Question about RTO Forward Reverse Drive Gears:Mgt
No reverse i have a 1990 dodge caravan my reverse went out can i fix it easy or is my transmission going out?
  • Rick Wymer
    Rick Wymer May 11, 2010
    Auto or Manual?
  • 30 Answers
Well depends on how good of a mechanic you are. The reverse can be replaced. however the transaxle has to be removed. and you went that far... so logically you'd repair the whole thing. a catalog that you can get for free is called Northern Parts. They are out of Iowa. good stuff and offer lots of diffrent stuff and tranny kits inexpensive. (NOT cheap) thats for the parts companies with stuff made in china. Or call a auto salvage yard and see if they have a used one.
Posted on Apr 05, 2009
Wont go in to reverse and sometimes wont go in to drive SECOND TRANSMISSION ISSUE
Dec 27, 2009 - This time around, the check-engine light came on, and while driving on the ..... my dodge caravan wont go in reverse and only a few feet forward tranny shot i will go ... I have a 1992 Dodge Grand Caravan 3.3L 4-speed xmission. ..... having shifting issues sometimes shifts fine other times I have to cut van off ...
No Reverse - The Chrysler Minivan Fan Club Forums
Nov 21, 2010 - 10 posts - ‎1 author
BTW, I have driven it all summer, over 7k miles with no reverse; I just park up hill or in a drive-thru spot! ... 1992 S-10/4.3L V6/249K mi/original 4L60E ... I had a '90 Grand Caravan w/3.3 and same trans. rebuilt at 120k by AAMCO ... I've decided to drive it until the forward gears go out before I pay for a rebuild ...
10 Most Common Transmission Problems
Ever notice that while driving that the car hesitates or refuses to go into gear? ... that needs to be replaced, but may sometimes point to a more severe problem. ... If the carwill not shift after engaging the clutch and trying to move the stick, take a .... This is a problem because in park a dodge dose not run the the transmission ...
Transmission May Fail Causing Slipping in First or Reverse ... > Problems > Dodge > Caravan
Jan 27, 2016 | 1992 Dodge Caravan
  • What has happened is your transmission solenoid pack has gone bad. Not to worry, this is an easy fix.
  1. You need to purchase a transmission solenoid pack and a gasket.
  2. You can take your chances with a salvage yard or you can get one off of e-bay for about half of what the dealer will charge you or you can go to the dealer.
  3. Pop your hood and look on the top of the transmission. That little black box is the transmission solenoid.
  4. Clean the area around the solenoid real well with a shop rag.
  5. Remove the connector hooked onto the solenoid.
  6. You may have a linkage to pop off.
  7. Now remove the long bolts holding it into the transmission.
  8. Now wiggle the solenoid out.
  9. Reverse to finish.
  • That's it. Real easy fix for this vehicle.
Regards, Tony
Apr 27, 2011 | 2002 Dodge Grand Caravan
1990 Dodge Grand Caravan Tach, fuel gage, volt meter gauges not working,and dash lights, radio went out and check gauge light came on. At this time it downshifted to 2nd gear and remained until dash lights...
Dam you need a EXORCISM!
No just a loose connection in the dash.
Sounds easy right!
IF you are lucky it may be the main plug not seated into the dash board. Or a bad ire in that connector.
Jan 05, 2018 | 1990 Dodge Grand Caravan
1990 dodge varavan will not go into reverse
It is more then likely either a solenoid or a clutch pack. If you hear a bump and then nothing when you shift, it is probably the clutch pack, if nothing happens, it is more then likely the solenoid. The bad news, it will require a rebuild either way. Reverse gears are some of the hardest to change, and especially on that transmission, it will be quite a process to repair.
Jul 12, 2009 | Mitsubishi Minivan Cars & Trucks
My 1995 dodge caravan needs warmed before going into reverse
Trans is internally worn and only sealing properly when parts are hot. I would change fluid and filter just to be sure pressure loss is not from filter but if it does not improve, start saving up for a rebuild.
Jun 16, 2009 | 1995 Dodge Caravan
1997 Dodge Caravan "Back Up" Lights Do Not Come On
Welcome to FY
Check the reverse light switch located on the transmission. It is located by the shift lever housing on the transmission.
also there is a 10 amp fuse in your power distribution center for this too.
Jan 11, 2009 | 1997 Dodge Caravan
Transmission Died
sounds like the bands or gears in the transmisson went bad so youll need to replace the transmissions
Nov 17, 2008 | 1999 Dodge Caravan
RTO Forward Reverse Drive Gears:Mgt Logo
119 people viewed this question
Top RTO Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
