Question about Frigidaire FRS23R4A Side by Side Refrigerator
Icemaker fill tube keeps freezing up.
The fill tube or chute keeps freezing up blocking the water from filling the icemaker .
  • 4 Answers
The reason your fill tube to the icemaker is freezing up time and time again is simply the valve, or valves (water valves) that dispense water to the door and icemaker. It most likely always is the icemaker side because it is always harvesting ice and it gets used the most. The only way to stop this is to replace the water valves almost always located in the rear of the Refrigerator with the supply line coming off the wall the valves with one or two electric plugs that energize the solinoid type valve when unit calls for water. Tired of getting out the hair dryer and melting the ice that plugs up the fill tube? This is the only solution. Some of the time is because lime, or other deposits in the water will not allow the plunger to rest in the complete closed position. When the valve is energized for the amount of time needed it lifts the plunger allowing water to flow through. Then when it goes back down
to the closed position it has a small gap that causes water to seep through. There you have it! It's fixed! Unplug unit before replacing valves.If you have a double valve system make sure your lines go back to the original spot. Some of them have a 1/4" line with plastic compression fitting for the icemaker and a 3/8" for the water at the door. Some have both 1/4" compression fittings coming out like "Amana" so once again, make sure to get all lines back to the same possition. Free info. from-
Randy Browne
Appliance Installtion & Repair
San Antonio, Tx. 78209
210-822-1818/210-493-2700, cell# 210-264-1471
Posted on Feb 26, 2009
Tip
ICEMAKER SPLATTERING WATER ALL OVER FREEZER
THE FILL TUBE IN BACK OF FREEZER TO ICEMAKER CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
on Jul 27, 2011 | Refrigerators
Icemaker keeps freezing up after a couple of weeks of using then it becomes clogged with frozen ice int mechanical part of the icemaker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 06, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icicle are forming around icemaker port inside of
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 17, 2009 | Kenmore 53542 / 53544 Side by Side...
Icemaker does not fill with water
Pour about 1/2 cup of water into icemaker . If it freezes and dumps , replace the water valve ( the piece the wall water line connects to ) . If it doesn't dump after freezing , replace the icemaker . Also check the tube inside which delivers water into the icemaker to be sure it isn't blocked with ice . If it is , replace the water valve . Make sure the coils below fridge are clean of dust , lint , pet hair , etc..as this will slow ice production .
Aug 21, 2009 | Kenmore Refrigerators
No water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Jan 04, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Icemaker water line freezes
it is probably a faulty water valve that slowly leaks water up to the icemaker and freezing. sometimes it will freeze inside the fill tube and block the water supply completely.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
THE LINE THAT FILLS THE ICE MAKER KEEPS FREEZING WHERE IT COMES INTO THE BACK OF THE FREEZER WHAT CAN I DO
change the water valve on the back of the machine. the valve is very slowly leaking water up to the icemaker and freezing in the tube eventually blocking all water from going to the icemaker.
Aug 01, 2008 | GE Refrigerators
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire FRS23R4A Side by Side Refrigerator Logo
4,294 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
