Question about HP OfficeJet 6110 All-In-One InkJet Printer
Scan save problem
HP 7280, just installed.
On the printer, scan to compute, Message :No scan options
From computer, HP resolution center, save scan doc to file, error message: 8,[(8,106,0)]
  • 25 Answers
Not sure if this will work however put the printer CD in the carriage (cancel the auto start). Then do your scan etc... as you normally would. My HP 6110 for some reason will not always see/grab all of the scanner files on an install. If the CD is in the carriage your scanner MAY see and grab them off of the CD when it actually needs them. If that works for you it should continue to work.
Hope that helps
Posted on Mar 01, 2009
  • 3 Answers
Same thing drove me nuts at first. You must set up where things go using the software on your computer. It's the "HP Solution Center" that you probably thought you would never need; you need it to set up EVERYTHING! You use it all the time. Wish they would tell us that. Once you have things set up the way you want, the menus on the LCD screen will then come alive. Good luck
Posted on May 11, 2009
How to scan pictures using ho f2480
When scanning with HP Solution Center, you can scan a photo or a document, but HP Solution Center does not save the scan to your designated folder. The Scan button on the product's control panel might not operate correctly. This issue occurs in Windows 7, or when using a version 13 print driver in Windows XP or Vista. Solution HP has created a patch to update your driver and resolve the issue.
  1. Right-click this link,(HP Scan Patch) link ftp://ftp.hp.com/pub/printers/scanbh/CPEScanPatch_hpcom_000_001.exe , and then click Open in New Window . A File Download window opens.
  2. Choose one of the following options to download the patch to the computer.
    • If you want to install the patch on the computer immediately, click Run . NOTE: Click Run again if the computer displays a Security Warning message.
    • If you want to install the patch at a later time, click Save , select a destination on the computer for the file to save, and then click Save . When the download is complete, click the downloaded file.
  3. Follow the on-screen instructions to install the patch.
Cause When installing or upgrading to HP Solution Center version 13, files do not install correctly.
Nov 27, 2010 | HP Computers & Internet
When trying to scan to my HP J4580 Officejet J4580 All-in-One printer it says "No scan options, refer to device documentation". What does this mean?
It means you need the HP scanning software running on your computer. The computer tells the scanner how to scan, what to scan and where to save the image after scanning. The scanner has no options until received from your computer.
Feb 09, 2010 | HP OfficeJet J4580 All-In-One Laser...
How do I scan something from my wireless printer to my computer
There are two options.
Option 1
Make sure your computer is on. Insert the document you want to scan. Click on the scan button on the printer. The document will automatically be scanned and saved in your computer in mydocument under mypicture->my scans folder.
Option 2
Insert the document which you want to scan in the scanner. From your computer invoke HP Solutions Center. There you will see options to scan the document.
Please note for both the options you must have installed all the softwares which came with your printer.
Nov 20, 2009 | HP Photosmart C4580 All-in-One InkJet...
"no scan options error" appeared
Try ths:
This happens mainly when you try to scan from the printer ;
Always try to scan from HP solution center but still here is the resolution:
Open Hp Solution center
Click on Settings
Click on scn settings
click on Scan to Setup
Select all the option available to updrade the Front panel menu list and click on ADD
Click on Update;
Restart the computer and the printer and try to scan.
It should resolve the issue.
Regards Soumajit
Jul 16, 2009 | HP Photosmart 3310 Printer
No Scan Options
Try ths:
the resolution:
Click on Settings
Click on Update;
Regards Soumajit
Mar 31, 2009 | HP Officejet 5610 All-In-One InkJet...
Scanning
This message will come up when you are scanning from the Stand alone printer not from the computer.
If the software is sucessfully installed in your computer,
Then you should have a icon which says HP Director / HP Solution Center (If not Goto> Start> All Programs> HP and then you will see them
Open HP Director/Solution Center and try scanning from there, It should scan from there.
If yes then go to settings> Scann Settings> Scan to setup> There you see an option which says Front panel Destination list> Click that and there you see a options says Restore Defaults> Click that> then Apply and Ok> And close all the indows and try scanning from the All-In-One.
If it does not work then try the steps bellow:
Go To:
My computer>C:windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:>windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Sep 10, 2008 | HP Officejet 5610 All-In-One InkJet...
No Scan Options for HP Oficejet 6310
This is a resolution for "NO SCAN OPTIONS" in the front panel screen of the All-In-One Only:
If you are getting this message when you are trying to scan from the All-In-One.
And If the software is successfully installed in your computer, then you should have a icon in your desktop as HP Solution (if not got to Start> All Programs> HP> HP Solution Center) Then try scanning from there, if you are able to scan from there then try the steps bellow.
Open solution center> Settings> Scan settings> Scan to setup> Then in this window click on Restore defaults> Then apply or ok and close all the windows and try to scan from the All-In-One printer.
If it still does not work then try the bellow steps:
Go to:
Copy hpzipm12
Copy hpzinw12
Copy hpqtra08
close this window
Tried to scan.
Good Luck
Sep 03, 2008 | HP OfficeJet 6310 All-in-One Printer...
The scanner dont work in my HP officejet 5610 all in one
This is a known issue with HP printers. Do not worry, if you get this message that the scanning software could not be found the please go to the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Select the Operating System.
From the list select. ... HP Full Feature Software and Drivers
Then scroll down to the 3rd option......
Click on Download only >> Save the file to the desktop.
Start installation and make sure that the Printer is not connected using the USB cable to the computer.
While installing, you will get the option to connect the printer. Do not connect the printer.
Select the option "I will connect it later". Go next the installation will be complete.
After the installation is complete...leave the CD inside the computer.
Connect the computer and the printer.
It will show you the configuration window.
Wait until you see the "Start using the device" option.
Click on "Start using the device".
You should see the solution center window now.
If it is succesfull. Try scanning using the Solution center.
If it is succesfull, you can now scan using the printer as well.
Try it and let me know if it works and please let me know your issue in detail.
Aug 03, 2008 | HP Officejet 5610 All-In-One InkJet...
Can not scan to computer
hi,
below are the steps that i want you to follow. The "NO SCAN OPTIONS" refer to the absence of options when you try to scan using the printer button your printer. However, if you are going to scan from the SOlution center installed in your computer, it will scan without any problem.
Step two: Populate the destination list The destination list must be populated in order for the Scan To function to work. Follow these steps to populate the destination list.
  1. Open the HP Solution Center. Use one of the following methods to open the HP Solution Center.
    • On the Windows desktop, double-click the HP Solution Center icon.
    • On the taskbar, click Start , Programs , or All Programs , click HP , and then click HP Solution Center .
    If more than one HP device is installed, click the tab for the All-in-One product. The HP Solution Center shows only the functions, settings, and support options that are appropriate for the selected HP product.
  2. Click Settings .
  3. Click Scan Settings and Preferences .
  4. Click Scan to... Setup .
  5. Click the Destination List tab.
    NOTE: Depending on the computer performance, it can take several minutes for the Front Panel Destination List to populate after the printer or computer is turned on.
  6. If the Front Panel Destination List is empty, continue with this procedure. If the Front Panel Destination List contains valid scan destinations, proceed to step three to uninstall and reinstall the software.
  7. Click each program to include on the Scan To list.
  8. Click the Add arrow.
  9. Click OK .
  10. Scan a document using the Scan To button on the front panel.
  11. If the scan fails, try to scan using the HP Solution Center Scan button. If the scan still fails, please let me know.
Thank you so much.
adonscott
Jun 02, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP OFFICEJET 7410 "NO SCAN OPTION"
1.open the HP Director/Solution Center 2.click on scan menu and go to destination list tab 3. on the left side u will find a list of available destinations , move them all to the right side (front panel destination list) and save and then try to scan again , IT MAY WORK
Jan 01, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
160 people viewed this question
Ben Johnson
