Even after unchecking ''the battery icon to show on task bar'' it keeps apperaing at startup all the time. How can I turn it off and repair it for normal use? I am using Win XPSP2 on a desktop, normal use.. Thank you in advance!
  • csabcee Feb 26, 2009
    Hi pal, thanks, but by only starting the XP is "dialog startup" and once restarted, restore "normal startup" - actually without changing anything - did not solve the problem.. what did I do wrong?
    Another thing caused by a trojan qhos - already cleared: windows autoupdate is blocked now, I have found a "solution" as a repair.cmd, but after 2-3 restarts, the problem is there again.. any idea?
    Many thanks in advance!
  • 3 Answers
Hi dear, do one thing click start menu-- and tupe msconfig on run command and press enter. then a dialog box wil displayed. In the general tab select Diagnostic startup and click oK. it will ask for restart. Let it restart. Dont wory if you do not here any sound or theme after restart. Then perform same steps and this time select Normal Startup from that dialog box. This will surely help you.
Posted on Feb 26, 2009
My volume icon on the task bar has disappeared, how do I get it back
Open the TASK MANAGER, open the PROCESSES tab, highlight "explorer.exe", click on "end process", Open "file", "New Task", Type "explorer" without quotation marks. OR Control Panel, Sound, depending on your OS, You will find a box to show tray icon. If it is checked, uncheck, apply, then check, apply. The Task Manager will remove stored icons that fill the program, and restart the icons.
Nov 28, 2012 | Dell Inspiron 1501 Laptop
IM box will not appear
The system tray (in short: systray, nowadays also called taskbar notification area) is the icon strip normally located near the right end of the task bar, next to the clock.
Some Windows XP installations show a peculiar defect in that some systray icons disappear or, rather, do not appear, when the system is booted and the user logs on. The problem is even more prevalent on systems with autologon. The most frequently affected icons seem to be the speaker icon (sound volume) and the power/energy icon.
This has nothing to do with the hide inactive icons settings. The defect shows up when you don't have any icons set for hiding.
In any case, please make sure for now that you haven't activated that setting. Right-click the task bar, click on Properties, uncheck the last check box. You can reactivate it later if all other problems are identified or solved.
Check your Startup folder and the starter registry entries through Start, Run..., type: msconfig, press Enter, to check whether the programs are really started at system start, or use Task Manager (Ctrl + Shift + Esc) to see whether the processes are running.
Jul 03, 2010 | Yahoo Messenger
No icons or tool bar on desktop at startup
In your desktop, Right click your mouse and properties will show and look for show desktop option. And then move your mouse to the bottom of your computer screen, if toolbar will show, then your toolbar is set to automatic hide. Change the settings in your Taskbar and Start Menu Properties and change there the settings, uncheck the auto hide task bar.
Nov 10, 2009 | Acer LX.W530X.012 Gateway M7325u 15.4in...
Ok on my macbook pro it seems to have locked up i see the task bar but the icons or nothing else will show up any soulution?i tried apple option esc but nothing showed up. it seems to lock up where i can...
Hello
This can be hardware or software related...
If you can see the dock, it means that the system started up with success, but had a hard time to get your account running.
You should try these:
- Press the shift key at startup for 15 seconds at the startup chime). this will check your hard drive, and deactivate extensions. it will ask for your password.
- If you see your desktop, and the apple, then go to the apple menu - system preferences - accounts -startup items tab. Delete all the startup items
- If it did nothing, the you should try to boot from your OS DVD pressing the c key at startup, abd repair the disk's permissions here
- At last, reinstall your system, choosing the "archive and install" option when requested
Hope this helps
Jul 13, 2009 | Apple MacBook Pro Notebook
Icons and start upmenu bar absent
explorer.exe is what displays the icons and the startup bar on the screen so try opening explorer.exe from the task manager. Or if it is already running close it and then reopen it.
Jun 08, 2009 | Computers & Internet
Explorer doesn't start
go to Start > Run > msconfig
In General tab
make sure you are set to Normal Startup.
Mar 18, 2009 | Microsoft Windows XP Professional SP2 for...
Disappearing icons in notification area of taskbar
Open task bar properties, from control panel, choose taskbar and start menu. Uncheck the check box at the bottom of the window.
Dec 11, 2008 | Microsoft Windows Vista Home Premium with...
Start Task bar not showing
Press the Windows key to open the Start menu, then right-click the start button and choose properties.
Next, go to the task bar tab and
1. Uncheck auto-hide
2. Check keep task bar on top of other windows
Dec 11, 2008 | Computers & Internet
Dear Sirs I have just insalled the SimpleCenter media but I do not want the icon to automatically load onto the task bar on the right hand side,although I would like the shortcut to remain. I can delete...
You cannot delete the icon from the task bar as it only displays the start up programs running on the computer. I have given the steps below.
Click start, than click run. In this box type "msconfig" without quotes.
You will see the list of startup programs. Uncheck the ones related to the Simple center Media.
Click Aply, Than click close, than click Restart computer now.
The program will not load automatically and you would not see the icon in the taskbar.
I am sure this will help. Please update me on the same.
Regards,
Sammy
On Top of the window click startup
Jul 10, 2008 | Computers & Internet
Taskbar and Desktop icons flash/flicker on and off and don't allow her to open the Start menu or click any of the icons
restart computer and keep tappig F8 when
select safe mode from advance menu
*select win xp os
*get into safe mode and check
if u dont have any issue
then click on start->run->msconfig
click on selective startup
uncheck load startup items
click applay
click close
reboot and chack
if same problem
reboot computerr in safe mode
create new user acount
Feb 18, 2008 | Lenovo 3000 C200 Notebook
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
