Question about GE GSD2200Z Dishwasher
Correct water level?
Our dishes are not coming out clean. I suspect the water is not filling high enough. Should the water level be above the heater? Should the heater be immersed?
  • 833 Answers
Yes, the level should be above the heater but that is not likely the only problem. Make sure your filter at the bottom of the unit is clean (for adequate water flow) and that you're not overloading. Use the recommended amount of cleaner. Always scrape your dishes of loose food.
Posted on Feb 25, 2009
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Water level adjustment
If it has a ballcock bend the ball upwards till you have a high enough water level
Nov 26, 2013 | Toto Home
My sensing light stays on during wash cycle and dishes are not coming clean. The wash arms are not spinning very fast during the sensing nor the wash cycle. Not sure if it is the control board or the...
I do not suspect the control is the problem,it could be a weak pump OR not enough water in tub to be circulated. The water level should be at or just above the level of the heat element if it is less..the water valve is bad and not fully opening or the water supply into that valve is restricted
Aug 23, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
My dishwasher will not clean anything. It starts the programme and then constantly beeps. HELP!
Check the water temperature. Should be 125 to 140 F. (this is important.. check your hot water heater to make sure that it is turned up well enough to give out hot water)
Check pump re-circulation., Listen, see if it sounds like it is spraying the water around with enough pressure.
Check water level when the fill cycle has completed. Should be just under the heating element. If not, possibly need to replace the water inlet valve.
Check the spray arm and pump cover for splits or leaks.
Check to make sure dishwasher is draining after each cycle. There should only be a little water in the bottom of the tub.
Make sure the dishes are loaded properly, or dishwasher is not overloaded.
Possibly try a different detergent. Some liquid-gels will bubble and a pump cannot pump bubbles
ALSO.. if you had the manual whilch you can get free, check in the manual to find out what is wrong if dishes do not come out clean
Aug 11, 2011 | Miele Dishwashers
We get a white film on dishes and silverware after running then dishwasher. It 's getting worse gradually over time. What is the cause and how do we correct it.
If your dishes or glassware appear with a white film or a white powdery residue or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Please rate the solution if you feel I've helped you
Aug 24, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My dishwasher is not washing the dishes it acts like there is no or not enough water coming out, the supply line is new and good water pressure going in just not coming out
Water inlet valve not opening all the way. Water should go up to about the heating element. Let dishwasher fill when it goes to the wash cycle open the door to stop it and see how high the water level is. The water inlet valve may have a screen on it that you can clean out. If the water is not high enough and the water inlet is not clogged up replace the valve. If the water is high enough several other things to check.
Feb 26, 2010 | KitchenAid Dishwashers
The dishes don't come out clean after complete cycle or even after I re did the wash.
Has it always been okay in the past? Do you have the manual, and if so, are you loading it properly. I am not familiar with this particular machine, however there are a few things you can check. Make certain all the spray arms are spinning freely. If there is a "tower" that comes up from the bottom, be certain nothing is blocking the center portion of the bottom rack. Run a load as normal, but stop it after a few minutes. Is there water in the tub and are the dishes wet? If not, determine if the water source is on, and the "fill" solenoid is working. If there is water, and all dishes appear to be getting wet, be certain you are getting a lot of "water action" during the wash. If you listen closely, you should hear a sloshing sound as the machine runs. If not, your not getting enough water circulating. The pump may be clogged, or perhaps there is not enough water coming in. Is your water pressure high enough to fill it completely? I hope I have given you enough things to check in order to lead you to the problem. Let me know.
Oct 31, 2009 | Maytag MDB7100AWB Dishwasher
Water coming in stops short of the proper level - not enough water comming in to clean properly. I have to add water.
most dishwashers fill level is determined by time.
If the water pressure is to low, or the flow is restricted by sand or rust cloging the water valve, the unit will not fill with enough water to clean the dishes.
if you are willing to try, and you can use basic hand tools, you might be able to clean a clogged water valve.
first make sure the ELECTRICAL POWER to the unit is up-plugged or turned off. turn off water supply.
Valve is located under unit most can be reached by removing panel on lower front of unit. disconnect water pipe at valve and look for a filter screen inside the valve, remove it, clean it, reinstall it. now reconnect water pipe, and turn water and power back on look under unit and check for water leaks before reinstalling panel.
Sep 29, 2009 | Dishwashers
Kitchenaid dishwasher (nearly new) does not fill with water
first I would check screen on the water fill valve. make sure it is not plugged.
also check the fill hose make sure the hose is not pinched
check that the water is turned on all the...
this dishwasher is time filled the float is to stop the dishwasher at a overfill problem...
Mar 02, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishes are not clean.. on top level the dishes seem to be steamy
Check the following to address this issue.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Jan 30, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
GE GSD2200Z Dishwasher Logo
101 people viewed this question
Top GE Dishwashers Experts
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
