Question about Philips 9P5544C 55" Rear Projection Television
Can't seem to get the color +'s to line up, print on arc
No movement for the lense to line-up + lines, and all rpints look on a arc Help please, used the front buttons no luck. Used the remote no like either help please. Daneen
Your chips are burned out, had the same problem with mine cost about $200 to fix.
Posted on Jun 21, 2009
  • unciviliz_ed Jun 21, 2009
    your chips are burned out, had the same problem with mine cost about $200 to fix.
Hi folks! I have a Viewsonic PJ400 projector. He
Which "lenses" did you clean inside the unit. It would seem that you have misalignment of the lcd panels or the phase setting may need adjusting. What input are you using and what vertical frequency is the signal using?
Jun 30, 2011 | Office Equipment & Supplies
It prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways. The printer seems fine and...
it prints fine using the new hp 15 black ink cartridge. But when I print with the new color 17 cartridge, it comes out with uneven 'cross lines' of color, like sliced sideways.
Jan 16, 2010 | Apple HP DeskJet 840c InkJet Printer
Green color is like a arc how to fix it,red color is fine blu color is fine just the green is like move out the line but like a arc no straith line like curb up how i bend the green dow so can be line up...
There is a problem with one or possibly both of your convergence amplifier IC's. They both handle some of the green convergence. It should not be extremely costly to have repaired. Do have a technician check it out. Convergence adjustments are tricky. Thanks for using fixya.
Dec 25, 2009 | Philips 60PP9200D Television
Printer creating white lines that distort output
Hello loyasq,
You should do :
1st; Try to fix that by the device's Appliaction
smthing like that
2nd; Uninstall every application for this device and re-install it again.
3rd; If your printer have 1 Cartridge for all colors, Cleanse the part of ink output (the nozzle of ink cartridge) with wet tissue.
Thx for using FixYa.
Apr 15, 2009 | Dell Photo 964 All-In-One InkJet Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Problem with printing smoothly
Hi morshi. I found a potential solution to your problem with your 5610 printing vertical lines at HP.com:
Vertical black lines or streaks
It's hard to tell from the rest of your message what other problems you're describing. I did find a troubleshooting page at HP that shows how to address general print quality problems:
Problem with quality of copies
If those links don't solve all of your problems, the Color printing issues page for the 5610 at HP has numerous other solutions:
I know the name of that last link may seem misleading since you haven't described color printing issues, but the links on that page offer different general print problems and their solutions.
Good luck.
Sep 30, 2008 | HP Officejet 5610 All-In-One InkJet...
Ink in printer
did you do a test page? maybe you need to clean and calibrate them?
Apr 28, 2008 | Lexmark X75 All-In-One InkJet Printer
Problems with Color printing
Click Start - All programs - HP - HP Solution center.
Click Settings - Print settings - Printer settings
Click on the Features tab. Set the print quality to best. Click on the Colors tab. Under color management - Enable the option Managed by Application. Click OK . close solution center. Try to print.
Dec 22, 2007 | HP Photosmart C3180 All-In-One InkJet...
Small lines or specks on the right side of every page
Did you try cleaning the lense? You'll have to pull all the toners and open the little door below and wipe with a clean lint free cloth in ONE direction.
Nov 10, 2007 | Lexmark C510 Laser Printer
Philips 9P5544C 55" Rear Projection Television Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
