Question about Uniden BC72XLT Handheld Scanner
Only one bank blinks
Does this mean it is not scanning the other banks? I have other frequencies in bank 2, but only bank 1 is blinking. Hope this makes sense. I'm new to all this.
  • dove58 Feb 26, 2009
    I read the manual and did as it directed, but it doesn't indicate if the other banks should be blinking as well. It's extremely frustrating. Thank you for your help.
    Problem Solver:
  • 17 Answers
Yes that sounds like the case. Every scanner or radio I've ever delt with that is the way it works. Check user manual on how to turn off and on banks. Good Luck.
Posted on Feb 26, 2009
  • ntfd67 Feb 26, 2009
    Try putting a frequency that you know will have activity on it into one of the other banks that is not blinking. If you don't pick up anything then you know it has to be blinking to activate that frequency.
I Havel a pro-95 scanner and I have frequencies programmed into banks 1 thru 6 and the scanner isn't scanning banks 2 thru 6
Make sure the banks are enabled and the frequencies in the banks aren't locked out. If you are scanning trunked systems make sure the control channels are set up properly.
Keep in mind you cannot scan digital systems with this scanner, only analog systems and frequencies.
Pro 95 The RadioReference Wiki
Mar 07, 2017 | Radio Communications
Radio shack pro 135 want to scan only one band
  • Now if your wanting to scan one bank or your radio and the stored frequencies are still separated in different bands (banks) then just push the number on the keypad that you want to not scan. The number on your screen will show the banks that are active. Do this until only the bank you want to listen to is visible. To scan them again just press the corresponding number again.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 01, 2011 | Radio Shack Radio Communications
I have the BC370CRS SCANNER I am trying to clear all the memory and reset it. It is telling me to hold down 2, 9, and hold and turn it on. That is not working. Can you please tell me another way to do...
Locking/Unlocking Banks When you are scanning conventional banks, the scanner displays the digit corresponding to all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press the letter that corresponds to the bank. The bank's letter disappears from the display. To unlock locked-out banks, simply press that bank's letter again. The bank's letter appears on the display and the scanner includes that bank when scanning. Note: You cannot lock out all banks. One bank must be unlocked at all times. Locking/Unlocking Channels To lock out a channel so that the scanner does not stop on it while scanning, press L/O when the scanner is stopped on that channel, or manually select the channel and press L/O. To unlock the channel, manually select it and press L/O again. Restoring All Locked Out Channels You can restore all locked-out channels in a bank only when the bank is selected for scan. Follow these steps to restore all locked-out channels in a bank. 1. If you de-selected the bank, press SCAN then press the bank's letter. 2. Press MANUAL. 3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
Mar 29, 2011 | Uniden BC370CRS Base Scanner
Check engine light on, code reads p0420
Hi and welcome to FixYa!
Code p0420 means Catalyst System Efficiency Below Threshold (Bank 1). This will surely needs attention to resolve the problem.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 26, 2011 | 1999 Buick Century
During inspection I found out that a o2 sensor was bad but i was reading up on them and aparently there are four o2 sensors. 2 upper and 2 lower. How am i suppose to know what one is bad? secondly my...
The check engine light is blinking usually because of a misfire which can cause damage to the cat. The blinking check engine light does not necessarily mean the the cat is damaged.
The first thing you need to do is find out what codes are causing the check engine light to come on. If there is an O2 code it will help you identify the O2 sensor. The sensors are divided into to banks. Bank one is the same side of the motor as the number one cylinder. Bank 2 is the other side of the motor. Then they are divided into sensor 1 and senor 2. Sensor 1 is always before the cat. Sensor 2 is always after the cat. So if you had an O2 code for the Bank 2 sensor 1 O2 sensor it would be the opposite side of the engine from the number one cylinder and the sensor before the cat.
IMO, your first priority should be to figure out why the engine is misfiring and causing the check engine light to blink. Solving that first may take care of the O2 issues or the O2 could be the issue.
Dec 02, 2010 | 1999 Jeep Grand Cherokee
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
I have a uniden bearcat portable and base I cant figure out how to program it
With the scanner powered ON,
1. Press [HOLD].
“HOLD” appears on the
display.
2. Press [PROG]. CH appears
and blinks to indicate that you
are in the Programming Mode.
To change the displayed frequency,
use [UP] or [DOWN]
while “CH” is blinking.
3. Press [PRIVATE]. “PRIVATE”
appears on the display.
If you want to program it into
another bank, press the
desired bank key. The lowest
open channel appears on the
display.
2 screens alternate to indicate
that open channel is available
to be programmed.
The scanner automatically
selects the lowest open
channel (000.0000) for easy
programming. If all channels
have been programmed (there
are no open channels in the
bank), channel 1 appears.
Use [UP] or [DOWN] to select
a new channel and even overwrite
old channels.
4. Press [PROG] to store the
frequency in the desired
channel.
Note: Press [BAND] to escape
from programming mode before
step 4.
Need the manual? You can download/print it here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
Oct 01, 2009 | Uniden BC350 Base Scanner
How to program an Icom IC-R5 handheld scanner
to store a fcy press BAND to go to your fcy range ie 118.000 airband
dial your fcy ie 127.900(shanwick ocean area control) press and hold V/M for 1 sec, small numbers now blink, dial the memory slot you wish to store into ie 001 then press V/M again for 1sec and this will store 127.900 into mem slot 001. make a list:-
mem number / fcy / mode(am - fm) / station / bank
to prog a fcy into a "bank", press V/M for 1sec - blinking mem numbers - dial mem number ie 001(127.900) press MODE - "bank" flashes past-
-- -- -- -- 001 shows, turn dial to show A-00 this is the first "bank", pressing BAND scrolls through all the alpha "banks" - choose one.. ie A-00 (for airband..) press V/M this puts mem 001 into "bank" A mem slot 00, there are 100 slots in each letter 00 to 99. do this to any fcy you want to scan as a group.
to scan a bank press V/M - small numbers appear -
press BAND to scroll through any "banks" you have created ie A B C D etc (only banks with fcys in will display), press MODE -"bank"- press MODE again and you will start scanning just that "bank" of mem slots.
MODE starts and stops the scan... each letter holds 100 mem slots.. happy scanning!!!
Sep 22, 2009 | Icom IC-R5 Handheld Scanner
BC72XLT program/scanning problems
1. If you mean on "bank" of channels, then you have locked out the others. To unlock them, place the scanner in "scan" mode & press each button that corresponds to each locked out bank until all are "on", as indicated near the top of the LCD. If you can't scan "bands", meaning all frequencies between 25-54, 118-174 & 406-512 Mhz, you may be stuck in the "capture" mode. Let me know if this is the case (not likely) & I'll coach you through it.
2. No.
3. No.
Sep 29, 2008 | Uniden BC72XLT Handheld Scanner
Uniden BC72XLT Handheld Scanner Logo
102 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
