Question about Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier
Ionic breeze quandra died
Was working perfectly and it appeared the power to them was disrupted. I have no way to get it to work again and it is just "dead". Cleaned it well, and did everything I was supposed to do without success. (Tried different outlets without success.) Do they have fuses? How much does it cost to have it repaired as I love the product.
  • 1 more comment
  • kimberlyt760 Feb 27, 2009
    I am having the same problem, when I turn it on the power light flashes. This is really frusterating and all I can find are bad reviews about the product and NO support for it.
  • jjrph16 Mar 03, 2009
    Mine is as if the unit is unplugged. Ive tried to clean it,but nothing helps. I have not found any fuses on it either. But what makes matters worse is I have two of them and they both quit about two weeks apart.
  • claudia7 Mar 06, 2009
    I have a Quadra Pro - actually 2 out of 3 of mine just won't turn on. Does anyone know where I can ship them to be fixed?
  • 28 Answers
No fuses that I'm aware of.
The company went under and doesn't service them anymore. It's possible you could find a local repair place that might be able to do something, but there is no authorized or trained service station, and you can't get parts.
You might be able to pick up spare parts if you scour eBay long enough.
Posted on Mar 09, 2010
Ionic breeze quadra will not come on at all
My Quandra Ionic Breeze will not come on. I have cleaned it, but still nothing. I have had it for many years.
Jul 22, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Ionic breeze smells like a serious electrical short when I turn it on.
THEY RUN WITH A DIFFERENT KIND OF SMELL PEOPLE ARE NOT USED TO. ITS A HIGH VOLTAGE SCARY SMELL .IF IT SEEMS TO WORK OK THAN IT MIGHT BE OK
Apr 23, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic breeze gp does not work .
Hi.
Check power cord. If power cord has a built in fuse, replace it.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Mar 27, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Ionic Breeze - Cleaning Overdue light stays on even after unit has been cleaned
Hi.
The filter is damaged and may need replacement.
Regards.
Ginko.
Nov 18, 2009 | Sharper Image Ionic Breeze 3.0 Air...
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sharper Image Air Purifiers
Ionice breeze - no power, dead.
I posted a solution to a similar problem I had with my Ionic Breeze GP. I was able to replace a bad switch and get the unit working again. Details are in the following Fixya article:
http://www.fixya.com/support/t123864-ionic_breeze_3_0_repair
Oct 29, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper Image Design Ionic Breeze GP Professional Series Mod 1861
My professional series Ionic breeze GP blows out what seems to be clean air but the purple lights inside it are no longer working. Can anyone tell me where I can find replacement bulbs or just what I need to do to get it working again. I got it as a gift 4 or so years ago. The gift giver says there was a 5 year warranty on it but I am not sure. Any advice would be helpful.
thank you. Nicole
Aug 28, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Ionice breeze quadra Model # S1637
had the same problem with ionic pro ca500. i took the unit apart and found a fuse that was blown and it works now. sorry but i don't know if there is any repair shops.
Aug 02, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Sharper image ionic breeze air cleaner
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
Jul 15, 2008 | Sharper Image Professional Plus Ionic...
I was able to find the power-on switch to be defective. The switch is a momentary normally off switch constructed of two contacts on a printed circuit board1.gif. After five years, the surface of the switch contacts became oxidized and no longer made electrical continuity when depressed. I rewired the two wires to a new momentary switch and both my Ionic Air Cleaners are working again.
Feb 18, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Sharper Image Ionic Breeze® Quadra® 4.0 Silent Air Purifier Air Purifier Logo
110 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
