyundai sonata the outside of the harmonic balancer fell off have a new one but can't get the center bolt on the bad one to take it off.
Impact gun or find a way to keep egine from turning like a flywheel turner. or big long braker bar and give it hell
Posted on Feb 26, 2009
I am trying to remove the harmonic balancer from a 1990 olds 98. The balancer is the original and has no holes to attach a puller to.
There are no holes--slots or anything? Then you'll have to get a puller that grabs the outside edges of balancer.
In the picture, it appears the legs are long enough to grab the out side edge of balancer. The picture is harmonic balancer puller. I have seen pullers that had a main beam, fairly long, then the end pieces would slip onto the main beam and grab the outside edges of what your trying to pull.
Jun 17, 2017 | Cars & Trucks
Timing belt noise? Coming from passenger side, checked tensioner and harmonic balancer. Any ideas?
Hi,sprey a little water if sound goes away then you should ajust belt or replace.
Mar 17, 2015 | 2004 Hyundai Sonata Antenna, 04
Why is it hard to get balancer pulley off 98 neon? Tried a pulley puller and impact. Still no luck. What should I do?
Did you take out the center bolt? You have to remove the center bolt, then use a harmonic balancer puller. Not the two or three armed pulley puller, but a harmonic balancer pulley puller-the pullers with jaws that hook around the outside of pulley can ruin a harmonic balancer.
Use the impact gun to remove the center bolt. You won't need an impact gun to remove the balancer pulley. The balancer puller will take it right off the crankshaft, no problem.
Jul 23, 2013 | Cars & Trucks
2001 dodge stratus r/t 3.o liter outside pulley on harmonic balancer fell off. do i need whole new balancer or is there something that came off that holds it on?
ON most engines there is only on pulley as part of the harmonic balancer. It is the on that has the rubber between the pulley and the center bit on the crank. Any other pulleys are normally bolted to this pulley on the center hub piece . I'm thinking that the mount bolts have fallen out.
Apr 20, 2013 | 2001 Dodge Stratus
The big outside pulley on the harmonic balancer fell off
The Harmonic balancer is held on to the front of the crank shaft with a bolt. there are pullys pressed onto the harmonic balancer in rubber.If more pulleys are needed for more accessories they are bolted to the harmonic balancer.
Apr 20, 2013 | Cars & Trucks
Harmonic balancer removal on 2004 sonata v6
the pin is a line up pin for the balancer it does not hold the 2 together if the balancer is stuck you may have to use a puller to remove it
May 01, 2012 | Hyundai Motor 2004 Sonata
Harmonic balancer removal 2006 sonata
Do you have the harmonic balancer removal puller? It should come off with no problems after belt is removed.
Nov 17, 2011 | Cars & Trucks
The harmonic balancer is broken on my hyundai santa fe. How can it be removed and replaced
Parts stores sell a "harmonic balance pulley remover" for around 15-20 dollars. Much like a steering wheel puller, it's a gear puller made to remove the harmonic balancer with engine in car.
Oct 21, 2011 | 2002 Hyundai Santa Fe
Belts not moving
You should change the Harmonic Balancer that is a pulley with a rubber cover comes off when the rubber is not transmitting movement to correas.thanks
Feb 27, 2010 | 1995 Hyundai Sonata
Passenger door on 98 sonata wont open
dear friend-this is a tricky one but it works,roll the window down.remove the outside strip.push the widow aside and look inside for the door lock,take a piece of wire and make a hook on one,use the hook to unlock vehicle.
Jul 09, 2009 | Hyundai Motor 1998 Sonata
Astro Pneumatic 7846 Harmonic Balancer Puller Set Logo
524 people viewed this question
Top Astro Pneumatic Air Tools & Compressors Experts
Trippy Tripp
Tom Chichester
Are you an Astro Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
