Question about Bosch Axxis WFL 2060 Front Load Washer
My Bosch Axxis WFL pump drain blocked. I had a
My Bosch Axxis WFL pump drain blocked. I had a service man try to work on the machine. He was so frustrated that he and all service men in Hays KS refuse to work on Bosch washing machines. Bosch will not send me a service manual. How can I get a service manual so that I can make the repair myself?
  • 1 more comment
  • BaileyK May 09, 2009
    Do you have the "Service" manual that a service tech would use to troubleshoot and fix this issue?
    I just purchased a used on and after each load I have to use the small drain hose. There is nothing that I can see in the pump housing by unscrewing the plug.
    Can anyone help with this please????
  • kvdncd
    kvdncd Nov 15, 2012
    I had a similar problem and found orthodontic rubber bands wound around the pump impeller shaft. It was a major pain to get them out of that pump because of its depth but it did fix the problem.
  • Anonymous Mar 18, 2014
    how do you change a drain pump on a bosch 300 washing machine
  • 6,784 Answers
Hi there, i have prepared two links. The first one is the original manual you requested and the second link refers to the quick reference guide.
Click here for the first link to your original manual.
Click here for the quick reference guide.
Posted on Feb 25, 2009
  • 2xlbu4u Apr 16, 2011
    These are the user manuals and not the service manuals. We need the tech internals, exploded diagram, etc
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
The pump is not pumping water when in drain cycle and "Pump Blocked?" error is displayed. The washer has been drained and the pump cleared of debris (penny, toothpick and two small rectangular...
Hello & Welcome to FixYa
If you have cleaned it completely and nothing is blocking the drain pump assembly then it means that the drain pump is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Jul 25, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 won't spin or drain. Still full of water
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Mar 05, 2011 | Bosch Axxis WFL 2060 Front Load Washer
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
2nd Bosch washing machine same problem
Since you faced the same problems with two new machine's, it sound like a manufacturer problem and you should ask for another new washer or to get your money back !!!! Good luck !!!
Aug 18, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
Jun 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
1,749 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
