Question about Panasonic SC-HT730 System
I have a panasonic ht730 home theatre system. distorted sound
System is only 2 years old, all5 speakers are distorted and worse as you turn up sound. applies to all tv, dvd run through it????????
  • Jim Bay May 11, 2010
    Has this always been the case or is it getting worse over time?
  • 4,234 Answers
If the sound is distorted and is effected by the volume control, the problem is in the "front end". This is not a common problem, but is significantly less expensive to fix than the output section. Try turning off any surround mode and run the unit in plain stereo. Does the distortion still occur? I suspect that it will not. Update this with that info and I should be able to list the probable parts that need to be replaced.
Dan
Posted on Feb 25, 2009
Panasonic SC-HT730 home theatre has no centre or surround audio. Front right and left work, nothing else. What could it be?
First thing is to check the wiring. a simple flipping of the positive and negative at the back of the theater box can fix this. I know they have the color coded wires and suppose to be plug and play but I see these reversed all the time right from the factory. If that does not work repost and I will follow up.
Nov 12, 2012 | Panasonic SC-HT730 System
Hi I have just purchased a Panasonic Plasma TV and Panasonic home theatre. Everything works well except for I cannot get sound coming out of the home theatre when watching normal TV. I purchased the...
Try running the audio from each video source (NOT the TV, which is an output, not a source) to the HTR digitally so you'll get the best mutichannel sound possible. Then you can turn the TV speakers (assuming it has them) off for hi-end watching.
Aug 15, 2010 | Panasonic Audio Players & Recorders
GREEN TINT TO ALL DVD'S PLAYED
Your red component cable needs replaced or your red component input in either your DVD player or TV needs replaced.
Jun 13, 2009 | Panasonic SC-HT730 System
Panasonic SC-HT70 Home Theatre - No sound on front right speaker
Normally this is a failure of the output amp section which is a single amp-pac. This part is available using the part number: RSN311W64D-P for about $95.20 and can be easily changed by anyone with audio repair experience. Add in your local repair labor rate for the total repair cost.
Dan
Jan 05, 2009 | Panasonic SC-HT70 System
Power issues: will not turn off or function
Unplug all of the speakers and power on.Its possible that one of the speakers is causing the protection circuit to activate.If powered on and subwoofer works start reconnecting one speaker at a time( after powered off) and retest each time.One Speaker may be bad.Its also possible the output ic is failing under a speaker load.There are no fuses related to this issue.If its not a speaker problem then the subwoofer will need to be serviced.
Feb 24, 2008 | Panasonic SC-HT730 System
Home theatre but TV without audio outlet
I would suggest that you smash
Philips HTS w/a hammer!
I had better sound from TV alone! Only 2 speakers put out sound from TV. Recordings from DVR can not be heard very well w/all volumes at max. System sucks! You get what you pay for! $2500 LCD TV sounds worse w/Philips HTS than my son's $300 TV! ALL cables hooked up as instucted!!!!
Dec 17, 2007 | Audio Players & Recorders
Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Dec 14, 2007 | Panasonic SC-HT720 System
SA-HT730
Fixed Mine!!!!
My Home theatre started to do the same thing today and I manged to get it going again by reseting the ratings password and changing the batteries in my remote. Oddly enough, I have never set a ratings password so I suspect the batteries caused the issue. Seems to be back to normal. Instructions for the reset are in the manual. Here's a link to the online one at Panasonics website http://service.us.panasonic.com/OPERMANPDF/SAHT730.PDF
Nov 08, 2007 | Panasonic SC-HT730 System
No sound, subwoofer or speakers
Er so you plug the speakers into anther system and they work? Blindingly obvious but there is no fault with the speakers.
Oct 06, 2007 | Panasonic SC-HT730 System
Panasonic SC-HT730 System Logo
125 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Michael Kovalik III
Michael Kovalik III
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
