Question about Epson Stylus C86 InkJet Printer
Printer "works" but page is blank, no printing. Words are not going from computer to printer. Epson C86. Ink cartridge is new. This happened after I cleared a paper jam.
  • 353 Answers
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of black ink? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Posted on Feb 28, 2009
Epson Stylus C86 printing blank pages.
Ensure the proper procedures for installing an ink cartridge was done. Next, perform at least two cleaning cycles (hold down the ALT and the Pause button on the printer panel to initiate a cleaning cycle). Print out the demonstration page (press the ALT button while applying Power). If the problem persists and there is no improvement, take the printer to an Epson Authorized Service Center.
Oct 28, 2010 | Epson Stylus C86 InkJet Printer
Ive changed all the ink cartridges in the sylus dx7400, but it will not print the black ink, and the colour sheets have lines all the way through the page.ive rechecked the cartridges, but the black still...
Did you Change to Genuine Print Cartridges.????
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 21, 2010 | Epson Stylus C86 InkJet Printer
All blank pages when printing, new ink installed
You may not used the printer for a long time (1 week). The heads may be blocked. run the head cleaning utility.
Jan 08, 2010 | Epson Stylus C86 InkJet Printer
Using Epson c86 printer. black Ink dots appear
It may be caused by waste ink at bottom plate of head. Print blank pages about 10.
Nov 12, 2009 | Epson Stylus C86 InkJet Printer
All new ink cartiridges and pages come out blank now
please follow these steps:
1. reseat all of the ink cartridges
2. perform a cleaning cycle using your computers maintenance options
if you are using windows go to the control panel then look for the printers and faxes folder, right click on the icon of your specified printer then left click go to printing preferences.
on printing preferences click on the tab for maintenance then look for head cleaning. do it for 3 to 5 times then test by printing nozzle check
if it does not work the possiblity is that the nozzles might have been clogged with dried inks. try spraying it with wd40 then let it dry for 3 to 4 hrs then print.
take note that doing the head cleaning you can take a considerable amount of your inks
Sep 23, 2009 | Epson Stylus C86 InkJet Printer
Blank printing
If you have already done head cleaning and nozzle check 3 consecutive times from the computer and has tried reseating all the ink cartridges and it still acts likes its printing but just prints out a blank page chances are your product already has a hardware issue. If you product is still within the 1-year warranty period from date it was purchased, I suggest that you contact Epson tech support for more options otherwise, you would need to get the product repaired by servicer located in your area. To locate a servicer click on this link http://www.epson.com/cgi-bin/Store/support/SuppProductSearch.jsp?BV_UseBVCookie=yes
Jun 24, 2008 | Epson Stylus C86 InkJet Printer
Epson printing not printing
If you have already tried 3 consecutive head cleanings and nozzle check from the computer, tried reseating the inks and tried replacing the ink and it still acts like its printing but just provides a blank page chance are your printer already has hardware issue. The ink delivery system is already clogged. If your printer is still within the 1-year warranty period I suggest that you call Epson Tech support for more options otherwise, you would need to get the product repaired by an Epson certified service center. To locate a servicer in your area click on the link http://www.epson.com/cgi-bin/Store/support/SuppProductSearch.jsp?BV_UseBVCookie=yes
Jun 03, 2008 | Epson Stylus C86 InkJet Printer
Printer not printing
I hate Epson. Had problems with Stylus C82 and now my replacement Stylus C86 has given me nothing but trouble.
I've just replaced all four ink cartridges and now when I print I'm only getting blank pages. I uninstalled, reinstalled, and nothing is working. I even called Epson, twice, only to be routed to the Phillipines where neither person was very helpful, in fact, had a hard time understanding their English. So this is what I;m going to do. I'm taking this bloody Stylus C86 outside and smash it with a hammer..then I'm going to buy a HR Printer...and if anybody from Epson reads this...good luck...your products SUCK!!
Nov 04, 2007 | Epson Stylus C86 InkJet Printer
No ink on pages
Jeanne: I have the same problem. Seems to have begun after I tried putting the printer on a wireless network. That didn't work, and now, neither does the printer. I downloaded new drivers, in addition to running the utilities. If you want to try that, go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=41661&prodoid=46048263&infoType=Downloads&platform=All Please let me know if you have had any luck finding a fix for you C86. Sorry about the accidental rhyme. This ain't no laughing matter. windwing@sbcglobal.net
Sep 18, 2006 | Epson Stylus C86 InkJet Printer
My Epson 680 Printer only gives me blank pages
First of all, there is the seller's liability here. If it's from eBay, there's some protection feature for you to use. The "prints blank pages" problem is believed to be caused by a clogged purge tube. Here is a guide I found that exlpains the problem, and how to solve it: Recently, after changing out the blank ink tank on my finacee's Epson CX5400 multifunction inkjet printer, the printer began printing nothing but blank pages. Even after doing multiple head cleanings and test prints, pages would emerge from the printer completely blank. After some research, a number of fellow CX5400 owners have reported having the same problems, to the extent that the term "design flaw" became a common theme. I've owned several Epson printers and have had, generally, good luck with them. I was always somewhat suspicious of Epson's philosophy of making the print heads a permanent part of the printer and having the only replaceable part be the ink tanks, but it produced good-looking prints so it didn't bother me. Now I know, unfortunately, that this system is both a blessing and a curse. Before we delve into how to fix your blank-page-printing problem, a quick explanation on how Epson's ink delivery system works (or, rather, how it appears Epson's ink delivery system works, because Epson isn't exactly willing to divulge its trade secrets) is in order. There are a few components to the delivery system. First, you have the ink tanks. Early Epson tanks were just that; plastic boxes with a sponge inside saturated with ink. Newer tanks have a small PCB with a flash chip on it, so the printer can tell if a tank is new or used, or if it's an Epson brand cartridge or a generic replacement. In either case, the basic functionality is that it's a holder for the ink. Next in the chain are the ink tubes and primer. I've heard conflicting reports on how Epson printers get the ink out of the tanks; some believe that the tanks are positively pressurized when first installed, so that ink shoots out of the tank when the printer needs it. Other reports say that the printer puts negative pressure on the cartridge to draw ink out of it. Once the printer has the ink out of the cartridge, there are two places it can go, to either the print heads or to the purge tube. The print heads are what makes the ink spray onto the paper; the purge tube is where the ink goes when the printer primes new cartridges and cleans dirty print heads. Many cases of the "prints blank pages" problem occur right after installing new ink tanks. People have literally removed empty tanks from printers that work perfectly, and installed new tanks to find that the printer delivers blank pages (this happened to me). Since it's highly unlikely that the print heads have become clogged during the 5 minutes it takes to swap out the cartridges, the problem has to be elsewhere in the ink delivery system. So here's what happens when you install a new ink tank: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The ink flows through the purge tube into the internal absorbent pad. 4. After a couple seconds, the printer stops the priming sequence and probably does a quick print head cleaning. Now, a few people have done some in-depth troubleshooting and found that the "prints blank pages" problem is actually caused by a clogged purge tube. While this may not immediately make sense (you may be thinking, "so what if the tube is clogged, the ink will just spill inside the printer elsewhere"), here's what my research suggests happens when the problem occurs: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The tube is blocked, so the ink has nowhere to go. 4. After a couple seconds, the printer stops the priming sequence. Epson's ink delivery system appears to be a sealed system, so when the ink has nowhere to go in step 3, little ink has actually escaped the new ink tanks. This means they're not primed correctly, and won't deliver ink as they need to when the printer goes to print. So unless the purge tube gets cleaned out, you can swap tanks and perform head cleanings until the cows come home and it won't do any good. Now that there's a basic understanding of what's going on, here's how to try to fix the problem. This guide is meant to be model-agnostic; I did this procedure to a Stylus CX5400 multifunction, but it should be similar for most Epson inkjets made in the past few years. It's unknown if new Epsons still have this problem, as it usually takes a year or more to surface. The first thing you need to do is prepare your work surface. You'll need a big table, preferably one you don't care too much about. If all you have is your good kitchen table, then it's a good idea to slice open a tall kitchen garbage bag to make one large sheet, and tape it to the table to protect it. Next, you'll need the following tools and supplies: (View attached picture)
Jun 21, 2006 | Epson Stylus 680 InkJet Color Printer
Epson Stylus C86 InkJet Printer Logo
85 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
