Question about Poulan Garden
Poulan micro xxv wich will run for 5 mins then flood but why?
Please can any one help i have a poulan micro xxv wich will run for 5 mins then flood but why?
Clean out the vents on your fuel cap. you may also have sawdust or dirt stuck on the diaphragm in the carburator
Posted on Feb 25, 2009
Trying to find a service manual for this. can you assist? thanks
Hi Linda:
Here's a link that will get a lot of sites where you may be able to get the manual. Just click on it.
Hope this helps.
Keep those old machines running!
Apr 02, 2016 | Poulan Micro Xxv Vintage Chainsaw Coil...
We need a manual to help replace the fuel line on a Poulan Deluxe Super 25
You do not need a manual; exactly like the video that follows:
No primer or second carburetor connection. Be kind to the oil pump; they are no longer available.
All fuel components are on the "Ignition, Electrical & Flywheel" print here (filter and hose are available):
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Thank You for using FixYa.
May 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Micro Super XXV Deluxe S250?
Just like the video:
Fuel Line Replacement by
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best. Fuel components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Apr 26, 2010 | Garden
Will not run new fuel lines but does not crank, poulan micro xxv
I suspect hose routing may be in error. Is it like this?
If it is, please reply below and we will continue with an attempted repair. I hope you found this most helpful.
Jan 30, 2010 | Poulan Garden
I have poulan micro xxv chain not being oil when
wow thats an oldie, That saw uses a diaphragm pump located just above and in front of the clutch drum. Its going tobe hard to find one if its bad, Try cleaning out the oiler hole in the bar first, Then try running the saw without the bar and chain on and see if it pumps.Also check the oil pickup tube in the tank, It has a small screen on the end of it thats prone to sawdust clogging it. If it still does not oil then I suggest you locate the gasket and diaphragm for the pump before you take it apart. Remember to clean everything before reassembling,, Good luck
Dec 15, 2009 | Poulan Garden
Need to know gas oil ratio on poulan micro xxv deluxe
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
Oct 08, 2009 | Poulan Garden
Poulan micro xxv 25 yesterday i started the saw ran fine.tryed today would not gas and spark.loosenthe gas cap firer but would not stay running.thank you.
i'll bet you have it flooded. Try a dry sparkplug. pull it over a few times with the plug out to help dry the cylinder out too
Aug 13, 2009 | Poulan Garden
Looking for a workshop manual for a poulan micro xxv deluxe Thank you
This is "POULAN-WEED-EATER" and your model number"Micro xxv" XXV Gas Saw&AFID=59
Aug 04, 2009 | Garden
Garden Logo
471 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
